2 mcpx with zero pitch. yet they fly completely different?! - HeliFreak
Old 05-27-2012, 07:16 AM   #1 (permalink)
Default 2 mcpx with zero pitch. yet they fly completely different?!
Hey so i recently built up an mcpx with mostly microheli parts minus the main hub and frame.
and ive got another thats all stock ( minus extended boom )
the MH one has lots of negative pitch and barely any positive and the stock has lots of positive pitch but barely any negative...
i put them both to zero pitch...yet this is the outcome.
any idea?
Trex 500
Night Vapor
Dx8
Thefishtank is offline        Reply With Quote Quick reply to this message
Old 05-27-2012, 07:22 AM   #2 (permalink)
Try adjusting the ATVs or travel adjust on the Tx. Also how do you measure zero pitch? There is a possibility that the swash sit too high/low so you get uneven pitch. Also check pitch curve for linear pitch.
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 05-27-2012, 07:38 AM   #3 (permalink)
the pitch curve is linear, whats the ATVs & travel adjust?
i did the zero pitch with my throttle hold set to zero and put it mid stick
Trex 500
Night Vapor
Dx8
Old 05-27-2012, 07:43 AM   #4 (permalink)
Its a menu on the radio if you are using a DX6i or a computerized radio. Whats the radio?
Compass 7HVU
Logo 600SX CF
Blade 450X
Old 05-27-2012, 07:44 AM   #5 (permalink)
dx8
Trex 500
Night Vapor
Dx8
Old 05-27-2012, 07:57 AM   #6 (permalink)
well i just skimmed through my servo menu...and my servo travel was at 75% so i put it to 100% and now they dont seem to be zero pitched any longer...maby that was it?
Trex 500
Night Vapor
Dx8
Old 05-27-2012, 08:06 AM   #7 (permalink)
Because I am not so good at explaining things, here is a setup video for the mcpx:[ame]http://www.youtube.com/watch?v=1-J0OapW4QE[/ame] Hope this helps a little and cover radio as well as mechanical setup.
Compass 7HVU
Logo 600SX CF
Blade 450X
Old 05-27-2012, 08:14 AM   #8 (permalink)
oh ive followed that video more than once. thanks for posting...
guess ill give it another go..maby i overlooked something
Trex 500
Night Vapor
Dx8
Old 05-27-2012, 08:29 AM   #9 (permalink)
make sure you have f.mode enabled when you are comparing pitch, ive been a victim of that mistake in the past.
the MH mcpx will fly a little different than the stock heli, i had the same situation before i went brushless but you can even out your positive and negative pitch. Go through the setup video posted and make sure you are in f-mode and your pitch setting under servos is even 70/70
Synergy E7
MSH Mini Prtos FBL Stretch 6s
MSH Prtos CF FBL Sretch
branmuffin is offline        Reply With Quote Quick reply to this message
Old 05-27-2012, 11:40 AM   #10 (permalink)
Brushed motors can vary quite a bit. If setup and lipo are identical, this could be the problem. I've got 3 stock mCP X's they each have their own character lol
2018! Packing!
spykez is offline        Reply With Quote Quick reply to this message
Old 05-27-2012, 04:22 PM   #11 (permalink)
Default .
I just purchased my first MCpx last week. This is what I did to remedy the uneven pitch problem. First set your pitch to zero at mid stick. I like the toothpick method the best for this. Remove the blades and put toothpicks on the blade grips where screws go. From there you can move the stick to full negative, positive and mid stick using throttle hold. You will probably see uneven amounts of full negative and positive pitch. So adjust the ATV points to make them even. For example on my mcpx the positive ATV is at 75 and negative ATV is at 80 to get equal amounts of pitch. My bird flies 10x better now after doing this. Transitioning to inverted flight is much easier.
H.M.MURDOCK is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
