Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 03-15-2012, 10:53 PM   #1 (permalink)
Default IMPORTANT: SAB Announcement for Goblin Owners
Moderators, please make sticky if possible:
Hello all,
Please watch this video as it contains some important information about the first two batches of Goblins.
Thank you!
Bert Kammerer
http://www.bertrc.com/
Bert Kammerer is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 11:47 PM   #2 (permalink)
I measured 140mm on mine. Guess I need to do the tape mod.
Xpert
Scorpion Power Systems
OnlyFineHelis. Family Run/Operated
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 11:49 PM   #3 (permalink)
Member
Thanks Bert.
Old 03-15-2012, 11:55 PM   #4 (permalink)
Tape Mod??? It will just compress and cause it to be out of alignment again. Will SAB replace these problem booms?
VControl
Old hand at Planks
Peter
Old 03-16-2012, 12:21 AM   #5 (permalink)
Mine is 146 mm....
If I understand it is Ok. right?
Stefano
ste_23_66 is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 12:40 AM   #6 (permalink)
Member
Originally Posted by ste_23_66 View Post
Mine is 146 mm....
Stefano
Sounds like if you have 145mm or higher you are good.
Old 03-16-2012, 12:42 AM   #7 (permalink)
Mine is good as gold...
Distributor of SAB, MSH, Outrage, AleeS, Gens Ace, Beastx and more products for South Africa
Goblin Hobbies South Africa PTY LTD
Ktmheli is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 02:05 AM   #8 (permalink)
I would think 0.2mm shims would be a better idea. Anyway just measured ours and it's 148mm so no problem.
I'm sure that once the dust setlles SAB will be replacing a few bits like booms and off-centered secondary shafts. Maybe they'll just give all of us new kits, lol!
cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 05:37 AM   #9 (permalink)
There is nothing wrong with compression. Most tapes are too thick anyway and you need some degree of compression. Keep in mind, 0.1 to 0.2 mm in the front translate into several mm in the rear.
Not sure what SAB will do, will find out soon. The important thing is that SAB is trying to keep the lines of communication open with the customers to ensure that they have a good experience with their products. As with any new mass production helicopter, there are normal growing pains, but they're being taken care of and addressed immediately. We're inspecting every single important part that comes out of the assembly line right now.
Bert
Bert Kammerer
Old 03-16-2012, 05:54 AM   #10 (permalink)
Mine is ok.
Thanks!
alexvan is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 05:56 AM   #11 (permalink)
Thanks Bert, will check mine tonight.
Cris
Cris Trebbi
Ci+izen #012
SynergyAero is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 08:07 AM   #12 (permalink)
Thank you Bert and SAB, mine is 147 so all good.
mykel is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 08:53 AM   #13 (permalink)
Nothing a piece of tape cannot fix! Does it have to be red though? I'm asking this because the color of the tape used seems to be important when fixing RC helis:
https://www.helifreak.com/showthread.php?t=380401
3Dmuse is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 09:44 AM   #14 (permalink)
I have measured mine and it was 142mm. So I tried out a couple of possible combinations, and I found out a quite effective one. As you can see in the following photos by using two little pieces of simple electrical insulation tape (its quite thin) you can achieve an increase in the distance of boom and blade tip of 5mm.
You can double that by using two layers of tape. Mine is now 147mm. By placing the tape that way you also make sure you will not have any side ways movement of the boom as it still makes very good contact on the sides of it's base.
Tape must be red though.
ID:	299246   Click image for larger version
<<JR VIBE 50--LOGO 400--COMPASS 6HV>>
aris2024 is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 10:20 AM   #15 (permalink)
+1! mine is 139mm then SAB will just have to ship me a new boom! don't want to tape mod my heli.!
Yoda DK is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 01:57 PM   #16 (permalink)
hopp my is fine , getting it on monday- tuesday , don't want to do any mods
| Kraken 700 : Neo | Atom 6HV : Neo | Align 500X : Neo | vbct : |
ragge1 is online now        Reply With Quote Quick reply to this message
Old 03-16-2012, 09:09 PM   #17 (permalink)
Mine was 131 mm !!!! I put a layer of 0.7mm thick electrical tape (thick stuff, you can get it at Home Depot) and now it sits at 144.5 mm. Good enough.
Goblin 700C | Goblin 500 Sport | Trex 700L Dominator | Trex 450L Dominator | Trex 250DFC | DJI F450 | Armattan Chameleon FPV
justindewoody is offline        Reply With Quote Quick reply to this message
Old 03-17-2012, 02:50 AM   #18 (permalink)
just measured mine (from first batch) its 149-150
I noticed at the risk of breaking my blades if you bend the blade down from the tip it comes to about 50mm clearance from the boom. didn't want to risk pushing it further in-case i broke my blades
Phil777 is offline        Reply With Quote Quick reply to this message
Old 03-17-2012, 05:25 PM   #19 (permalink)
Bert
While this is great that SAB appear to be sorting the issues I think they should not be there in the first place.
Not just SAB but in general, we hobbiests for some reason accept it, say to ourselfs and others that it's fine,why? It's not fine and we don't accept it in any other part of our life's.
What would you guys do if you brought a new car, a band new model and it had defective brakes?
Accept it, no you would be back in the dealers the same day and they would sort it for you ASAP foc.
Now I'm an early adopter purely because if I see something I like I get it so it's actually because of people like me we have these issues and manufacturers think is acceptable to release a product that is not 100% ready strange one but that's what this hobby does to us
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 03-17-2012, 06:07 PM   #20 (permalink)
This is why they have "recalls" . Remember Toyota?
In all honesty this happens in all industries. Some fix em some don't.
Surely some, if not all, "previous" helis on the market have design flaws, but we do/did not recognize them.
I think having transparancy on such issues allows us to act, either by implementing the "mod" or by applying for a proper fix. At least we are informed!
Surely SAB takes their customers seriously, but I'm convinced a lot of the manufactures "transparancy" comes from "brand" protection. This is where the power of the customer lies
Just saying life is not black or white ...
Grtz,
Marc
***** If it FLIES it WILL CRA$H *****
T18MZ, JR Sylphide E12 & E11, JR Airskipper 50 FBL, Hirobo Sceadu EX 50, Hirobo Lepton EX
poerqwa is offline        Reply With Quote Quick reply to this message
