Furion 6 went in... - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Electric
MA Electric IonX2, Razor and Furion Support forum
Old 04-01-2012, 02:59 PM   #1 (permalink)
Default Furion 6 went in...
Furion 6 went in this afternoon.
Was just coming out of a loop and everything stopped. I mean I think the head stopped turning... not sure, it all happened so fast. It dropped like a rock into a muddy area from maybe 200 feet up.
Damaged Canopy, tail boom and that's all I see for now.
I actually spooled it up (low rpm) after and everything looks ok.
Is it possible the one-way seized up in flight?
Not sure where to start?
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote Quick reply to this message
Old 04-01-2012, 03:57 PM   #2 (permalink)
Ouch. Sorry to hear about the crash.
When you say the blades stopped. Did they stop all at once or by the time the bird hit the ground they were stopped?
I would think that if the owb had locked up you wouldn't know it until you tried to shut it down.
If the electronics lost power or the RX had a signal loss the heli could have gone into fail safe and that could be power down if you haven't set it up otherwise.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 12:52 AM   #3 (permalink)
Sorry to hear.
LOGO: 480XX, 550SX, 690SX, 700
VCONTROL, NEO, TRIBUNUS, DPL8, BUMP CONTROL, MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 04-02-2012, 02:41 AM   #4 (permalink)
Sorry to hear the bad news Danny. Did you forget to switch out of normal mode (if you still use it) before the loop? I agree, if the one way seized you wouldn't notice until you spooled down or tried to auto.
spootman is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 09:59 AM   #5 (permalink)
A seized one way would not stop the blades unless the belt broke and wrapped up the main gear too. Just sounds like you stalled the blades and it fell from the sky....things happen quick.
jadams is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 10:39 AM   #6 (permalink)
Just from the size of these blades, it would be amazing that they could just "stop"without completely wrapping up the head. There is a lot of stored rotational energy in the blades.
Must be one of those "slow motion" like feelings you can get when something like this happens.
Sorry to hear about it though.
ahahn is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 11:34 AM   #7 (permalink)
Probably was one of those "slow motion" moments, but still to fast to really see what's going on.
I was in idle 1 head should of been at 2100 rpm.
I've read about this particular ESC momentarily shutting down power to the motor and I'm looking into that.
If the motor lost power and I stalled the blades with high collective, it would explain what I saw at least what I think I saw.
@spootman Not totally sure my belt tension was correct - when I get it back RTF I would like you to give it a once over.
Thanks all.
Old 04-02-2012, 12:27 PM   #8 (permalink)
Sorry to hear! What ESC?
Synergy N5c YS56, CGY750
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
drdispatch is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 12:57 PM   #9 (permalink)
YGE HV90. I kind of doubt that this is the cause but I just don't know.
This ESC has a shorter servo-type connector used for programming, and some have experienced this thing cutting power to the motor somehow, their fix has been to put a bind plug on it to ground the signal wire.
Maybe I just over AMPed the ESC?!?
Maybe I have a bad solder joint in the power grid?!?
Makes me kind of wish I had the Castle Creations logging.
Old 04-02-2012, 02:56 PM   #10 (permalink)
Also check for binding, if the Hitec Rx's are like the Spektrums, binding in the servos can shut the Rx down.
Old 04-02-2012, 03:08 PM   #11 (permalink)
Although anything is possible I think it unlikely in this case...
The Rx is connected to the Skookum Flybarless Controller, then servo wires go from the FBL unit to the Skookum Power Bus(Voltage is fed to this from the BEC), and from the Power Bus to the servos.
Mistake I made was to not look at any of the "Indicator lights" on any of the electronics (ESC, FBL, Rx)... I was in to much of a hurry to shut it all down. There might of been a clue.
Old 04-02-2012, 03:24 PM   #12 (permalink)
I guess rebuild and fly, count it as a fluke?
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
Old 04-02-2012, 04:48 PM   #13 (permalink)
Pretty much
Parts that hurts are the canopy $80 and the blades $90!
I have a brand new Ice2 120 that I might try.
Old 04-02-2012, 05:14 PM   #14 (permalink)
one thing that stands out, this heli can take a crash, I can fully attest to that.
Team Horizon Hobby
My RC facebook and Youtube Page (please subscribe to get latest news and video):
http://www.youtube.com/zoomtt
http://www.facebook.com/zoomtt
edsel.labao is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 06:06 PM   #15 (permalink)
My YGE 90HV shipped Saturday
Hoping I wont have any issues.
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
Old 04-02-2012, 07:19 PM   #16 (permalink)
Apparently it now ships with the bind plug already on the programming lead.
Besides, I'm not convinced that the ESC was the problem, but I'll probably never know.
I'm going to load the sucker up with all the Hitec telemetry before the next flight; Voltages, amps, temp...
Old 04-03-2012, 01:55 PM   #17 (permalink)
Hmmm... seems the Hyperion motor that I am using is rated 100amps continuous, and the ESC is obviously rated 90amps continuous.
Maybe I pushed it to hard and the ESC did shut down.
Not that I am much of a stick banger, but I did some big power loops and my collective pitch is +/-14 degrees.
This did all happen approximately 5 minutes into the flight and the YGE Gov would of definitely pushed the motor to keep its speed and therefore require high amps.
Just thinking out loud "so to speak".
Old 04-03-2012, 02:13 PM   #18 (permalink)
That could happen. Do you know what is the peak power the yge can handle?
Team Horizon Hobby
Old 04-03-2012, 02:17 PM   #19 (permalink)
I've been looking and can't find anything.
Old 04-03-2012, 03:05 PM   #20 (permalink)
Just because a motor/esc is rated at 100 amps doesn't mean that you will actually pull that much.
That is entirely dependent on how much you are loading things.
In fact you can pull an arbitrary number of amps, at least for a short time , limited only by the coil resistance of the motor. Likewise with a low loading you can pull just a few amps.
The best way to see what is going on is to use a datalogger. Another option is to look at what other Furion6 setups are getting.
If you are flying a particular style, you will need a number of watts going into the rotor. This is independent of whether you have a 6s, 10s, or 12s setup. Of course the amps will scale inversely with the pack voltage. This at least will get you in the ballpark.
Insurance
Human Verification
