Old 09-16-2011, 10:51 AM   #621 (permalink)
Team Taco VP
You should post these kinds of questions in the forum for the heli. The Trex Nitro forum is here:
https://www.helifreak.com/forumdisplay.php?f=78
However. First it is odd you have a Nitro with the old plastic tail case. I do not recall Align ever making a Nitro version with that tail case?
But for that old plastic tail case, the pitch slider control arm is VERY close to the case. It will rub the case if you forget to put in the spacer washer between the bell crank and the arm the bell crank pivots on. It was common back then users would either forget this spacer washer or put the wrong washer there (a thinner one). If the arm is rubbing and the thick spacer washer is there then usually it was due to a warped plastic arm.
Bob
Old 01-08-2012, 06:13 AM   #622 (permalink)
Red face Align GOV set up video
Hi Bob.
Thankyou for your vids. Excelent.
I need some help in this set up. Do you have a video or link to see how to set up these Align Gov in the T-Rex600NFBL with the 10C Futaba radio + 8 Channel Fasst Receiver?.
Thank you.
Ger
Ger2010 is offline        Reply With Quote Quick reply to this message
Old 01-13-2012, 03:56 AM   #623 (permalink)
Bob, do you have video of GY701 using DX7 transmitter?
jogarce
ginnethone is offline        Reply With Quote Quick reply to this message
Old 01-14-2012, 11:11 AM   #624 (permalink)
Team Taco VP
See my Trex 500 nitro conversion videos and I show how to setup the Align gov. It's not with a Futaba radio thought but the principles are the same.
I have not done a GY701 but John has:
https://www.helifreak.com/showthread.php?t=252108
Bob
Old 01-22-2012, 02:23 PM   #625 (permalink)
helps out a lot bob thanks
chase boy 301 is offline        Reply With Quote Quick reply to this message
Old 01-22-2012, 02:29 PM   #626 (permalink)
excellent job Bob helps out a lot for my first time with my new hoobby
Old 02-13-2012, 04:36 PM   #627 (permalink)
On the GV1 setup you said it could be adjusted in the adj. travel...I can do it when I am in the programming part, but it does not seem to change if I am flying it. Is that normal or am I doing something wrong.
I have one other question.....I also have a .90 size Raptor.....where should the RPM's be for the three flight modes? I set it up like the .50, but that seems to be insanely too much RPM's.
Where does the white go when the snow melts?
cliff600 is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 12:27 AM   #628 (permalink)
hey bob, Im have a little trouble setting up my cy atg on my 9303, do you have by chance a tutorial on how you would set it up on a 9303.
lazsyss350 is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 07:29 PM   #629 (permalink)
Default raptor 30 or t rex 600 v2 nitro
hi bob or any one please reply back i can fly a rc heli but i did not assemble my raptor 30 now i have bought a new raptor 30 to assemble which i managed to assemble fine i really like the look of a t rex 600 v2 nitro limited edition would you say any one that can assemble a raptor 30 will not have problems assembling a t rex 600 because the Manuel makes it look hard to assemble is there any better manuals out there or would you recomend i just buy all quick uk parts to upgrade the raptor to anodised parts and forget about the t rex
jase88 is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 02:47 PM   #630 (permalink)
Default awesome
great build videos thanks a million
smallmand is offline        Reply With Quote Quick reply to this message
Old 07-01-2013, 05:22 AM   #631 (permalink)
Thank you very much. This videos help me many times.
aleranol is offline        Reply With Quote Quick reply to this message
Old 07-07-2013, 12:31 AM   #632 (permalink)
Hello,
I took apart the tail grips from my old Trex 600 tonight, for maintenance purposes. I had put this heli together some time back, and haven't taken off the tail for couple of years.
Right away I noticed that I need to put in some lithium grease on the thrust bearings.
Questions: How many radial bearings does these tails have? I only have one (sitting right next to the center hub), and then the radial (next to the bolt). Aren't there supposed to be at least two sets of radial bearings, and then the thrust bearing?
Thank you in advance for your feedback ... cheers
karma4u is offline        Reply With Quote Quick reply to this message
Old 01-01-2014, 11:21 PM   #633 (permalink)
Exclamation
it has been years since i built my last trex 600N i recall it being simple watching these step by step build videos by finless helping and expelling a lot and seting up the old DX7
well i have got the bug again and i picked up the new DX9 and decided to go with the 600DFC and decided to come back on here to tweak and look for clean setup videos. well to my surprise Nothing
im shocked. Did the heli world fall off. what happond to finless and his priceless tips and setup videos. (Hope we didn't lose a Great)
heli's have improved alot in the past 5 years i expected the same for the videos
i have found some and one that is half pare to the God of heli's (finless) what happened and can someone point me to the right direction
super cp pro, e-flight remote
hdx 300,t-rex 450 se, 600N PRO, JR VIBE 50,HeliMax ssl100, Trex 600N DFC
DX7, DX9
philliefiller is offline        Reply With Quote Quick reply to this message
Old 01-06-2014, 05:55 PM   #634 (permalink)
Team Taco VP
I took a break for a while... 2000 videos or so and I needed one
I expect to pick back up this year but I have some learning to do too!
Bob
Old 01-07-2014, 03:26 AM   #635 (permalink)
Bob
WELCOME BACK Bob !!!
Mirco
gelatmi1 is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 10:18 PM   #636 (permalink)
yes welcome back may I start a list I have the new 600DFC super combo, picked up the DX9 and got the spectrum gps telemetry system, reading the 3GX I'm thinking they can work together for auto pilot I'm hoping. is the 3GX flybarless system a receiver also, or just everything else, and you plug servos into it instead of the receiver and bus out telemetry.
Edit, or will i have to buy the dji naza h
DX7, DX9
Old 01-24-2014, 03:20 PM   #637 (permalink)
Default Trex 600N DFC 3Gx Setup Spektrum & Telemetry
Used old videos to help refresh mind and a guide funny most the mods align has took care of them made the parts better and now include a lot of CNC parts instead of the old kits with the plastics heres what i need to know i couldn't make a New thread about the 600N DFC kit so just continued it here in the old 600 vids
Either I'm over looking it or its not there but i can not find any info on Telemetry or a Spektrum setup. here is what i have, let me know what i need to do
TRex 600N DFC
Spektrum DX9
3GX
Spektrum TM1000 Telemetry system
Spektrum GPS Sensor
JR RA01T DMSS 2.4GHz Telemetry Module Full Range with Chip Antenna
( Will this JR DMSS Remote Receiver Bind with the Spectrum and Dx9 setup ok?)
after I bought it I was reading somewhere it is not good to mix brands! but figured before it was better to have the full range remote antenna with telemetry instead of the reg remote antenna.
Ok to the 3Gx system will the Spectrum Gps sensor work with the 3Gx it says that 3gx can auto pilot and return home.
This is what it says
(●Support with APS gyro system and bring up more functions for your helicopter. With the APS gyro, the helicopter will have the ability to self stabilize, hold position as well as altitude, and even autonomous way point flights as well as return home.)
Or is the APS Gyro something else you have to buy?
back to the receiver and 3GX
if the JR remote Antenna will work, will i need to have a Receiver hooked to the 3Gx with the Telemetry system with remote antennas, Or is it ok to run the 3Gx as the receiver and Telemetry as Second antenna and run the JR remote antenna?
DX7, DX9
Old 07-08-2014, 08:44 PM   #638 (permalink)
These videos are still relevant!!! I am getting ready to build an untouched Trex 600 Nitro Pro kit as pictured in the videos. Should be a great project. Flybars live!!!
TREX 500 GF, TREX 600 CF, TREX 600E PRO, TREX 600 NITRO PRO
SAB GOBLIN 570 SPORT
justabigham is offline        Reply With Quote Quick reply to this message
Old 02-22-2016, 02:39 PM   #639 (permalink)
Default Align APS Gyro
Aloha, I know this is and old thread. First off I can't figure out how to start a new thread. So let me begin by saying please excuse me.
I am wandering if anyone actually uses the Align APS system? I can't find any recent posts on it anywhere. Also do they still make it? As well as is it junk?
Mahalo, in advance
Bluemoose is offline        Reply With Quote Quick reply to this message
Old 05-22-2016, 06:35 AM   #640 (permalink)
People still fly flybared helis? I took a break since 2014 so I miss out how the heli world is going? Thanks guys!
AceTheAxe is offline        Reply With Quote Quick reply to this message
