ALIGN T-REX 500 Four Blades Rotor Head Test - Page 2 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Mechanics
Mechanics Mechanics Discussion
Old 01-25-2013, 10:40 AM   #21 (permalink)
I'm just putting one of these on my Trex 500, do I use a standard 500 mainshaft or do I need a flybarless mainshaft?? Thanks
alchemy66 is offline        Reply With Quote Quick reply to this message
Old 01-25-2013, 01:37 PM   #22 (permalink)
I have used them both, flybar or flybarless, depending on the fuselage style and if you need or not the longer shaft. Either way will work....
JoseReyes is offline        Reply With Quote Quick reply to this message
Old 01-26-2013, 03:53 AM   #23 (permalink)
Problem is, when I use a standard fly bared mainshaft I cannot get zero pitch at 50% stick. The links from the servo horns to swash are not long enough. I was hoping that a fbl mainshaft being shorter would sort the issue out? Am I correct? Thanks
Old 01-26-2013, 03:11 PM   #24 (permalink)
ESP H50086 153.3mm
FBL H50133 148.8mm
It will lower the whole head by 3.5mm or you might have to get some longer rods off another model
ozflyer is offline        Reply With Quote Quick reply to this message
Old 01-26-2013, 03:36 PM   #25 (permalink)
Originally Posted by ozflyer View Post
ESP H50086 153.3mm
FBL H50133 148.8mm
Thanks OZFlyer, I don't suppose you could suggest any suitable links?
Jim
Old 01-26-2013, 03:38 PM   #26 (permalink)
approx. how much too short are they
Old 01-26-2013, 03:39 PM   #27 (permalink)
Hi, I'll have to measure them and get back to you, I'm not where the model is at the moment. I'll post back tomorrow. Thanks for getting back so quick.
Jim
Old 01-26-2013, 04:02 PM   #28 (permalink)
Hi Jim
Standard length for ESP 3 x Φ1.96 x 31mm
here are some options
550 rods H55048 3 x Φ1.96 x 39.5mm
600 rods H60161 3 x Φ1.96 x 39.5mm
550 rods H55049 2 x Φ1.96 x 44mm ( you would need 2 packs)
Steve
Old 01-26-2013, 04:05 PM   #29 (permalink)
Steve,
Awesome many thanks, I'll measure tomorrow and see which I need to get.
Much appreciated
Jim
Old 01-27-2013, 05:02 AM   #30 (permalink)
Hi Jim
Steve
Steve, with the swash midway between head and mainshaft collar. The distance ball to ball is 55mm. I can't help wondering if there is something else not quite right here as no one else seems to have posted anything about needed longer links or different mainshafts??
What do you think?
Old 01-27-2013, 05:21 AM   #31 (permalink)
Having the swash mid way on the mainshaft is a 3D thing to get equal travel +ve and -ve and you wont be needing to go to -12 degrees you can move the swash lower by lengthing the blade rods a little as long as you still have clearance. Are the arms level?
Standard length for an ESP between balls is 50mm a FBL main shaft would just about fix that.
Other people might be starting wit a FBL heli with the shorter shaft.
Old 01-27-2013, 05:25 AM   #32 (permalink)
Smile
Yes I get that, I won't be doing 3d with it :-) . I'll order the FBL mainshaft and I might order some longer links as well just in case. I'll post back in due course, thanks for all your help.
Jim
Old 01-27-2013, 05:58 AM   #33 (permalink)
My EFL Pro with the 4 bladed head uses the 39.5mm rods to fit. Ozflyer should know.. he bought them for me
Uglybob is offline        Reply With Quote Quick reply to this message
Old 01-27-2013, 06:11 AM   #34 (permalink)
Cheers, I've ordered the shaft and rods so should be with me tuesday / weds next week. I'll get back on it then!!
Old 01-29-2013, 01:19 PM   #35 (permalink)
Update: mainshaft & rods arrived today. All OK now. Many thanks to you guys!!
Old 02-28-2016, 06:47 AM   #36 (permalink)
hi
i look for instruction manual pdf
COMMANCHE is offline        Reply With Quote Quick reply to this message
Tags
500, align, four blades, t-rex
Human Verification
