Old 05-03-2012, 10:49 AM   #1 (permalink)
Default Pitch & Throttle Curves Explained
Throttle and pitch are controlled separately, But they are controlled buy the throttle stick at the same time!
2 channels driven by the throttle stick.
Throttle and collective / pitch control.
In the pitch curve section of your TX.
This example is a 3D pitch curve!
0 is full negative pitch. Lowest throttle stick position
25% is 1/2 negative pitch 1 quarter throttle stick position
50% is no pitch at all the blades are flat. This is mid stick position of throttle stick
75% is 1/2 positive pitch three quarter throttle stick position.
100% is full positive pitch. Highest throttle stick position
This example has no negative pitch. So the blades never go into reverse below mid stick.
50, 50, 50, 75, 100 has no negative pitch below mid stick the blades will be flat.
Above mid stick position the blades increase positive pitch.
50,50,50,50,50 has no pitch at all positive or negative the blades stay flat from minimum throttle stick position through full throttle position.
In this example, You will notice
L = 50% zero pitch Flat Blades
2 = 65% The blades begin positive pitch orientation much earlier, at or before throttle position instead of mid stick
3=70% Very gradual increse in pitch
4=75% Very gradual increse in pitch
H=80% Very gradual increse in pitch
This is a very soft feeling pitch curve sutable for newcomers to MCPX or normal mode fun flying
indoors or out as the pitch comes on very early and increases very slowly over of the collective stick rather than just the top
This is a suitable throttle curve for the above pitch curve
L = 0
2=40
3=60
4=80
H=100
Pitch Curve
L=50%
2=65
3=70%
4=75%
H=80%
How throttle curve works
You can program your DX6i so that the throttle operates in any manner you like.
Throttle Curve Menu
L is lowest throttle stick position motor off.
25% is throttle stick position
50% is throttle stick position
75% is throttle stick position
H is full throttle stick position
You can assign any power setting to any throttle stick position.
Normal mode standard MCPX throttle curve.
L is lowest throttle stick position 0
25% is throttle stick position 40% power
50% is throttle stick position 60% power
75% is throttle stick position 80% power
H is full throttle stick position 100% power
You can also do this.
In this throttle curve in normal mode in the throttle stick minimum position the motor is off.
But at the 25% position the throttle goes to 100% power and stays 100% up to full stick position.
25% is throttle stick position 100% power
50% is throttle stick position 100% power
75% is throttle stick position 100% power
Use a pitch curve like this in normal mode with the above throttle curve 50, 50, 60, 70, 80
This pitch curve has no negative pitch below mid stick the blades will be flat. Above mid stick position the blades increase positive pitch. You control altitude using the pitch of the blades with the throttle / collective stick.
Stunt mode / Idle up
Stunt mode settings in the pitch curve menu and in the throttle curve menu operate when the idle up switch on the radio is in the on position.
In stunt or idle up mode the throttle curve is set at any given setting 100, 100 100, 100, 100
No matter where the throttle stick is when in idle up the motor will run at the assigned power setting in this case 100% all the time.
If you set the stunt mode power 80 80 80 80 80 in the stunt position throttle curve of the DX6i when you turn on the idle up switch the motor will run 80% no matter where the throttle stick position!
You control only the pitch of the blades with the throttle / collective stick.
An example of a 3D throttle and pitch curve would look like this.
H is full positive pitch. Highest throttle stick position
If the tail is blowing out on hard climb or pitch pumps. Go into the DX6i Travel adjust menu and lower the pitch setting from 75 by 2% at a time until the tail holds! Positive and negative!
Hold in the throttle curve menu of your DX6i
Set this 0 so when you hit the hold switch you want the power cut off to the helicopter motor.
No matter where the throttle stick position!
In the pitch curve menu of your DX6i I set Hold at 50 50 50 50 50 so no matter where your
throttle stick the blades go flat zero pitch. When the hold switch is activated.
This helps not break parts in a crash. Others set 0/25/50/75/100.
Soft start feture on MCPX.
For those not formilier with soft start. You can turn on I/U when the helicopter is sitting on the ground.
The tail rotor will start then the main motor will slowly spool up to 100%.
Turn on Dx6i
Plug in helicopter
Let them bind.
Switch on Idle up switch, then move throttle stick to mid stick position so the blades are flat for spool up.
After flying move throttle stick to lowest positition befor switching off Idle Up switch.
You can also switch between idle up mode and normal mode in flight.
Ron
Petrolia Ontario Canada.
Electric, MCPX-BL,450X, Trex 550E Nitro Hirobo SCEADU Evolution 50
Imzzaudae is online now        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:05 AM   #2 (permalink)
On the dx6i TH setting is in %. You need to put it at 10% or blades could spin when TH is turned off and throttle stick is still at lowest pos. And in TH you should keep your pitch at 0 25 50 75 100 this way you can still control your pitch when TH is on.
Sent from my SGH-T959V using Tapatalk 2
rleary360 is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:13 AM   #3 (permalink)
Default Thanks
I had forgotten the 10% on the throttle hold switch on MCPX. I did go back and correct the error in the above post.
Thanks for pointing it out ! I hate giving bad information.
Ron
Ron
Old 05-03-2012, 11:14 AM   #4 (permalink)
Just a little tip from Kevin at KBDD, since we will not be auto-ing our MCPX we should turn our TH pitch to FLAT Zero to eliminate boom strikes that are so damaging to blades on the trailing edge. If a blade is - pitch and folds, Boom strike, not advisable on bigger birds because we auto them but for an MCPX this is a great tip!
Danny H.
"SUPER-STROKER" is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:16 AM   #5 (permalink)
Danny H.
Lol my bad! Didnt notice the forum
Old 05-03-2012, 11:22 AM   #6 (permalink)
Ron
Im glad you put this up cuz im going to buy one tomoro
Old 05-03-2012, 11:26 AM   #7 (permalink)
Default Funny thing
I have been trying to figure out why my MCPX blades are cracked on the trailing edge. I'm going to have to smack my nephew and tell him to stop landing so hard!
Never thought of it!
What an MCPX?
Ron
Old 05-03-2012, 11:28 AM   #8 (permalink)
I'm confused about the 10% in T/H, why wouldn't you want it at 0%?
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:30 AM   #9 (permalink)
Ron
Can you please explain the 10% on Throttle Hold stuff ? I have never come across this before and cannot locate it in the manual. What are you suggesting is set to 10% ?
UKHeliBob is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:38 AM   #10 (permalink)
Default OK
I just looked in both manuals, It's the B450 that requires 10% setting in throttle hold menu not the MCPX, I should have looked before making the correction.
Sorry guys I will go back and correct this and will be more carful in the future when posting.
I'm supposed to know what I'm talking about here.
Ron
Old 05-03-2012, 12:04 PM   #11 (permalink)
To be fair, it was not you that made the 10% suggestion.
Old 05-03-2012, 12:17 PM   #12 (permalink)
I have 450 electronics in my 400, I'm going to have to do some research.
I don't have my radio here but I'm pretty sure I have mine set to 0% on T/H, might need to change it to 10%.
My guess is it's suggested for auto landing.
Old 05-03-2012, 05:36 PM   #13 (permalink)
I coulda used a post like this about 3 months back.
I vote sticky!
Draganflyer IV - mCX - mSR X - mCPX v2 - DX8 - iCharger 206B
Metal is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 06:06 PM   #14 (permalink)
Hey Ron just listen to yourself. When it comes to setup and radio advice with the MCPX your word is golden. I direct to your posts when people have questions. I wish I had your info when I started. I did not and I have the parts count to prove it. I fooled with your setups all last winter and literally learned to fly my heli. I am so ready for the 130 and 300. I really do not have intrest in a 450 at this time. My yard allows easy flight for smaller craft so be it. Rock on my friend. Keep up the good work.
stablehover is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 08:55 PM   #15 (permalink)
I have been struggling to grasp this concept. This thread just made it click in my head. Great work. THANK YOU!
DX6i MQX mCPX V1
supermarvin76 is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:44 PM   #16 (permalink)
Default Thank you all
Thank you all for your understanding and feedback is always welcome.
It is sure nice to turn on my computer and find that my posts actually do help people.
You guys are all great!
Stablehover: I also learned at the school of many broken parts. Thanks for the thumbs up!
I'm also looking forward to the 130X I don't think I will bother with the 300 this year maybe next
year. Although I do enjoy flying my B450 like many others I have found myself leaning towards MCPX.
Great school yard heli.
Ron
Ron
Old 05-09-2012, 10:13 PM   #17 (permalink)
I'm getting into MCPx flying too.. great and helpful post!!
greyhoundfan is offline        Reply With Quote Quick reply to this message
Old 05-13-2012, 11:49 PM   #18 (permalink)
Makes sense now. Thank you.
budweisr33 is offline        Reply With Quote Quick reply to this message
Old 05-19-2012, 03:12 PM   #19 (permalink)
I finaly got one....i binded to dx6i but i have no throttle. What all settings do ya use?
Old 05-19-2012, 03:51 PM   #20 (permalink)
Check out this link. It will get ya setup.
https://www.helifreak.com/showthread...58#post3854858
Blade 450 3D, Blade 120SR, Blade MQX, Blade MCX2, Blade Scout, Heli-Max 1sq Quad, Griffin Heli, Traxxas QR-1, DX6I DSMX w/ blue backlighting.
Mini Tmaxx is offline        Reply With Quote Quick reply to this message
