Old 06-29-2012, 10:57 PM   #21 (permalink)
Originally Posted by itsmillertime0 View Post
Holy! Wow
Sent from my ZTE-Z990G using Tapatalk 2
Trex 550X,,Fusion 480,OMP M2,B180CFX,lots of Planes Powered by DX8/TX16S AMA 32 yrs.
Epoweredrc is online now        Reply With Quote Quick reply to this message
Old 06-30-2012, 12:32 AM   #22 (permalink)
Originally Posted by Razzman View Post
Hello James and 130X pilots,
Thanks for the info on setting gyro gains. I tried a couple test hovers indoors this evening, but I initially found that the tail was acting like the gyro gain was too high, not being very smooth, shaking mainly side to side, also some up and down. Also when spooling up from soft start, the tail goes through a nasty vibration, looks like the tail blades are way out of track, until the head speed is stabilized.
This was with stock settings for hovering, idle up was worse. I lowered the gyro gain, although not sure if it's as low as it goes. This helped smooth the tail vibration some, although it's still not very smooth, still some side to side vibration, and up and down.
I played with the main blade tightness, and tail blade tightness in blade holders, as they sure were on the super loose side. I just took some of the excessive play out in the blade holders, but the blades can still pivot freely.
All gears seem to turn freely, just hoping I can get this heli to smooth out in a hover.
How smooth should the tail be? My MCPX was very smooth, no vibration.
Thanks,
Brian
I experienced the same problem, I tried lowering the gain on my gear channel from 100 down to 80 and it help but not smooth, hopefully somebody out there can chime in on how to iron this out...
I don't always fly but, when I do, I fly Gaui "X1" and "X1.5"
fabian1675 is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 12:43 AM   #23 (permalink)
I saw the exact same vibration on two 130Xs at the LHS today, and with mine when I got it home. Seems that there's a particular rpm where this happens. Above or below that value, it doesn't happen but you can't miss it when it does.
One of the hobby shop guys also noticed something when landing. When lowering the throttle to minimum, the servos would 'twitch' just as the blades stopped. He said it happened nearly every time, but when he went to demonstrate it, it didn't happen. Go figure...
I hovered mine in the basement this evening. The 'twitch' wasn't present at landing on the first flight, but I did observe it on the second. Also, the tail was vibrating quite a bit while hovering during the second flight.
Anyone else seeing these or other issues?
The 130X seems like a nice helicopter, hopefully these are just 'teething pains'...
Don
Digital Don is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 08:27 AM   #24 (permalink)
3vw
Default Mine too
I have 2 130x's and both units have manifested the same issues of vibrations for me.
The advantage of having the 2 130's is the ability to see right away these problem are not unique.
Sadly this is being taken up here in this thread... A new thread should be started with the titled problem.
Hopefully James or someone from HH can tell us what the remedy might be.
3vw is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 08:57 AM   #25 (permalink)
the twitch when you land is the gyros resetting when you go to zero throttle. that is normal.
Team Horizon
merlin3 is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 09:15 AM   #26 (permalink)
We tested one so we would know what we are selling to our customers and immediately had the extreme tail vibration. It is so bad and increases to the point that that it looks unsafe to continue any higher. At just above half stick the heli is bouncing around on the ground because of the vibration. Looking at it from our customers POV we felt that most of them would probably freak at this point and not try to push it and then return it to us. Unfortunately we will most likely pull our inventory and return it until this is officially addressed. Its simply not an acceptable characteristic.
Socal500 is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 10:14 AM   #27 (permalink)
Wow! This is exactly the kind of thing I didn't want to hear.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is online now        Reply With Quote Quick reply to this message
Old 06-30-2012, 10:31 AM   #28 (permalink)
Have you tried to just flick into Idle1 and let the heli spool up to flying speed?
A lot of heli's will hit a resonance at lower headspeed. The trick is to simply push thru it as fast as possible.
ahahn is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 11:25 AM   #29 (permalink)
Mine is fine.
We're on the Road to Serfdom....
Adam T is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 11:47 AM   #30 (permalink)
Hi guys,
The vibration issue is normal on spool up. The helicopter is hitting a resonance when on the grou. Spooling up slowly will cause this, the simple is to spool up quickly and go right into a hover.
This is not a defect. Lowering the tail gain will not affect this.
As for the twitch when landing after leading and going to low throttle the gains are on for 5s then shut off. This is so you can do baby autos.
Ill try to help out whever possible.
Thanks,
James
Horizon Hobby Product Development
soljkaer20 is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 11:49 AM   #31 (permalink)
Out of all the helis I have flown, the worse tail wag does not even compare. Even if we could push through it it's not something I would expect our customers to accept. That and the amount of vibration it goes through prior to pushing through cannot be good for the small parts in the tail. In not sayin all of them do this. We will test a second one today.
Old 06-30-2012, 02:15 PM   #32 (permalink)
Don
Yep, I'm seeing the exact same thing. (posted over in the thoughts, issues, problems thread)
Fifteen years....
and still workin' on the left hand hover
TheEternalNewbie is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 03:06 PM   #33 (permalink)
ALRIGHTY THEN!
Adjusted my rudder gain (how much? Not sure. Hard to tell when LED was blinking faster)
Random tail shudder has gone away.
Fifteen years....
Old 06-30-2012, 03:09 PM   #34 (permalink)
Smile Getting a smoother 130X
Guys,
I checked the main blade balance with a crude home made balancer using two razor blades, glued to a strip of wood, then I used a small 2mm bolt with a couple nuts to join the blades together in order to check the balance.
I found that the main blades were way out of balance. So I actually drilled some small holes in the heavy blades bullet, also sanding the paint off the blades with some fine wet and dry 3m paper. I even used some 5min. LB weld to add some weight back in to a couple bullet holes...experimenting.
I also took the entire tail apart, all seemed fine. I did tighten the tail blades into their blade holders, they can still pivot, but the sideways play is gone. Also tightened the main blades so they could pivot, but no excessive play in the grips.
I also increased the throttle curve in normal mode up a good 10%, in order to accelerate the main rotor and tail through the vibration zone....it still has a nasty vibration, not always so consistent in intensity(I'm trying different techniques to power through it, adding some tail rotor, adding collective to get the heli in the air quicker)
But the heli is much smoother in a hover! I'm happy with the smoothness, the tail is also much more stable, being almost perfectly smooth. I did also lower the tail gain with James instructions...will still play with that, along with the Ail. and Elev. gains.
I'm just happy the heli is smooth in flight, just working on some fine tuning. The tail spool up vibration is certainly nasty at times, maybe different tail blades will improve it? Come on KDBB bring us some blades
ID:	328305   Click image for larger version
ID:	328306   Click image for larger version
ID:	328307   Click image for larger version
"Wring it out"
Razzman is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 03:40 PM   #35 (permalink)
Originally Posted by soljkaer20 View Post
Hi guys,
Thanks,
James
You saying it's able to do baby autos?
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 05:18 PM   #36 (permalink)
Bringing this one to the top and repeating the other request to make it sticky.
Mike
mrc3 is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 05:39 PM   #37 (permalink)
It does nice ones from about 3 feet.
ChrisG23 is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 10:12 PM   #38 (permalink)
^ that's awesome.
nqx, mcpx, mcpx BL, 130X, trex 250 pro DFC iKon, 450X, TBS Discovery, Trex 500 DFC iKon, dx9
TheHeliDude is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 10:30 PM   #39 (permalink)
Smile huhh
Originally Posted by ChrisG23 View Post
Now if only the stock system supported governor mode, and swash had rear facing anti rotation pin.... oh well Not gonna stop me from purchasing.
Cool little - heli,really no ned for gOv mode
genuine is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 10:38 PM   #40 (permalink)
Smile neat
the ladder is warp next to the house, never thought something so small would lift that,shows yeah what power will do!
