Blinking Satellites - HeliFreak
Old 04-06-2012, 12:03 AM   #1 (permalink)
Default Blinking Satellites
Hello,
I upgraded my Mini V-Bar 5.0 Express to 5.2 Express today. I rebinded my DX7 to 2 JR DSM2 Sats that I've had for over 1 yr and previously working. After binding w/ digital center, I re-power the system ( align 35 ESC and 3s charged pack) and the sats are solid but both blink slowly after the VBAR initializes and the servos jump. I power off and back on the DX7 and then the VBAR, same results numerous times. I'm out of ideas. I did change the satellite cables w/ 2 new ones I had sitting around.
mCPX BL
NovaCX12 is offline        Reply With Quote Quick reply to this message
Old 04-06-2012, 12:20 AM   #2 (permalink)
Blinking means theres a power problem.
Try the same test with a receiver battery instead ( pull out esc lead for test )
You could also do a power up while connected to the computer and check for the min voltage in software.
Sadly the event log isn't available in express but only in pro
Martin
Logo XXtreme 800 8917 / 256HV VBC
rcmarty is offline        Reply With Quote Quick reply to this message
Old 04-06-2012, 01:27 AM   #3 (permalink)
I just plugged in the same ESC and 3S lipo to my 450 Pro with vbar and 1 sat, I could not replicate the same blinking satellite(s). Voltage in the vbar software showed 6.0v Act and 5.6v Min each time. If it matters, the vbar with blinking sats issues have 3x DS610 and 1x BLS251. My 450 Pro has 3x DS92s and 1 x DS520.
mCPX BL
Old 04-06-2012, 02:54 AM   #4 (permalink)
Slow blinking on Dsm2 you get if you cycle power on satellites (intentionally or not) without cycle power on radio.
http://heli.dacsa.net
Old 04-06-2012, 03:06 AM   #5 (permalink)
I re-power the system and the sats are solid but both blink slowly after the VBAR initializes and the servos jump.
mCPX BL
Old 04-06-2012, 03:16 AM   #6 (permalink)
Pm me your serialnumber
Old 04-06-2012, 05:41 PM   #7 (permalink)
Hi guys any word on what this is?
Logo Xxtreme 700, Kosmik/Scorpion, HC3-SX, 451/251, Edge
Logo 600sx, Kontronik, vBar, 451/251, Edge
Logo 500se, Kontronik/Scorpion, HC3-SX, 451/251, Edge
Avant Ultimate Ys91SRS/Hatori, vBar, 451/251, Edge
Stuarty is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 03:37 AM   #8 (permalink)
In his case a internal faulty regulator
Old 04-09-2012, 12:44 AM   #9 (permalink)
I've noticed this after flights every now and then.. But it's always just one of my satellites..
-Goblin 700: Crashed but re-building, still needing electronics
-Goblin 630: CC Ice 120HV, vBar
scoti333 is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 04:37 PM   #10 (permalink)
Check the cable for that satellite.
Use hot glue or similar on the connectors.
Old 01-28-2014, 06:16 AM   #11 (permalink)
Hi, it seems that I also have the blinkig issue. It is my fifth vBar.
It is a blue mini vBar. A new one that I bought during the Mikado winter sale.
The satellite blinks just after initialisation or starts blinking after moving the sticks. The blinking happens when there are at least two servos connected. The max current from the ESC when doing these pitch pomps was 1A. The ESC is a standard Align 35A ESC.
The heli did tons of flights with the same setup (ESC, servos, satellite) and another vBar.
So, it looks as if there is a power supply issue. See the movie below.
I tried the following and it seems that the vBar is faulty:
- install another vBar with the same servos, ESC, satellite
- supply power from another source.
- different servos
- different cable to the satellite
- different satellite
Do you have any idease before I send it back for repair?
[ame]http://youtu.be/16GCyjG_CF4[/ame]
emilh is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 06:49 AM   #12 (permalink)
Default Re: Blinking Satellites
- different servos
Have you tried a different Vbar. If it's fine with the other one then I would say it's the Vbar.
Sent from my SCH-I545 using Tapatalk
Protos 380 Vbar NEO, HW 60A V4, XNOVA 890KV
Raptor E700 700MX 510KV, Castle 120HV w/Vbar Neo Gov 1960
Working on getting Protos max
Vcontrol
tshelby73 is online now        Reply With Quote Quick reply to this message
Old 01-28-2014, 09:00 AM   #13 (permalink)
- different servos
So are you saying it worked with a different Vbar? Was it a full size Vbar or mini? What does the Vbar log say? Post the log.
Wayne Armstrong
Logo 480 / Logo 600sx / Logo Uvular / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 09:08 AM   #14 (permalink)
It was a big silver vBar.
I don't have access to the log because I am using the Express firmware.
Old 01-28-2014, 05:34 PM   #15 (permalink)
Big Vbar is less susceptible to power spikes/dips because according to Mikado it has some small capacitor on the power buss thats not on the MiniVbar. Some servos can cause the problem other times a poor BEC.
You can read about it here: http://www.vstabi.info/en/node/1327
Way to test it is to add a capacitor to the power buss. Seen the capacitor work to correct this sort of thing and its worth testing. I've used 6800mf 16v capacitors.
Wayne Armstrong
Old 01-30-2014, 07:26 AM   #16 (permalink)
Thank you for suggestions.
Information: the servos are KST DS115MG. However the blinking also happened when I replaced them with one Align DS410 and one DS610 servo (both servos pugged in at the same time).
In order to investigate the issue I did the following things:
1. Tests with another mini vBar
2. Tests with three Align DS415 servos
3. Tests with a capacitor and KST servos
4. Firmware upload to version 5.3 PRO
A picture - for the record - is attached below. The whole story seems a bit ridiculous to me and does not have a happy ending :-)
It was a black mini vBar - no blinking issues at all. Even when the 'pitch pomp' was set to 100.
This qualifies the blue mini vBar for repair in my opinion.
So again the faulty blue mini vBar with express version (pitch pomp: 0). And three DS415 servos - no blinking issues noticed.
Conclusions:
a. Align DS415 servos draw less current than KST servos (abvious beceause KST servos have better parameters). And the vBar seems to be OK, however the black version works better - because it handles KST servos as well.
b. Two Align DS415 servos draw less current than one Align DS610 servo.
See the capacitor in the picture. So in order to use my KST servos I decided to use the capacitor. Quite big it is - but - it really worked! No issues observed. I agreed mentally (unwillingly) to have the capacitor installed on the model. But I wanted to make sure that it will also work with the pitch pomp set to 100 (as Mikado rekomends to check), so - go to point 4.
To activate the pitch pomp and the vBar log I purchased the PRO version. But during the firmware upload to the device (very close to the end) - the vBar switched off suddenly and my computer displayed something like 'The device in not operational. The operation can not be completed'.
Since that the vBar does not work at all, the computer software does not see it.
So I don't have any option rather than send it back for repair. The conclusion that the blue version is worse that the black version - point 2 above - may not be true, because during the whole time there was something wrong with it.
Name:	vBar and capacitor-small.jpg
Old 01-30-2014, 10:21 AM   #17 (permalink)
You can try the Vbar upgrade recovery file to recover from failed upgrade attempt. Its located at the bottom of this page link and you need to be logged in to download the file.
http://www.vstabi.info/de/node/112
Wayne Armstrong
Old 02-01-2014, 01:45 PM   #18 (permalink)
my experience was BAD with spektrum and vbar.
i went futaba and no more issues whatsoever.
im not raggin on spektrum im just ragging on spektrum in conjunction with vbar.
Sent from my Samsung S4 using Tapatalk 4 because Tapatalk2 just vanished........
crf69 is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 02:55 PM   #19 (permalink)
+1
Saeed
saeed09 is offline        Reply With Quote Quick reply to this message
Old 02-04-2014, 03:43 AM   #20 (permalink)
Thank you for the hint. I managed to recover and upgrade to the PRO version. With the 100 pitch pomp, and the capacitor, I did not observe any power spikes/dips; with my KST micro servos installed.
The vBar log - when the capacitor was unplugged - is attached below. Yeah, the voltage drops below 3,3V.
I will write about it to Mikado because - the black mini vBar does not require any capacitor. And I suspect that other mini blue vBars neither:
But first I will do two more tests:
1. This mini blue vBar with full size HV servos (and 2 cell Li-Po)
2. This mini blue vBar with full size LV servos (and the standard Align BEC)
Name:	T-Rex450PRO2 voltage drops.JPG
Insurance
Human Verification
