need help - c05, blades spin backwards - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 06-01-2012, 02:04 PM   #1 (permalink)
Default need help - c05, blades spin backwards
Hey guys/gals, I have a BL mcpx with the wow hobbies pnp with xp-7a, steve and hp05 motor. I just bought a c05 motor to replace the hp05 when flying indoors as I feel the hp05 will do some serious damage to something in my living room (and then mostly likely my relationship)
I thought I could just switch out the motors, but when plugged in one way, the main blades spin backwards, when I flipped the connector 180, the motor doesn't spin??
Any help would be appreciated
(fyi- also just bought a flashed xp-7a from Dylan in case I want to permanently install the c05 on my stock mcpx)
mixfisto is offline        Reply With Quote Quick reply to this message
Old 06-01-2012, 02:22 PM   #2 (permalink)
Flip 180 the motor should spin the other way. Does it spin without the main gear?
BTW direct solder is much better.
MCPX HP05s/HP03T Xtreme Frame (Beater)
MCPX HP06v2/HP03T MH X Frame (Precious)
MCPX HP08/HP03T MH X Frame (Grounded)
MCPX stock DIY firmware (Experimental)
coredump is offline        Reply With Quote Quick reply to this message
Old 06-01-2012, 02:44 PM   #3 (permalink)
The wires are rather delicate on the C05 motor. Make sure a wire did not come loose at the plug when you flipped it around.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
DX9, AMA# 966513.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 06-01-2012, 03:02 PM   #4 (permalink)
ok,
the good news - for some reason when i flipped it this morning, it spun the right way!
the bad news - while connecting to the esc, the black cable from the esc to the connector came loose... i guess that could be blessing in disguise.
now that i have to do some taking apart and soldering, i might as well get rid of the 'pnp' aspect and just solder the whole thing up right
i know there are million posts/threads on this, but can someone point me to a great place to learn the proper wiring/soldering? Looks like I will have 2 bl mcpxs (c05 + hp05, indoor/outdoor)
- i have one mcpx v1 with the wow hobbies pnp xp-7a, the steve - which i will now attempt to 'de-pnp'
- i have another mcpx v1 with a flashed xp-7a from Dylan
Thanks!!
Old 06-01-2012, 03:03 PM   #5 (permalink)
btw, thanks craig and coredump for the info!
Old 06-01-2012, 10:33 PM   #6 (permalink)
I would leave that small motor pnp, incase u ever have to adjust zero pitch.
Hoghunter7mm is offline        Reply With Quote Quick reply to this message
Old 06-01-2012, 10:42 PM   #7 (permalink)
Why PNP help adjust zero pitch?
Old 06-02-2012, 11:04 AM   #8 (permalink)
Yes, please explicate.
Team Newb pilot
DX9, AMA# 966513.
Old 06-02-2012, 11:30 AM   #9 (permalink)
Opps, I didnt read the WOW pnp, thought he meant the 3 pin plug between motor and esc.
Old 06-02-2012, 12:14 PM   #10 (permalink)
sure he means so moter can be unpluged while fooling with settings on heli.
Spedix250pro,180CFX,Trex600 Beastx,Edge 540,Gremlin,POD Racer,,Whipit,Z-84,Electric Shock AMA 27 yrs.
Old 06-02-2012, 12:17 PM   #11 (permalink)
You can just plugin the battery to do that. It is better unplug the
battery so you don't stress the servo any way. The servo when
powered, it will work hard try to hold the posistion. If you push
on the servo, that might stress it.
Old 06-02-2012, 12:44 PM   #12 (permalink)
I get the servos mechanically zeroed, than finish off with sub trim too get it perfect. That's the way I do things.
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
