Main shaft / autorotation gear play - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-06-2012, 03:03 AM   #1 (permalink)
Default Main shaft / autorotation gear play
I noticed I have some play in the bolt holding the autorotation gear. As a result I can rotate the head a bit while holding the gears still. There is no up/down play. I have two main shafts, both the same. The bolt is brand new. Gears are fairly new and not damaged.
Have you noticed the same, should I order new set of parts and hope they fit better? Should I tighten the bolt even more? It is already quite tight and I'm afraid I break OWB. Or is this something completely different?
Dead Meat is offline        Reply With Quote Quick reply to this message
Old 05-06-2012, 04:36 AM   #2 (permalink)
I had the same problem. Turns out the bolt was the wrong size change of bolt later and all is well
Martin353 is offline        Reply With Quote Quick reply to this message
Old 05-06-2012, 05:02 AM   #3 (permalink)
Thanks. The bolt is the standard one from Align. I understand you got it fixed using such as well, i.e. not using oversized bolt?
Old 05-06-2012, 05:41 AM   #4 (permalink)
both my helis are like this....if you tighten that lower bolt too much it can mis-shape the owb collar...just nip it up and use some locktite to keep it there
chris
warp 360-ds92-ds525m-polaris bec-beastx-edge 50 lite-yummy
Synergy E5-castle 100 ice-bec pro-beastx.
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote Quick reply to this message
Old 05-06-2012, 07:25 AM   #5 (permalink)
My bolt was an align one too. The replacement was also align. Go figure lol but the replacement worked. I wonder if there are 2 sizes like a v1 and v2 that they haven't told us about yet
Old 05-06-2012, 08:32 AM   #6 (permalink)
Smile
So it's not just me then??
Gents, could you be so kind as to measure the bolt you had the slop with and the new bolt that allows minimal play, and post here?
I thought there was a massive amount of play in my auto gear train, but after going through the lot it's only that bolt causing the problem.
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote Quick reply to this message
Old 05-06-2012, 09:27 AM   #7 (permalink)
I'll see if I have it but I tend to be a little OCD with bolts and throw them after they have been used (ESP if they caused a problem)
Old 05-16-2012, 07:10 AM   #8 (permalink)
Smile
Hey Martin, did you end up finding the old bolt?
If not, what was the Align part number for that bolt if you have it please.
JR X9503.
Old 05-16-2012, 07:13 AM   #9 (permalink)
Hi bud. Sry I've not found it yet I'll have a look tonight for the part number
Old 05-16-2012, 12:04 PM   #10 (permalink)
What u need is align part H60158 this gives you 2 m3x22 bolts in the pack
Old 05-16-2012, 12:36 PM   #11 (permalink)
Smile
Thanks mate. I'll have to order some.
JR X9503.
Old 05-16-2012, 02:19 PM   #12 (permalink)
No probs
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
