DMSS Adapter Cable... Can't Find it - HeliFreak
Old 04-24-2012, 05:55 PM   #1 (permalink)
Default DMSS Adapter Cable... Can't Find it
Hi,
I have serched the wiki at Skookum but I can't find anything about the adapter cable...
Can anyone help?
Steve
Below from Skookum software update...
(requires simple adapter cable, see wiki)
steven0db is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 05:42 PM   #2 (permalink)
Can anyone help?? I searched the manual, wiki and Skookum site and can't find any JR DMSS adapter cable diagrams..
If someone could post a copy here that would be great...
Steve
Old 04-26-2012, 04:40 AM   #3 (permalink)
Default Cable
Hi im looking for it also,your's,Marty.
Atom500,Align510m cyclic,JR 8900 tail,SkooKum 540,HW 80 Platinum,Galaxy&Optipower Batts,shelf queen.
Gaui X3,MKS servo's,Hobbywing 50 amp V3 esc,Vortex VX1e fbl,genace and turnigy batts,Jr 8XG radio and PL6 charger
NEAGRON is offline        Reply With Quote Quick reply to this message
Old 04-27-2012, 03:40 AM   #4 (permalink)
=] SK will supply this at some point, in the meantime the wiki will show how to do a simple home brew version.....
Old 04-27-2012, 03:44 AM   #5 (permalink)
Hi Georgi,where can I finf the instructions to do this,many thank's,Marty.
Old 04-27-2012, 04:09 AM   #6 (permalink)
=] Marty hi, you will need to keep checking the wiki for this addition! if I spot it first I will post it up here!
Old 04-27-2012, 04:43 AM   #7 (permalink)
Why does all the Skookum documentation say it's on their wiki when there is clearly nothing there??? Or is this going down the same track as the GPS unit... I originally purchased the SK720 for that piece of kit and keep hearing it's comming... The end of the world will get here sooner.."....
Old 04-27-2012, 06:13 AM   #8 (permalink)
its not on wiki yet
https://www.helifreak.com/showpost.p...90&postcount=5
JR 11XG DMSS the only way to go , xcell 60 xcell 60 SE
jet ranger xcell 60 mechanics now electric
T rex 700e, beastx V1, Trex 700 F3c V2,
Trex 500 stock ,trex 500 fbl (beastx ) , 500 scale ,Trex 550e, MFA 500,.Micromold Lark
sircol is offline        Reply With Quote Quick reply to this message
Old 04-27-2012, 06:33 AM   #9 (permalink)
Originally Posted by sircol View Post
My point exactly...................
Old 04-28-2012, 03:04 AM   #10 (permalink)
=] http://www.skookumrobotics.com/wiki/...40_Connections
shows 540 but I will need to confirm its the same for the 720......
Old 04-28-2012, 04:33 AM   #11 (permalink)
Default Thank You
Georgi,many thanks,so does that mean we use the normal receiver but dont have to use connecting wires,hope that makes sence,yours,Marty.
Old 04-28-2012, 04:53 AM   #12 (permalink)
=] morning up there! this is for DMSS satellite receivers fitted directly to the SK, the full size receiver will still need all of the usual cables fitted, if that's what we are talking about??!
Old 04-28-2012, 08:10 AM   #13 (permalink)
Done. But then, what? How to make the xg8 and the sk720 work together?
The ESC just keep beeping and no servo movement, etc. Art said that there is no binding. In fact the binding option is greyed out. Not sure what to do next...
Laowai is offline        Reply With Quote Quick reply to this message
Old 04-28-2012, 09:40 AM   #14 (permalink)
=] ok so have you got DMSS selected in the software?,have the sats been bound to a full size receiver?
Old 04-28-2012, 10:03 AM   #15 (permalink)
Yes and yes.
But still no signs of life...
Old 04-28-2012, 10:09 AM   #16 (permalink)
=] ok, there are 3 clear instructions on the link I posted, if you are following the diagram only you may have missed something?
  1. Replace the orange wire with the grey wire
  2. Replace the black wire with the orange wire
  3. Replace the grey wire with the black wire
Old 04-28-2012, 11:32 AM   #17 (permalink)
Georgi:
The instructions on the wiring are pristine clear.
The issue comes when you plug it and and turn on the power. How is it supposed to work?
Because nothing happens either on the TX or on the SK720. No servo movement, no light on the satellite antenna (RA-01T), nothing...
Is there something missing that I should do? Are only some models of the antennas supported?
Old 04-28-2012, 12:08 PM   #18 (permalink)
=] can we first establish the SK is wired correctly and getting power?
Old 04-28-2012, 03:44 PM   #19 (permalink)
Wiring match perfectly your instructions and the picture in the wiki.
The wire works with a Spektrum sat (reversing the wires, of course).
The power part is tricky because unless is linked with a TX the turquoise light is off, but if I keep it plugged for a while it gets slightly warm, so I guess is getting power.
Also, if I plug the sat when the sk720 is on, the sk light goes red for a couple seconds, blinks green and then solid green. But nothing ever happens.
On the other hand, I am not sure (I've never tried) how to control an unbinded receiver with the xg8. Usually, my TX thoroughly ignores any receiver that hasn't been binded or that has no bind plug in... You must use the plug then go to the menu, select binding. The turquoise light in the sat comes alive blinking. The TX shows "Success!". The light goes steady.
With no bind, I wonder how will it work? I turn on the transmitter, then the sk720 and that is it? Hmmm... Kind of scary because at the field a lot of people has XG transmitters and, if someone is fooling around my 700e could start and cut my arm right off.
Old 04-28-2012, 03:56 PM   #20 (permalink)
=] its out of the scope in here, please contact SK tech support for further assistance...
Insurance
Human Verification
