Where is your FBL mounted? - HeliFreak
Old 04-14-2012, 12:04 PM   #1 (permalink)
Default Where is your FBL mounted?
as stated above. I want to mount my ZYX inside the frame on the lower plastic. Looks to be parallel to the boom.
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 12:13 PM   #2 (permalink)
Yes the bottom plate is 90 degrees to the mainshaft and boom however I mount my beastx on top of the boom clamp housing. Easy to get to the buttons on beastx but more importantly if you ever hit hard inverted there is a very high risk that you can drive the mainshaft thru your fbl unit. I also find it much easier to wire up every thing and do a neat all hidden wire job. One of my minis is beastx on top of boom block and sat on the bottom of boom block and the other is an ar7200bx on top of boom block. They both are stretched 6s. I also like the looks of a nice clean open frame under the main.
scott s is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 12:32 PM   #3 (permalink)
I did my Protos 500 like yours. BeastX on boom block, receiver on bottom tray.
On my stretched mini I will have cnc alun servo blocks & lower bearing block, so not much worried about my mainshaft coming through(hopefully). Also, there are no buttons on the ZYX unit that I need to get to and would rather my wires be underneath. Eventually I'll get an AR7200bx and be able to get rid of half the wiring.
William
Old 04-14-2012, 05:43 PM   #4 (permalink)
Have a look at my two on page 18 of the pics thread. They're quite neat, even neater looking than you can get mounting on the boom block imho. I mounted them there for less vibes from the tail. Would like to try to reduce tail vibes and try a boom block mounting on my next one though.
Mini Protos, Voodoo 400, Goblin 500 Sport, Gob 550 x 3, BT650, Thunder T 700, Protos Leggero 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
Old 04-15-2012, 05:29 PM   #5 (permalink)
Yes, I have decided that if I get the thunderpower 6s pro batteries for my stretched mini's I will move the beastx and ar7200bx up under the main with all cnc servo and 3rd bearing blocks do to the lighter weight of the TP batteries. I realized that getting to the pots on these fbl units is easy with a long appropriate screw driver right down thru the top of the heli in front of the swash. Plent of opening in the main gear so it will not be difficult at all. The sat on the beastx heli will stay on the bottom of boom block. Ya it will be neater also!
Old 04-16-2012, 02:52 AM   #6 (permalink)
Yes Scott, you did figure it out. Basically you have to mount the fbl units more forward than I have mine mounted to get good access that way. Looks like I will be able to get to the pots on mine that way also, just with the screwdriver on an angle though. Will want to be one heck of a long skinny one though.
Old 04-16-2012, 03:46 AM   #7 (permalink)
Actually, I mounted those units specifically in that position so the wires coming out the back of the unit are pretty much hidden between the frames. Mounted more forward than that, the wires then become more visible unless anybody's got a trick to hide them in that scenario. Black sleeving is all I can think of. Maybe a piece of black tape over all of the wires.
Old 04-16-2012, 04:56 AM   #8 (permalink)
I also have my Beastx on the boom block - receiver under the mani shaft
Mikej is online now        Reply With Quote Quick reply to this message
Old 04-16-2012, 08:07 AM   #9 (permalink)
Mini Vbar on the boom block. I suspect under the main shaft would have better vibration isolation but it is too hard to plug vbar and CP into it under there.
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L
beans07 is offline        Reply With Quote Quick reply to this message
Old 04-16-2012, 11:42 AM   #10 (permalink)
Well after much carefull thought I have decided that the beastx and ar7200bx on my minis will stay on top of the boom block. There is less wiring showing with everything plugged in with the connector end on the fbl units facing forward and the wires tucked down inbetween the frame and pulley guide holders then a black piece of foam stuffed into the slanted rear portion of the frame and secured with a nice velcro strap. Moving the beastx or ar7200bx to under the main shaft requres it to be pretty forward to get to the pots thru the top of the heli and just to much wiring showing behind it for my likes and still a slight pain to get to the pots and I will not do the braid thing as I did it on my 550 outrages and it is just not worth it. I am sure the heli will balance with the tp 6s 1300 pro batteries anyways. Plus the open area under the main shaft has allowed me to drill a small hole in the bottom plate so I can get to the bolt in the bottom of the main shaft super duper easily. I have never had vibration problems with these mounted on top of the boom blocks so they will stay there!
Old 04-16-2012, 12:08 PM   #11 (permalink)
Tarot ZYX fbl that I'm going to use doesn't have any pots to adjust.
William
Old 04-16-2012, 12:33 PM   #12 (permalink)
No worries then the only thing to watch for is when you lube your belt, after the first flight most access lube ends up on the bottom tray.
SYNERGY 516
Mikado LOGO 550
SMJT is offline        Reply With Quote Quick reply to this message
Old 04-16-2012, 12:44 PM   #13 (permalink)
I use silicone spray on the belt and let it dry before I fly it.
William
Old 12-29-2012, 11:22 PM   #14 (permalink)
Doesn't this mean you have to remove the bx to replace bent booms? It holds the two boom block halves together, right?
matthewcornell is offline        Reply With Quote Quick reply to this message
Old 12-30-2012, 01:11 PM   #15 (permalink)
I don't need to remove my beastx from the boom block to replace the boom.
SYNERGY 516
Mikado LOGO 550
Old 12-30-2012, 02:07 PM   #16 (permalink)
Me neither. Just loosen up the boom block and the tail boom slides right out.
William
Old 01-01-2013, 04:29 PM   #17 (permalink)
I found out in another thread that I had installed the boom backwards so that the slot was at the tail and the hole at the block. Now I understand. Thanks.
Insurance
Human Verification
