Old 02-11-2013, 02:10 PM   #21 (permalink)
Originally Posted by CalleDK View Post
Its because 1 is your idle up settings... So your have to switch your idle up switch to on.. Before you can see this settings
Sendt fra min GT-I9300 med Tapatalk2
Ok. So i flipped what should be my Idle Up switch ( 0 Gear / 1 F Mode switch in front of the trainer switch) and nothing happened in that menu. I switch other switches on my Dx6i and 1 at a time they change to 1.
Cali_Heli_818 is offline        Reply With Quote Quick reply to this message
Old 02-20-2013, 11:28 AM   #22 (permalink)
On the DX6i, scroll down to the Setup List. Then scroll down and select D/R Combi and change this setting to FM (flight mode).
Now when you toggle the switch from 0 (Gear) to 1 (F Mode) on the DX6i all your D/Rs will change at the same time. You can test this by going into the D/R settings and then toggling the switch, you will see the O's change to 1's...
DrCopter
mCPx v2 - SR - 120SR - mSR X - DX6i
“Once you have tasted flight, you will forever walk the earth with your eyes turned skyward,
for there you have been, and there you will always long to return.” -Leonardo da Vinci
DrCopter is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 03:48 PM   #23 (permalink)
THANK YOU! That worked and i was able to change the settings on that tiny part of it to what they were supposed to be. Now i have another question...
Are these settings the normal flight settings or are these tuned down for beginners? This is my first heli/dx6i and want to know if ive been learning with turned down settings or if these are what everyone flies.
Old 06-07-2013, 09:13 AM   #24 (permalink)
Default Nano binding
Should the nano be bound with the rates set on high 100% or when on the reduced 85% rates or does this not matter. All when saying to change the collective to tamer rates for beginner, does the heli need to be rebound for these settings to work, thanks ...
claudecracker is offline        Reply With Quote Quick reply to this message
Old 06-07-2013, 06:22 PM   #25 (permalink)
Default Re: Blade mCPX - DX6i/DX7/DX8 TX Settings for Beginner/Normal/3D
AFAIK rates expo etc are irrelevant to the bind. You can actually switch rates mid flight with no problem.
Sent from my GT-I9300 using Tapatalk 2
welshboy is offline        Reply With Quote Quick reply to this message
Old 06-23-2013, 04:46 PM   #26 (permalink)
Default dx7s setups
can someone post a setup for the mcpx bl setup for 3d. I for the life of me can't make one that will let me fly upside down in phoenix.
Is the idea to keep throttle constant and just have pitch change? Cuz it didn't work.
I have the dx7s radio. Many thanks.
kecked is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 06:28 PM   #27 (permalink)
Hi
I've an mcpx bl and I wonder whether I should use the same settings as mcpx2.
any help would be appreciated.
thanks
heavenscanwait is offline        Reply With Quote Quick reply to this message
Old 09-27-2013, 05:08 PM   #28 (permalink)
*crickets chirping*
Wow... Two weeks with no help? Not sure if you're still looking for an answer here or if you found one elsewhere. It may or may not be possible, but I don't recommend it. The BL can handle much more than the v2, and settings that are comfy for the v2 will not work the same on the BL.
FP - Blade mCX2/mSR {x2}/Nano QX{x2}/120SR - Syma s107g - Xieda 9998{x2}
CP - Blade Nano CPx/mCPx(v2+BL {x2})/CP Pro 2(Scale Build in Progress)/300x/300xSS(Benched)
TX - Spektrum DX6i/DX8
jcmo is offline        Reply With Quote Quick reply to this message
Old 09-28-2013, 08:25 PM   #29 (permalink)
Default What's Goin' On
Dear All
JCMO is right. I'm also equally perplexed. 17 days and no answer (apart from JCMO).
So now I have MCPX BL but still no wiser how to set it up on DX6i.
Is there any one out there who can guide with correct and "detailed" settings. I need detailed as I'm a newbie.
In desperation, today I tried with default settings on DX6i and stopped after 3 hard landings (out of 3)
I would very much appreciate some help
Old 09-29-2013, 05:43 AM   #30 (permalink)
Originally Posted by heavenscanwait View Post
Dear All
Isn't there a post for that in the specific mcpx BL forum ? Anyway, since there is a specific forum for the mcpx BL, you should ask your questions about it there, you'll get more answers. (I'm a noob mcpx v2 owner myself so I can't really help you).
Aryemis is offline        Reply With Quote Quick reply to this message
Old 09-29-2013, 07:36 PM   #31 (permalink)
Thanks. Just did that yesterday and let's see what happens
