Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Like Tree3Likes
Old 11-24-2013, 04:15 PM   #1101 (permalink)
Originally Posted by LouP View Post
Here is what mine looks like these days
Attachment 467501
LouP
I dig the Nav Lights.
Crakin is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 01:20 PM   #1102 (permalink)
Default blade 450x
my blade 450 x
ID:	470459   Click image for larger version
ss1-2013 is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 07:19 PM   #1103 (permalink)
Smile My newly redone 450
Just finished today my very first "project" on a helicopter, other than the 130X. I had lots of help from HF member Primal. installed Savox servos, Western Robotics BEC and a YEP 45A ESC. It is a busy place in the belly of the beast,
ID:	470561   Click image for larger version
ID:	470562   Click image for larger version
ID:	470563   Click image for larger version
renefigueroa is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 07:21 PM   #1104 (permalink)
I like your cano.
Lynx Team Test Pilot
Heli's :, Gaui X3, Logo 480,
Vbar Control
Lu523 is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 07:54 PM   #1105 (permalink)
Thank you, it is the Fusuno Skyhorse from the 130X
Old 12-09-2013, 10:28 PM   #1106 (permalink)
Alright, I'm currently uploading the last flight before my personal drama started. Since then I have installed a new ESC, Scorpion -6 motor, and re-geared a set of stock servosMuch different feeling. Initial test hover involved some flapping noise towards the end (will try and upload that as well) so I landed and it turned out to be my tail fin hitting my main blades. I'm surprised it ended as well as it did. A closer look revealed the bottom screw slipped out due to the plastic hole it screws into breaking off. Not sure how that happened. Anyway. I have it benched until the new tail case comes in. Crappy weather around here anyway. Thinking of ordering an aftermarket motor mount for the Scorpion. Also, has anyone had any luck with aftermarket tail cases/assemblies, if they are available?
Can you turn a 450X belt drive into a torque tube? Has anyone tried? Is it possible? What are the pros/cons of one vs. the other?
~~~Lynx Heli Team~~~
Ed Olson is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 10:01 AM   #1107 (permalink)
TT is more locked in but belt is more forgiving if you land in tall grass or tail blades touch anything.
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 10:23 AM   #1108 (permalink)
The Airetic
From what I rave read and heard, you should not be able to tell the difference between a properly set up TT set up and a properly set up belt system.
It's totally a preference thing. You have to a tension a belt, and you have to lube a TT setup. Pick your poison.
Episode Episode 114 of RCHN podcast covers this directly.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 10:37 AM   #1109 (permalink)
I managed to strip a TT gear on the X5 due to a stupid mistake where I let the tail blades strike the ground pretty hard. I lost the tail blades and stripped a few teeth on the front TT drive gear. The one thing I liked about it was that I was able to swap out that gear and the blades and had the thing back in the air in 5 minutes. I didn't even have to remove the boom. So it's a concern, but with the right design it doesn't have to be a huge headache to repair.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 02:33 PM   #1110 (permalink)
Originally Posted by Boris the Blade View Post
Here is my bird.
Awesome. Trex 500 Skids?
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 05:26 PM   #1111 (permalink)
Default Post pics of your Blade 450X
Been a while since I dropped a pic in here...
Current favorites...
Oxy 3, Goblin 380, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc..
Inverted2112 is offline        Reply With Quote Quick reply to this message
Old 12-11-2013, 07:08 AM   #1112 (permalink)
Attachment 467501
LouP
I like the scorpion tail light..too cool.
Recent 3d to X conversion.
Name:	450 3d  to 450x 004.jpg
Paper Money + Heli`s = Loose Change !!
Mr.D 4511 is offline        Reply With Quote Quick reply to this message
Old 12-11-2013, 09:49 AM   #1113 (permalink)
How did it go? Did you use the Stock Flybarless head? Have you flown yet? Im curiious. THanks
*LINKS*
Old 12-11-2013, 07:17 PM   #1114 (permalink)
The conversion went real smooth.The only thing that I didn`t bargin on was having to turn in on all the swash link rods..somewhere around 4 each.Yeah..I used the Blade drop in assembly.I did get to test hover it.First lift was straight up and out in 10 mph wind @ 45 dgr.Not the best hover on my part but a good build.[ame]http://youtu.be/pdrrAyn0JTk[/ame]
Old 12-11-2013, 07:20 PM   #1115 (permalink)
Sorry about that.I just put a flight vid on a pic thread...Ive got pics up in the "ok ,I`m gona do FBL" 450 forum thread.Havent been able to go out since i hovered it..sick in bed with the flu...its nasty out anyway...but hopfuly won`t have to wait too long.
Old 12-19-2013, 04:37 PM   #1116 (permalink)
Default 450 X conversion
A shot of my latest.A bit fuzzy though.
Name:	Ready to Go 008.jpg
Old 12-26-2013, 10:04 PM   #1117 (permalink)
Default Re: Post pics of your Blade 450X
Sent from my SAMSUNG-SGH-I317 using Tapatalk
TEAM HORIZON HOBBY
Find me on youtube :: http://www.youtube.com/user/highadvantage
jchandler is offline        Reply With Quote Quick reply to this message
Old 12-28-2013, 03:41 PM   #1118 (permalink)
TEAM HORIZON HOBBY
Old 12-28-2013, 03:56 PM   #1119 (permalink)
Did you find the canopy???
Old 12-31-2013, 06:21 AM   #1120 (permalink)
Attachment 467501
LouP
Cool. Where did you buy the nav lights?
Sport Flyer = Blade 500 3D (2), 360 CFX, 450X, XK110, XK123, XK124
mulcherhead is offline        Reply With Quote Quick reply to this message
