Like Tree6Likes
Old 07-17-2012, 05:25 PM   #61 (permalink)
oops.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 07-17-2012, 06:02 PM   #62 (permalink)
Throwing some 130x's around at TNT's house today. 60+ flights on the original gears!
Goatkeeper is offline        Reply With Quote Quick reply to this message
Old 07-17-2012, 06:03 PM   #63 (permalink)
Here is a pic of my 4g6 MH tail slider.
Old 07-17-2012, 08:26 PM   #64 (permalink)
Blade Forum Support
Here are more pics goatkeeper came over to fly so it was a small fun fly
Be blessed
Isaac
Sent from my A100 using Tapatalk 2
ID:	333164   Click image for larger version
ID:	333165   Click image for larger version
ID:	333166   Click image for larger version
ID:	333167   Click image for larger version
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 07-17-2012, 08:35 PM   #65 (permalink)
Be blessed
Isaac
Yep, fun day at TNT's house. I had to replace the first part after 60+ flights and 7 or 8 crashes. Thanks for the blade grip buddy!! Ill get you back.
Old 07-18-2012, 03:19 AM   #66 (permalink)
Some from mine today.
As you can see I have converted mine to nitro in this shot
Sent from my Galaxy Nexus using Tapatalk 2
rallyant is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 03:22 AM   #67 (permalink)
Wow awesome shots!
SAB Goblin 380KSE Gaui X3 Blade 180cfx Chase 360
JR DSX11 Mode 2
modena is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 08:16 AM   #68 (permalink)
Yeah, those are great!
Old 07-18-2012, 03:50 PM   #69 (permalink)
Once I can drive/walk I'll get yellow spray paint for white skids and tailfin. My 450X is orange,130X is Yellow, 300X will be red, and my second 130X is going to be green
Krea is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 04:02 PM   #70 (permalink)
You'd better be careful over there. Looks like Spongebob is stalking you guys...
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 04:04 PM   #71 (permalink)
SICK!!
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 04:05 PM   #72 (permalink)
I am a Troll and a CLONE account
Nice. Did you have to modify that part or was it a "drop in" install?
sertav is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 08:48 PM   #73 (permalink)
It has to be modified. You have to cut down an aluminum tube tail box spacer and slide it in the pitch slider to act as a bushing to fit snug on the tail shaft. The slider links have to drilled out to 1.2mm's and the ears on the slider where the links attach have to be opened up a bit for the links to move freely. Then you will have to adjust the slider push rod to have equal piro rates. So it's a little work but this slider bearing is so precise. With this and the O-rings I have 0 play and a crisp tail. Oh, and I added Walkera flange bearings to the tai case.
Old 07-18-2012, 08:59 PM   #74 (permalink)
Blade Forum Support
Here are few new pics. Upgrades aluim slider, tail grips, canopy and landing gear. This lil guy have worked his way in my heli family :beer:
Be blessed
Isaac
ID:	333443   Click image for larger version
ID:	333444   Click image for larger version
ID:	333445   Click image for larger version
ID:	333446   Click image for larger version
ID:	333448   Click image for larger version
FPV Everything Now
GOD BLESS
Old 07-18-2012, 09:21 PM   #75 (permalink)
What ?? You didn't have your spare parts with you ??
Glad to hear you had fun guys.
Fred
Pipoule 64
Trex 550e stretched. DHPS Head - Trex 700 DFC with Speed fuselage - Icharger 3010B - DX9 - Phoenix sim -
Pipoule64 is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 09:27 PM   #76 (permalink)
Here are few new pics. This lil guy have worked his way in my heli family :beer:
Be blessed
Isaac
Nice tail grip ;-)
Fred
Pipoule 64
Old 07-18-2012, 10:45 PM   #77 (permalink)
meTAIL upgrades
upgraded tail case, slider, grips, bearings, and weights for the tail grips. COG is level with the stock battery, performance is awesome and no vibration at ALL!
and yes my gear is on the other side, yes my tail spins opposite from stock. no i don't notice the difference reverse spinning tail rotors make when flying. and yes it took mods to get the case to work with the 130x
ALIGN TREX 250SE 450SE V2 500ESP 550E 600ESP 700E
NOVUS CP
BLADE MSR BLADE SR 120 BLADE SR
so-fly is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 10:54 PM   #78 (permalink)
Awesome!
What part numbers and how did you do it?
Looks great
Gaui X5 sweet! Warp 360 KST, B4503D Savox- all beastx, 250 SE flybarred-current shelf queen, 130X, Mcpx BL, Nano cpx, Mini Dragonfly, DX8 AMA #982022 If you get to thinking you're a person of influence, try ordering somebody else's dog around.
shreddedpaper is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 11:00 PM   #79 (permalink)
Originally Posted by so-fly View Post
meTAIL upgrades
You also now have leading edge control on the tail blades. I've been wondering if this hasn't been causing vibe issues due to the longer moment arm from the ball/arm to the CG of the tail blades with the stock setup and its overall SLOP. Every single heli I've ever had, except for ones with motor driven tails, had leading edge control for the tail rotor blades. Even the 450 3D which, oddly, has trailing edge control for the main blades.
Old 07-18-2012, 11:27 PM   #80 (permalink)
I dont know the PN, parts came from random parts bin lol. I'm sure it's one of those xheli copters I've bought in the past lol.
As for leading edge control...it's actually trailing edge. The rotation is reversed because I mounted the gear on the opposite side
NOVUS CP
