Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
04-06-2012, 08:03 AM | #1 (permalink) |
3g gain or lockgain
hi guys , just flew for the first time my 600n (first time nitro) my heli his bobling just hovering like a wag on eleveteur i whas wondering if it could be the lockgain the tail jump up and down
ok my 3g not 3gx is on v3.0 (no probleme on my 550) gain in the gaui is at 65 pots on unit are at 11 o clock ....give me 160 of gain in the gaui my lock gain are still at 70 my 550 did the same thing whent i put a strap to hold the 3g so maybe its vibration related my engine is so rich maybe that the probleme but i cannot tune it its to hard for me to fly it in that condition i only hover until i get a better feel of they heli so because its hard on my nerve i am asking what would you do drop gain again and try OR keep gain hight and lower lock gain? thanks guys franck
trex 600n sk 540 / limited edition os55hz-h /powerboost trex 550 v2 mcpx /dx7 / phoenixrc / fs one |
04-07-2012, 10:53 AM | #2 (permalink) |
Hey.
Sounds like the elevator gain is a touch too high to me, try lowering it. The lock gain symptoms you don't normally see until you're doing aerobatics I found. What settings are you using? Your rich engine wont help, any popping/rpm fluctuations will add vibes to the air frame, so will be a good idea to try and smooth this out to. . |
04-07-2012, 12:14 PM | #3 (permalink) |
thanks for thy info
my setting align 610 cyclic 650 on tail 620 for trotlle 25 exp on remote 0 in 3g gain on tail at 70 on remote in gaui stock (no drift no wag) 3g ver 3.0 mud done gain in gaui 65 unit at 11;00 for total off 150 / 200 ele and ail now i lower them to one 140 gyro 1 layer of 3gx tape / plate and 2 3gx tape then 3g gyro no strap i am using 600 3d pro blade (not fbl) tc 0 linear to 80 gouv not activated dint try the gouv yet or idl1 or 2 just hover in normal mode pcurv 40 45 50 75 100 normal mode then 0 25 50 75 100 in stunt mode i lean the motor a litle bit should help your rigth its not running very constent the only time one of my other heli did that whas because to much vibs or bad monting tape its my first nitro i know they have more vibration maybe i need to find more soft tape to mount the 3g but everything they sale those days is so thin and hard thanks
04-08-2012, 08:32 PM | #4 (permalink) |
its all good i lower i litle bit the gain tune my engine and my head speed whas not enough hight it whas wobbling a litlle bit but has soon has i engage the gouverneur everything whas awsome
loving my nitro experience
