Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
09-23-2012, 09:56 AM | #101 (permalink) |
I have posted a this question in a couple threads but after researching a bit I see it may be gyro related. When I power up the heli the tail servo does not initialize, after unplugging and plugging it back it it works fine I am running a HB-D-9257 servo from Fusonic, any ideas of my settings being wrong?
Copterx 450 Pro FBL: 3800kv, HB-800
Current: 130x, CopterX 450 Pro FBL*Build in Progress* Gone With the Wind: MCPx, E-razor 450, Nine Eagle Bravo SX |
09-23-2012, 05:09 PM | #102 (permalink) |
Well I did a couple more flights and the tail initialized correctly bob times and got a couple good flights in. Being this is my first Fbl gyro setup not sure where to start for adjustments.
Things I noticed and not sure how to iron out, on hard pitch pumps the tail drifts right and did a couple flips and the tail blew out on each, also had slight jitters while hovering,all stock setting atm. Any pointers would be appreciated Copterx 450 Pro FBL: 3800kv, HB-800
09-25-2012, 09:49 AM | #103 (permalink) |
Make sure you're not killing head speed when flipping. No gyro can hold the tail if there isn't enough head speed.
Keep adding gain to the tail until it wags and then back it off a few. Make sure it doesn't wag in FFF or when coming out of FF turns. You'll have to lower the gain if it does.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 - |
09-25-2012, 12:28 PM | #104 (permalink) |
Also, make sure you have enough pitch on the blades. You have a copterx, and I had to do the following to my exi.
It would blow the tail on pitch pumps because I didn't mechanically have enough travel to get enough pitch on the tail. I never had an issue on my old EXI kit, but the newer "Sport V2" tail for some reason didn't have the same travel. So for me I had to cut the bellcrank arm down a little so it didn't hit the tail box screw head. After I cut that down, and adjusted the travel, I've not had any issues with tail blowout. So what I guess I'm saying is, the gyro works. It just needs to be able to do what it needs to do.
mCP X ||| mCP X BL ||| 130X ||| 250 FBL ||| 250 FBL #2 ||| 450 Sport V2 FBL ||| 450 Pro FBL ||| X5 ||| DX6i |
09-25-2012, 06:11 PM | #105 (permalink) |
I did the grip flip mod so we will see how it works this weekend, if It doesn't help I will look into these options
09-29-2012, 01:11 AM | #106 (permalink) |
Do they work with Satellites yet?
10-05-2012, 01:11 PM | #107 (permalink) |
HOBBYMATE FBL CLONE USE WITH SPEKTRUM REMOTE RECEIVER
Is it possible to use a Spektrum remote reveicer with a HOBBYMATE FBL Beast - X clone? And if so how do you wire it?
10-05-2012, 01:14 PM | #108 (permalink) |
Mounted the h.mate on my trex 450, and just flown two packs with it.
SA1000E . MiniVolt-500.CncEfects: K7-1000E K6-800E. K700E.K550-600 Align:2x Trex 450 Dominator 6s. 2x Trex 550E 4× BeastX- 3× Vbar- 3× Spartan VX1n- 1× Sk720 |
10-06-2012, 12:49 AM | #109 (permalink) |
does not support sat rx yet from what I've read here.
10-06-2012, 03:35 AM | #110 (permalink) |
Does anyone know what’s up with Hobby Cool. After two flights, my HB800 will no longer initialize (almost gets to the end of bootup and restarts over and over and over) and I have sent 3 emails to Hobby Cool about this problem and no reply.
RC Heli Pilot = Control Freak |
10-06-2012, 09:23 AM | #111 (permalink) |
Have you tried going back through setup again? Can you reset the controller to factory default.
10-06-2012, 12:33 PM | #112 (permalink) |
It happened to me once, it ended up I was plugging in a battery I had flown already and not charged, plugged in a charged battery all was good.
10-06-2012, 12:43 PM | #113 (permalink) |
So what's the consensus on this thing? Is it legit? Better or worse than the zyx?
10-06-2012, 05:13 PM | #114 (permalink) |
My opinion:
If I were going flybarless again, I'd probably use the zyx (or the cheap 3x1000 thing) , with a computer programming cable. It has loads of users (support base), and flies well. I got the Hobbymate because I wanted to see how it flies. My friend had the copterx, and I wanted to be different. I am in no way disappointed, I love it, and its amazingly stable, and easy easy to set up. But the zyx is proven.
10-06-2012, 05:29 PM | #115 (permalink) |
Thanks, I had the ZYX and it did work well. I just felt like it had to much adjustability for me. From PID to deadband, it took me a while to get it right.
I now have a real beastx on a 500 and it literally took me 20 minutes and it was flying great. I have a hobbymate on order for a 450 project and hope setup time to performance ratio is more like the real BX and less like the ZYX. With a family I need flying time not adjusting time. |
10-06-2012, 11:38 PM | #116 (permalink) | |
I actually want the adjustability
10-07-2012, 10:34 AM | #117 (permalink) |
This was my first attempt at FBL. I thought it went well very easy to setup and flys great. Very good performance for the money and trouble free.
10-07-2012, 10:41 AM | #118 (permalink) |
Great,thanks for the input. I look forward to getting it.
10-08-2012, 04:14 PM | #119 (permalink) |
Thanks for the suggestions. I tried a fully charged battery sill will not initialize and just restarts the initialization over and over and over. Tried factory reset - it will not reset no matter how long I hold the button down.
Any idea how I can contact Hobby Cool, they have not responded to any of my emails. Thanks
