Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR X
mSR X Blade Micro SRX Helicopters Information and Help
Old 04-14-2012, 06:23 AM   #1 (permalink)
Default What is the white stuff on the board connectors?
I recently had to replace an intermittent main motor on my mSRX. I used a hobby knife to cut off the white, smooth blob of rubber stuff HH used on the connector. For the motor, I had to cut away the black melted rubber they used to hold it in place.
Once that was done, it was pretty straight-forward to slip the motor out and a new one in and plug in the wire. But I can't figure out what to use to seal the connector so it doesn't come loose in flight - same with the motor. I tried basic clear Dap silicone caulk - just a dab. But no joy. I went to pull on the connector this morning and it came apart easily. See the attached image.
Any suggestions?
Thanks!
/Hal
____________________________________________
Goblin 700C - VBar Neo | Goblin 420 - VBar Neo
MIKADO VControl | SPEKTRUM DX9 | iCharger 406 Duo | Meanwell RSP-1500W-24V
CaptHal8HS is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 11:57 AM   #2 (permalink)
I use a dab of shoe goo ....works for me.easy to peel off later if need be.
Blade ScoutCx/MCX2/MSRX/120sr/DX6i
newhelicrasher is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 12:15 PM   #3 (permalink)
I use automotive rtv on the plugs, It doesn't really have to have a super strong hold, you just want it to keep the plug from vibrating out.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 01:21 PM   #4 (permalink)
What the heck is shoe goo?
/Hal
Old 04-14-2012, 03:13 PM   #5 (permalink)
The white and black stuff is probably electronic RTV. The RTV typically found in the hardware stores should not normally be used around PC boards, etc. because it has an ammonia solvent in it and tends to be corrosive.
milterb is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 03:19 PM   #6 (permalink)
UH OH!!! What about automotive RTV , I got that stuff all over every heli I own..lol
Old 04-14-2012, 03:32 PM   #7 (permalink)
As an addendum to my previous reply, I remember when I was watching the repair CD that came with my msrx that the guy demonstrating how to reassemble the heli had a bottle of elmers while glue he used to glue in the motor. Just a dab. I haven't watched that CD for awhile, but I am fairly sure that was what was used.
Old 04-14-2012, 03:48 PM   #8 (permalink)
Elmers white glue, Household Amazing GOOP, and shoe goo are all good. I use household Goop . It's got a killer strong hold like gorilla glue but will peel off in one piece with a little convincing. The key is to get it on the plug VERY fast out of the bottle. It looses it's "tack" almost immediately.
DSMX DX6i, MH mCX2, mSR, BL RKH mSR X, 3 X mCP X v.1 (one stocker, one destined for DBL, one destined for DBL mini130X), Lachmund mQX
PM me for your soldering and mSR X BL build needs.
burnoutboy is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 03:50 PM   #9 (permalink)
If the automotive RTV you used smells like ammonia when you sniff the tube then thats what is in it. That's not necessarily fatal however, the heli parts are out in the open and get ventilation and most of the ammonia evaporates away. Its just that there is the chance of corrosion. Its just something to be aware of.
Old 04-14-2012, 03:54 PM   #10 (permalink)
It does stink like crazy when it's wet, it dries pretty quick though and I have been using it for months so I guess I will just keep an eye on it.
Old 04-14-2012, 06:40 PM   #11 (permalink)
I use Elmer's Glue. It doesn't grip as well as the original stuff that is on there but it keeps things in place and is easy to remove.
Neon888 is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 07:03 PM   #12 (permalink)
formerly koi-fish
Default Silicone
Ive always use clear non corrosive silicone (clear).....works well
/sr,msr,msrx,sr120,hbfp
Diogenes is offline        Reply With Quote Quick reply to this message
Old 04-15-2012, 02:15 AM   #13 (permalink)
A brand of adhesive traditionally used to bond soles to shoes and sold by many hobby shops as well. I buy it at hobbytown usa
Old 04-15-2012, 06:18 AM   #14 (permalink)
I tried using just plain Dap Silicone Sealant and it didn't work. I used it sparingly. And as I said, the next day I was able to just pull off the connector. See the attached image; it's what I used.
I'm going to either pick up an electronic RTV or just use Elmers Glue or Goop and call it a day.
/Hal
Human Verification
