Help!! Esc Calibration and Gov settings - HeliFreak
Old 05-25-2012, 03:56 PM   #1 (permalink)
Default Help!! Esc Calibration and Gov settings
I'm new to vbar and have watch the video's several times. I have set it up according to video 20. In normal the heli will not spool up until I get pass half stick. after spool up i go back to half stick it starts slowing down. then its slow to spool back up. is this normal?
Here is my setup
CC Ice 100 V3.27
Hyperion sensor
Scorpin 4025-1100 12t pinion 129t main
Tx throttle is 104/79 for 100/100 on vbar
Here is the file.
poboy is offline        Reply With Quote Quick reply to this message
Old 05-25-2012, 10:06 PM   #2 (permalink)
come on 40 views and no suggestions!
Old 05-25-2012, 10:27 PM   #3 (permalink)
Mr Mel shows in one of the video on spool up u have to go past 50 for vbar to spool up..if u see it in video its clearly pointed out,if not than u been watching the wrong one....i run Kontronic so i dont use the vbar gov....if u see it ramp up fine than u on the right track..
ourbail is offline        Reply With Quote Quick reply to this message
Old 05-26-2012, 01:41 AM   #4 (permalink)
Here is my setup
CC Ice 100 V3.27
Hyperion sensor
Here is the file.
You should not be adjusting the values in the tx to get 100/100 values in vbar gov tab. Only for calibrating endpoints for esc and vbar transm tab. If you watched the right video, after you calibrate the esc endpoints, then transm tab, you will go to the gov 1 select your channels. gov 2 you need to flip on throttle hold, put your throttle to mid stick, and then flip in and out of throttle hold untill you get NO DELAY.(this means moving the slider one point at a time to get no delay from the time you flip out of throttle hold and the motor starting. that is how you calibrate low end throttle. ) the slider values will never be 100/100 in gov 2 tab.
US Army (Med Ret. 09/2014)
VBAR PRO GOV
Whip Nitro 105 (Officially back in business...Pun Intended)
OXY 3 (On The Way)
jgalen0025 is offline        Reply With Quote Quick reply to this message
Old 05-26-2012, 09:47 AM   #5 (permalink)
I adjusted the values in the tx only to get the 100/100 in the transm tad. I finally got it working right. Thanks for the help.
I do have another question.
On my idle up 2. I have flat 100% throttle curve. In the Gov. tad I have 2150 set as max. It shows 2670 as requested in IU2. Shouldn't it only go to 2150 max?
Old 05-26-2012, 08:35 PM   #6 (permalink)
That is very weird. I have never heard that before. double check that your gear ratio is correct(main gear teeth/pinion) and pole count(Half motor pole). Also make sure your phase sensor is grounded if your using seperate rx bat for power. If the problem persists, reset the gov and set it up again. Sometimes reseting on the gov 1 tab helps out with weird issues.
let me know(PM ME) if you have any other problems as i just set the gov up and it is fresh in my mind
VBAR PRO GOV
OXY 3 (On The Way)
Old 05-27-2012, 12:44 PM   #7 (permalink)
My gear ratio was wrong. Test flew it today! Thanks for the help!
Old 05-27-2012, 10:59 PM   #8 (permalink)
No problem. I like to pass on my knowledge. I was taught by one of the original owners of a vbar when everyone else had a flybar and fbl was "cheating"
VBAR PRO GOV
OXY 3 (On The Way)
Old 04-11-2016, 11:07 PM   #9 (permalink)
Location: Rancho Cucamonga, CA- Yes, that is a real place
Hi I have the same issue as the OP. No spoolup in normal mode until midstick. I have it programmed just as it shows in episode 20. 100/100 in vbar tx tab, and 110/46 in vbar gov II tab. I know the high point is low so the resolution will be poor but why should that affect the bottom half of the normal mode? The soft start seems to be working good but I don't have blades for this heli to test it properly.
In version 5 episode 20, at 21:50, Mr Mel demonstrates normal mode spoolup just as the stick is moved from the bottom.
VBar 5.2 Episode 20 - Governor Electric Remake (23 min 5 sec)
EDIT- I reset the esc endpoints, now the gov II tab numbers are 110/88, but it still has the issue. As far as I can tell, the vid i have linked in this post is the most up to date one.
R/C Outlaw (and proud of it) since February 20, 2016
Eric T is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
