Like Tree1Likes
Old 01-29-2009, 01:36 PM   #201 (permalink)
Originally Posted by shaggybirdman View Post
yup. practice is the key. has your learning curve started to flatten out yet? mine has, but when i feel comfortable enough tail in i'll have to start all over with side then nose in. i'm going to paint 1 skid a bright color so it helps me with orientation when i start side, or nose in.
good idea
Jeremy Strickland
Evolution USA Team Pilot, Optipower USA Team pilot, Castle Creations Team pilot.
Questions? Send me a PM!
haha101 is offline        Reply With Quote Quick reply to this message
Old 01-29-2009, 01:41 PM   #202 (permalink)
BUT, you send me a dying engine and I'll show film on being too rich and how to blow it up by being too lean for all to see.
RCSavager is offline        Reply With Quote Quick reply to this message
Old 02-08-2009, 12:37 AM   #203 (permalink)
Is it normal when you're soldering on a Dean's connector as in the 101 video (pre tinning and reflowing) to have the metal connector melt the plastic just enough to go crooked? This happend on both of my tips on the male connector and I had to bend them to make it able to fit. It's really a shame because it's on a nice 55amp ESC. Should I desolder them and do it again with more support for a better connection? It still works, but it's hard to connect/disconnect. Thanks for all the vids though, it's been a huge help =D Stay up!
still charging is offline        Reply With Quote Quick reply to this message
Old 02-08-2009, 01:52 AM   #204 (permalink)
I have had that happen before. You probably don't want to hear this, but it's probably a good idea to get that connector off there and throw it in the trash. If you have more Dean's use it, if not order more. You want to take your time and make sure you have a good solid connection. I've found that if you are heating up the metal connector so much it is melting the plastic then there is something flawed with you technique. You may be holding the soldering iron to the metal prong for too long, you might have a dirty solder tip not allowing for a good transfer of heat to get the solder to melt, but enough for the plastic. My suggestion would be to practice a few times on some spare wire and connectors until you get the hang of it. Of course don't forget to slide the shrink tubing on the wire before you start soldering
efrsysop is offline        Reply With Quote Quick reply to this message
Old 02-08-2009, 05:55 AM   #205 (permalink)
pqr
Default Me Too on melting Deans
The melting deans plug - Is it better to use one of the solder irons like a 150W Weller type and heat quickly, or is it a more delicate process like heat up the metal furthest away from the plastic until the solder runs?
All clues much apprecated, like is there a rule of thumb on soldering iron wattage / item to be soldered?
Regards, Phil
All the Gear - No idea!
Trex 700N, 600N, 600E, 500E, 450 Pro, 450GF, 250
HK 250, 450, 500 for Spares
Blade MSR
pqr is offline        Reply With Quote Quick reply to this message
Old 02-08-2009, 11:45 AM   #206 (permalink)
Team Taco VP
Its not a delicate balance but is a balance. Too cold a iron and you have to hold it on there too long to get the solder to melt on both the wire and the terminal thus you can melt the connector or get a crappy solder joint. Too hot an iron and no matter how quick you are you will melt the connector.
A tip you can do is put the connectors together when soldering. This will help pull some heat out faster and keep the terminals lined up should you slightly get the connector too hot.
Bob
Old 02-08-2009, 02:20 PM   #207 (permalink)
Default EZ Solder Coupler for Dean connector
Guys,
I bought these from Heliproz. I've not tried it yet but it looks like an excellent idea. You basically convert the connector to a bullet type soldering point
Outrage Velocity 50 FBL - OS55 - Align DS610, BeastX + DS650, MGP, Perfect Regulators Igniter Push Button Glow and Flighttech 8A regulator
T-Rex 600NP- OS50 - Align DS620, Spartan + DS650, MGP, SwitchGlo and Ely.Q reg
T-Rex 450SE V2 with CC45 esc
crash-alot is offline        Reply With Quote Quick reply to this message
Old 02-09-2009, 02:45 AM   #208 (permalink)
pqr
Default Looks Good
Might give them a try, plus have more practice soldering as Bob and other guys suggest
http://www.heliproz.com/prodinfo.asp?number=745357
Blade MSR
Old 02-17-2009, 01:58 PM   #209 (permalink)
Heli-X is no longer for free. they ask a contribution for development.
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV
Quad 250 : Openpilot CC3D
chopstick is offline        Reply With Quote Quick reply to this message
Old 02-17-2009, 08:24 PM   #210 (permalink)
Thanks chopstick, I have updated the info in the first post of this thread.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 02-19-2009, 11:11 PM   #211 (permalink)
Default Video problems
These videos are awesome for us newbies! Unfortunately I've been having all kinds of problems with them. I've tried IE in XP, and Safari and Firefox on MAC OS X and have the exact same problems. If I stream them they start up and appear to be fine, but then fail at random times into the video. If I download them they'll play for awhile and then I get a pop-up that the file is corrupt. I've verified that the entire file is in fact getting downloaded.
Is this something I'm doing? It's failing on three different systems that I've tried.
Any advice would be appreciated. I need my Finless vids!
cruiser_kid is offline        Reply With Quote Quick reply to this message
Old 02-19-2009, 11:30 PM   #212 (permalink)
Default more info
Tried on a fourth system (another MAC using Safari), and got almost all the way through the dual rates video in streaming mode when I lost sounds. Video kept going but I couldn't get any sounds, even if I went back to earlier in the video. There's definitely something buggy going on with the video server.
Old 02-19-2009, 11:35 PM   #213 (permalink)
just tried the ccpm 1 vid, and it streamed just fine. try a pc instead.
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote Quick reply to this message
Old 02-20-2009, 01:03 AM   #214 (permalink)
Some of them work fine (CCPM vid 1 being one), and others do not. On of my systems is a PC ("IE on XP"), but the problems are consistent from machine to machine.
Old 02-20-2009, 01:34 AM   #215 (permalink)
Are these all at the same location using the same internet connection? Could have something to do with it. I never stream, always download. I have never had any problems downloading, or any corrupt files or anything. It does prevent me however from downloading more than two at a time. But as an IT Pro, I get that.
Old 02-27-2009, 12:17 AM   #216 (permalink)
Nice work - Thanks for the well organized set-up!!
Brian
Brian (ViperDraggs) Jones
Every Person is my Teacher So I May Learn From Them
Thanks to all the Military People.
ViperDrags44 is offline        Reply With Quote Quick reply to this message
Old 03-02-2009, 04:29 PM   #217 (permalink)
Finless, your video on servo 101 was great. Do you know where I can find plastic gear sets for exceed 8g servos?
Thank you for all your video information... very helpful.
crashlanding is offline        Reply With Quote Quick reply to this message
Old 03-02-2009, 07:40 PM   #218 (permalink)
i've had 8 of the finless videos downloading at ounce. bandwidth got split between them, but 8 at 1 time.
Old 03-04-2009, 01:37 AM   #219 (permalink)
Really? Anyone else? I can't download more than 2 at once, as soon as the 2nd download is done it'll start the third. I figured this was by design as I've designed some of my clients sites to operate this way for bandwidth purposes.
Old 03-04-2009, 02:07 PM   #220 (permalink)
Nope, 2 at once has been my limit also.
DA54 is offline        Reply With Quote Quick reply to this message
