xtreme hopup question - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 06-09-2012, 07:33 PM   #1 (permalink)
Default xtreme hopup question
while i was waiting to get new 5n1, i put on xtreme motor,swash,flybar and main shaft, already had 250 skids,boom support,blades cut and motor ziptied, i have 6 550 hyperion,and 6 nano tech 600 batteries, dosent mater which one ii use i get about 7min flight time with my stock 120 and about 2 sluggish min on my hopuped one, i cant figure out why?,, could i have gotten bad motor, and the 5n1 is brand new, all parts were
Blade 120sr with xtreme hopup
Walkera Master CP for sale
Devo 7E
Syma x8c with many mods
edgeslade is offline        Reply With Quote Quick reply to this message
Old 06-09-2012, 08:21 PM   #2 (permalink)
Hows the gear mesh on the hopped up one?
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote Quick reply to this message
Old 06-09-2012, 08:45 PM   #3 (permalink)
Good
Sent from my VM670 using Tapatalk 2
Devo 7E
Old 06-09-2012, 09:38 PM   #4 (permalink)
Back to basics then, pull the motor and put a stock motor in to see if it flies better.
While you have the motor out make sure everything else is spinning freely.
If that fixes it then you know the motor or the connection to the motor is the problem.
I don't have that type of motor but going by what I have learned form the old school brushed motors in rc cars, make sure the wires going to the brushes on the motor aren't hanging up the brushes, give them a little tug to make sure the brushes move freely.
Check to make sure you have a good connection at the battery and the motor.
Old 06-09-2012, 09:40 PM   #5 (permalink)
Another thing to check is the motor mount screws, make sure they aren't too long and hitting the armature inside the motor.
Old 06-09-2012, 09:48 PM   #6 (permalink)
i just put stock motor back on will check in morning to see if that's it
Devo 7E
Old 06-10-2012, 12:21 AM   #7 (permalink)
I just looked at a picture of the extreme motor and it doesn't appear to have changeable brushes like the old school brushed car motors, disregard my advice about the brushes.
Old 06-10-2012, 06:25 AM   #8 (permalink)
I broke a ball joint off the flybar ,so had order a new one.I replaced it with a carbon fiber/ aluminum one and also put an aluminum swash on it.Then I decided to go all out and upgrade almost everything.I just ordered aluminum blade grips,tail motor mount ,anti rotation collar,extended 8" boom ,vertical fin and a new canopy all in red.Cost a little over a$100,Am I crazy for spending this much on this bird?Should be pretty cool looking when the mods are done.Mike
Zelon is offline        Reply With Quote Quick reply to this message
Old 06-10-2012, 10:16 AM   #9 (permalink)
Its just bling, far as I'm concerned, long tail, throws center of gravity way off, all aluminum adds weight, and causes more damage in a crash, the swash and main shaft are worth it in my opinion
Devo 7E
Old 06-10-2012, 11:35 AM   #10 (permalink)
I guess it's too late now everything has shipped,maybe I"ll just replace parts as I break them.LOL Mike
Old 06-10-2012, 11:37 AM   #11 (permalink)
thats what i do , i have a shelf full of aluminum upgrades for my mcpx that i haven't touched
Devo 7E
Old 06-10-2012, 11:45 AM   #12 (permalink)
when i took the xtreme motor off i noticed on top of motor,there is two small brushes,where the wires connect, the one on the negative side looked to be barely touching, i removed brace bent inward, plugged motor in to dead battery and it jumped out of my hand, seemed to work fine, also the screws that came with,seemed to short so i used my stock motor screws, how should these brushes be positioned ?its raining here so cant get outside to fly
Devo 7E
Old 06-10-2012, 12:04 PM   #13 (permalink)
I'm not sure what you mean by ''positioned'' the brushes make contact with the commutator to conduct electricity.
Old 06-10-2012, 12:09 PM   #14 (permalink)
how much tension should be on them barely touching, or pressing firmly against the commutator
Devo 7E
Old 06-10-2012, 12:15 PM   #15 (permalink)
I cant give you an answer for that question, I could tell if it was right by feel but I have no way of conveying that to you.
I can tell you there should be some pressure though.
Old 06-10-2012, 12:19 PM   #16 (permalink)
ummmm, well like i said the one on negative side seemed barley touching so i bent so its got pressure, if to much it would burn brushes ,correct? also im going on assumption ,i replaced with my stock motor but its raining, haven't had chance to put it in the wind
Devo 7E
Old 06-10-2012, 12:23 PM   #17 (permalink)
I guess the best thing for you to do would be make it feel like the one on the positive side, basically you want enough pressure to keep the brush from bouncing off the commutator.
Old 06-10-2012, 12:24 PM   #18 (permalink)
makes sense
Devo 7E
Old 06-10-2012, 03:23 PM   #19 (permalink)
ok, finally got a break in the rain , it is the new xtreme motor, i got 7min awesome flight time with all my mods,and stock motor, so im going to retry the xtreme motor with adjustment made to see how it goes, will update
Devo 7E
Old 06-10-2012, 03:43 PM   #20 (permalink)
At least you know what the problem is.
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
