Old 06-29-2010, 05:28 AM   #581 (permalink)
Team Taco VP
Originally Posted by Helijamie View Post
Bob
It may be futile but do you know of any way I can actually communicate with Align in some meaningful way? That step takes me a couple hours.
Jamie
Jamie, I have tried...... It is futile
THIS my friend is why I put this in my video to begin with and I expected it not to be a problem. In fact I see people with VIBES all the time and just backing off the boom a little solves it! This is true on the 500 and 700 too
Thanks for measuring today's heli and letting us all know that it is a must! When I do my vids they get "dated" if you know what I mean and thus I expect changes. Well I guess this one has not changed.....
Bob
Old 06-30-2010, 09:19 AM   #582 (permalink)
thanks mate. this gonna help me alot. cheers
shanvick is offline        Reply With Quote Quick reply to this message
Old 07-25-2010, 02:30 PM   #583 (permalink)
Bob,
I've got a 2nd hand 600 Nitro Pro. There's a subtle noise comming from it (sounds like dry metal being cut on a lathe - a bit screachy).
I've replace the clutch tower in its entirity - There's a brand new OS55 on there and I've just replaced the main bearings but the noise is still there. Re done the tail and gear as per your videos.
In the field today I noticed that on other people's 600 the top gear of the one way set moves quite freely by hand. Mine moves bit is somewhat tighter.
If I loosen the bolt on the bottom cog it gets much better.
I think there's something wrong here - do you have any videos detailing the installation of the one way on the main shaft ??
mslater is offline        Reply With Quote Quick reply to this message
Old 07-25-2010, 03:54 PM   #584 (permalink)
Team Taco VP
My build videos show the one way but it is like all Trex helis. A sleeve goes in the ones way and that sleeve is what bolts to the main shaft. Your one way could be rusted or worn out possibly. It's easy to change. Use the right sized sockets and just tap it out of the main gear hub. Make sure to note orientation and tap the new one in the same way.
Bob
Old 07-29-2010, 02:23 PM   #585 (permalink)
Smile
Thanks Bob.
I've fixed the problem, the bearing was warped although it looked perfect it wasn't.
The give away is that the top gear should rotate freely by hand without the rotors moving.
New bearing and all perfect.
Old 11-25-2010, 02:27 AM   #586 (permalink)
Default BOB
Hi Bob great vids
I Have been out of the RC world for more than 15 years when i flew a Kalt cyclone and a kalt space barron 30
I moved to Thailand from the Uk and have found a great Rc club near Bangkok i already decided on the 600 Nitro as thats what is more available here i purchased the 3G flybarless kit with an OS 55 Hyper and align 50 pipe this kit comes with all align electrics just need 1 servo (throttle) and tx and rx i went for the Aurora 9 which i see you also do vids on i started to build it before seeing your vids but they have answerd some questions already do you have any recomendations with the above set up and any help with setting up the tx would be great i am sorta on my own as not many people speak english here thanks
Loz
loz944 is offline        Reply With Quote Quick reply to this message
Old 11-25-2010, 10:00 AM   #587 (permalink)
Team Taco VP
I have not done anything on the 3G yet and sorry to say the Aurora 9 video are not yet complete. My next heli build I will show the aurora 9 setting up a heli. Just follow the principles showing setup and try to apply them using the aurora 9. I recommend watching some of my general 101 videos in here.
https://www.helifreak.com/showthread.php?t=41692
Bob
Old 11-25-2010, 05:46 PM   #588 (permalink)
Bob
Wow, 3g already been out for a while you should do a video soon before it get obsolete LOL. Happy Thanks Giving.
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote Quick reply to this message
Old 11-26-2010, 04:51 PM   #589 (permalink)
thank you for the quick reply i will look forward to your vids guess i will have to learn Thai pretty damn fast lol
Old 11-28-2010, 12:07 PM   #590 (permalink)
Default Reciever hookup
How do you hookup an R617FS reciever when you need all 7 ports for components? I have no port for the regulator to power it up. Can I piggyback somehow?
foolforspeed is offline        Reply With Quote Quick reply to this message
Old 11-28-2010, 04:52 PM   #591 (permalink)
You could use a Y connector on any one of the channels and plug the regulator into that. If your gyro gain plug only has the signal wire, you could fit the +/- wires from the reg. into it.
John Barta
Michigan Whirlybirds Heli Club
http://www.michiganwhirlybirds.com
j bomb is offline        Reply With Quote Quick reply to this message
Old 12-12-2010, 10:43 PM   #592 (permalink)
Great vids for learning they helped me out alot. Just wondering if there is any vids on tuning gas engines or where I could find one? Thanks for your help.
cmaheden is offline        Reply With Quote Quick reply to this message
Old 12-24-2010, 05:00 AM   #593 (permalink)
Go here http://www.smacktalkrc.com/
First episode
Oh, you probebly thoght of gasolin burning motors, not nitro.... My bad
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
CoolKD is offline        Reply With Quote Quick reply to this message
Old 01-05-2011, 09:41 AM   #594 (permalink)
Hi Bob,
Like so many others here, I have just completed a TREX 600 N Pro and I can say your videos were invaluable. Although years ago I built some heli's a Schluter JR 50 and a TT Raptor 50, I didn't understand why something was done, or how to set things up better mechanically.
Your technique is great, comes across well and your experience clearly shows through why some steps are better done in non sequence..... as I remembered having fitted the engine with the stiffener plate in, whilst yours was done without!!!!
Anyhow, mine is nearly ready to fly, set ups are being completed as I write and I have every confidence which has been enhanced by seeing your videos, so many thanks indeed.
I'll let you know how she maidens!
Gaz
gazzer1uk is offline        Reply With Quote Quick reply to this message
Old 01-20-2011, 01:40 PM   #595 (permalink)
Hi Bob
Just wanted to say thanks for these great videos, I just finished building a T-Rex 600N 3G, it has not flown yet, but I'm sure it will be a great success.
Your dedication is something for all of us to look up to.
xp
xp190 is offline        Reply With Quote Quick reply to this message
Old 03-14-2011, 11:12 PM   #596 (permalink)
wandering if i could ask you a few questions on the trex 600 nitro set up
SIMPLE DZINE is offline        Reply With Quote Quick reply to this message
Old 03-15-2011, 02:22 PM   #597 (permalink)
Team Taco VP
It would be best to post questions in the actual Trex600 Nitro forum here.
https://www.helifreak.com/forumdisplay.php?f=78
Bopb
Old 03-29-2011, 12:14 AM   #598 (permalink)
Default gy701
Bob thanks for the video it help me a lot, i have to re built my trex 600n from head to skid.
could you show me a video on how to set-up my gy701 to dx7?
tnx
jogarce
jogarce is offline        Reply With Quote Quick reply to this message
Old 03-29-2011, 08:59 AM   #599 (permalink)
Team Taco VP
I do not have a 701 sorry. But I would bet the 701 sets up just like the 601/611 and my videos on that gyro should help you out.
Bob
Old 03-29-2011, 11:34 PM   #600 (permalink)
thanks bob
