Old 05-28-2012, 08:49 AM   #41 (permalink)
Do you balance your blades? Lots of times mysterious problems with FBL are vibration based.
Harbormaster is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 09:25 AM   #42 (permalink)
I balanced the whole head originally. I took the EXI 3dpro's off my 400 and tried them, they were smooth as well..only wobbled about every third pitch pump and not near as bad as before. The blades I had on it to start were the Yellow/black EXI's (I have two sets) and I tried the other pair on my 400 a week ago and even balanced it have a vibration. Tracking is spot on as well. I chock it up to shitty blades..
Compass 7HV Gaui X5 Formula HD Cell 500
LawnDartHeli is offline        Reply With Quote Quick reply to this message
Old 05-29-2012, 09:43 PM   #43 (permalink)
Can anyone please tell me if the Copterx 3X1000 Gyro get its power from connecting the ESC directly to the Gyro? Or does the ESC still connect to the Receiver and the Gyro is powered through the other cables that connect to the receiver?
Would it be better to plug the ESC into the Gyro so the power is more reliable for the servos? If so, how does the ESC then get the signal to run the motor?
You'd think a manual for a product would explain this detail, but obviously the think that its obvious enough they don't need to explain it!
Thanks.
meherenow7 is offline        Reply With Quote Quick reply to this message
Old 05-30-2012, 10:43 AM   #44 (permalink)
Receiver still gets power from the esc, only servos and gyro gain go to the fbl unit and it takes it from there.
Old 05-30-2012, 10:48 AM   #45 (permalink)
Got a problem fellas..
I was going to program some different settings in my Cx unit last nite and It wont link up. I done everything the same as I did the last 10 times, but for some reason it wont connect..all I get is a blue blinking light on my programming cable and the three red dots above the "connect" tab flash along with it like its trying to connect. Any ideas?
I uninstalled/reinstalled the software, uninstalled/reinstalled the usb driver, changed com ports around...nothin'.
Old 05-30-2012, 10:53 AM   #46 (permalink)
can you post a pic of your wiring?
Hello My Name Is Joe
Blade 130X - Lynx EOX / Blade 300x - AR7200BX, 2213-3585 / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX / TSA 600e Pro - AR7200BX, 700MX / TBS Discovery FPV - APM, Sunnysky 980kv/ DX8
jabu32 is offline        Reply With Quote Quick reply to this message
Old 05-30-2012, 01:20 PM   #47 (permalink)
Me?
Old 05-30-2012, 02:03 PM   #48 (permalink)
Have you tried changing the sequence in which you do things? That did it for me. It has been a while so I forget the details, but it was something like connecting everything up like I usually did, it didn't link, then disconnecting the USB dongle and reconnecting it, and then it worked.
Old 05-30-2012, 03:19 PM   #49 (permalink)
Did yours just blink the whole time like mine as well? I'll try a couple different things this evening. I was getting pretty frustrated with it last nite so Im not sure what ways I did try it.
Old 05-30-2012, 08:45 PM   #50 (permalink)
Ahhhhhh...how I hate computers
I tried and tried for the last hour, finally I just uninstalled the fbl-biz software and downloaded the Copterx software, connected as soon as I hit the button. I guess its a firmware issue?
I like the biz software but my unit doesnt, looks like Im stuck with Cx's.
Old 05-30-2012, 08:47 PM   #51 (permalink)
got my balls last night, fitted ok, just need time now to setup the gyro
quick question once i run through the setup is there anything else i need to check for?
how do you check for +- pitch or does the setup with the gyro cover that?
berserkk is offline        Reply With Quote Quick reply to this message
Old 05-30-2012, 08:57 PM   #52 (permalink)
I did a mechanical setup on mine without the fbl unit to get 0 at mid stick/servo arms @90, equal throw both directions. You will set pitch travel with the unit, so yes..you will use the software to set pitch.
Old 05-31-2012, 08:00 AM   #53 (permalink)
did you have to mess with the Swash Travel and Collective Pitch Settings or did you leave them default?
Old 05-31-2012, 08:58 AM   #54 (permalink)
The swash travel was fine on mine, I did back the collective down to lower pitch..it had some wicked tail blowout. Turns out my pitch was somewhere around 14-16 degrees at full throw, backed it down to around 6 till I could get it all smoothed out. I'll increase it before I go bottom-side up
Old 05-31-2012, 11:47 AM   #55 (permalink)
which swash are you using on your setup?
Old 05-31-2012, 02:31 PM   #56 (permalink)
Tarot
Old 05-31-2012, 03:37 PM   #57 (permalink)
oh you installed this on your 450, right?
Old 05-31-2012, 04:22 PM   #58 (permalink)
Yup. Havent decided how im gonna go about converting the 400 yet..
Old 06-10-2012, 08:13 PM   #59 (permalink)
Okay, so after a day of flying my fbl clone and my B400 I have officially came to the conclusion that flybars do indeed suck. I just placed my orders for a Tarot head and another CX unit. Hopefully by next weekend the ol' 400 will be swinging a little less hardware up top. There is absolutely no comparison on the way my B400 fly's vs my fbl 450...damn 400 fly's like a school bus with 3 flat tires.
Old 06-10-2012, 11:26 PM   #60 (permalink)
Maidened my b400 yesterday fbl yesterday!
I'm still having some trim issues (which is weird because i figured the fbl shouldnt have any trim issues??)
Any tips on trimming it out? what settings do i adjust if it drifts right and back?
thanks heaps for the guide and tips!!
