Groni Design Canopys - Page 2 - HeliFreak
Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim > Phoenix Custom Creations
Phoenix Custom Creations Phoenix Flight Sim Custom Models and Fields
Old 05-30-2012, 12:33 PM   #21 (permalink)
Here is the complete Set with Blur
SAB Blades - Tareq Alsaadi Edition
Enjoy
Groni
File Type: zip SAB Blades TareqAlsaadi_SetComplete.zip (157.3 KB, 104 views)
Groni is offline        Reply With Quote Quick reply to this message
Old 06-02-2012, 08:47 PM   #22 (permalink)
Hey Guys,
here is my newest Heli Layout.
Itīs the Goblin 700 Layout on the Henseleit TDR Canopy.
I call it "Goblin TDR - Tareq Alsaadi Edition"
The Package includes the Canopy, Blades and Blur. Just copy all of the files to your Schemes Folder.
Enjoy flying
Groni
Old 06-03-2012, 04:16 AM   #23 (permalink)
Hi Groni,
like your version of the GoblinTDR. The tailboom looks much better then mine but do not like the SAB logo.
Also the line thickness did not match exactly between the logo part and the rest of the tail.
The color of the skids matches much more the rest of the canopy as at mine version.
Thanks for sharing
Winger
Winger69 is offline        Reply With Quote Quick reply to this message
Old 06-03-2012, 08:32 AM   #24 (permalink)
Originally Posted by Winger69 View Post
Hi Groni,
Thanks for sharing
Winger
Thanks, I didnīt realize that you also made a Goblin. It was more of a freaky idea from me, cause Iīm a big Tareq fan. I know him very good, and we talk much. He also allowed me to share my tareq models to the community. And Iīm a real big fan of the Goblin and just wanted to have some goblin-feeling in Phoenix. Hopefully the Goblin will be available in a future release. Also I hope for the Velocity90 and Fusion 50.
Greetz
Groni
Old 06-03-2012, 06:17 PM   #25 (permalink)
Here is the GoblinTDR Tareq Alsaadi Edition in red
Enjoy flying
Groni
Old 06-04-2012, 03:55 AM   #26 (permalink)
Nice Work..
Mini Titan V2, Trex 600LE, Trex 600E Pro DFC, JR XG14 DMSS 2.4GHz, Phoenix RC, Reflex XTR2, AeroFly RC7, RealFlight 7.5, AccuRC.
tj69 is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 08:23 PM   #27 (permalink)
Thanks for all this cool schemes
Flydynamics is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 02:06 PM   #28 (permalink)
Here is the Black Tareq Goblin TDR
Enjoy flying
Groni
Old 06-09-2012, 02:32 AM   #29 (permalink)
deleted
Old 06-14-2012, 11:16 AM   #30 (permalink)
Hey Guys,
here is a little preview of my next Project.
Itīs the Velocity 50 with complete new HD textures for the complete Heli.
Itīs almost done and i need only some finetuning.
Too Bad that the model texture mapping is so bad(servos for example), otherwise it could have been more accurate in texturing. But I guess itīs the best to get.
Tell me what you think.
Greetings
Groni
Old 06-16-2012, 01:23 AM   #31 (permalink)
Deleted
Old 06-16-2012, 07:55 AM   #32 (permalink)
And here is a new Engine Sound for the new Velocity 50.
It also includes a new BladeFlap which sounds very realistic with this sounds.
Just extract the zip to your main phoenix folder.
Just select "Gronimod - Velocity 50"
****File removed cause of an Error*** New Link posted in a new Post.
Enjoy
Groni
Old 06-16-2012, 08:59 AM   #33 (permalink)
Enjoy
Groni
Thanks for the new stuff.
I've posted new sound for this model in the past, see https://www.helifreak.com/showthread.php?t=246486
Your sounds will cause conflicts as the WAV file names are the same
Regarding your HD visuals, did you try to create a 2048x2048 scheme for it? Might deliver a better HD version.
Cheers!
puzom is offline        Reply With Quote Quick reply to this message
Old 06-16-2012, 10:21 AM   #34 (permalink)
Yes, 2048x2048 makes no difference. Phoenix scales it down. I even installed 4096x4096
Oh did you use the same name?? then I will rename them
Thanks for the hint
Old 06-16-2012, 10:26 AM   #35 (permalink)
deleted
Old 06-16-2012, 10:31 AM   #36 (permalink)
So 2048x2048 is not sharper when the model is closer to you? Should be the case.
Perhaps the difference is better seen with scale models.
Old 06-16-2012, 10:58 AM   #37 (permalink)
Nope. I did a very close zoom on the Editor and changed between the resolutions. Not even a small difference. I always wondered why the textures in the editor was nothing like 4096x4096 . I guess the models have a max texture size to map. If the Texture is bigger, it will be scaled down. But anyway looks much better now in compare with the original Textures
Old 06-16-2012, 11:49 AM   #38 (permalink)
Not sure if there is a difference between Creator and the sim rendering. Did you try it inside the sim? Creator is pretty old compared to PhoenixRC v4.
Old 06-17-2012, 03:57 AM   #39 (permalink)
i tried both. If there is any differnence, then itīs so small that it is almost not noticable. The only difference is the loading time. I tried 1024x1024, 2048x2048, 4096x4096. The grafic quality was almost the same, but the loading time gets longer.
The only visible quality difference are the blades, if you are using higher resolutions.
Old 06-17-2012, 04:58 AM   #40 (permalink)
Ok thanks for testing.
Perhaps you should make a plastic see-through canopy using Alpha. This way all the HD parts can be seen
Cheers!
Human Verification
