Old 07-16-2012, 09:21 PM   #1 (permalink)
Default Can you fix a cut sensor wire?
Does anyone know if you can repair a cut sensor wire? Is it as simple as soldering it?
Here is a picture of the wire. I appreciate any advice.
Goblin 630, T-Rex 700e, Outrage Fusion 50, all with VBar, Blades MCX2, 120SR, Radian Pro, DX8's - HeliBuilderNM
nu66ie is offline        Reply With Quote Quick reply to this message
Old 07-16-2012, 09:44 PM   #2 (permalink)
Cut it completely, strip wires only a little, tin both wires, put Atleast 2 layers of unshrunk heat shrink over and solder together. Shrink the shrink one at a time and you should be fine.
heraldo is offline        Reply With Quote Quick reply to this message
Old 07-16-2012, 09:56 PM   #3 (permalink)
I would try fixing. It's just a wire, I would see it as no different than fixing a servo wire and I've done that a few times.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote Quick reply to this message
Old 07-16-2012, 10:24 PM   #4 (permalink)
Thanks for the reply. I thought it would be just like a servo wire but was a little nervous about the little blue box at the end of it.
Old 07-16-2012, 10:28 PM   #5 (permalink)
No problems with joining it - other option is to get some servo plugs and crimpers and just crimp a whole new plug on the end. Then you can use a servo extension if necessary for length.
John
Old 07-17-2012, 06:33 PM   #6 (permalink)
Thank you all for the info. I took heraldo's advice but used two layers of heat shrink on the cut wire and a third over all three. Seems to work fine on the bench.
Old 07-18-2012, 06:20 AM   #7 (permalink)
Done that on the sensor a time or two.
Screw It, I'm gonna fly.
In search of a 500-600 sized heli.
Preferably rtf with vbar.
povern is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 03:18 PM   #8 (permalink)
The Capi
Can you open up the blue cases ? Can you replace the servo lead on the PCB instead of extending the current lead ?
Old 07-21-2012, 06:47 PM   #9 (permalink)
I would guess its all SMT in the sensor and if someone isnt very good with a iron they could do more harm than good
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 09-21-2012, 01:08 AM   #10 (permalink)
Yes but if is good at solder iron .....
Do we have an inside pic?
Sent from GT-I9000 Using Tapatalk 2
Bill
Esprit Model Flying, TDR Rigid x2
F9 Fiberglass Europe Canopies
billiano is offline        Reply With Quote Quick reply to this message
Old 09-21-2012, 10:35 AM   #11 (permalink)
I would just leave it soldered and insulated, a lot of scare mongering on forums IMO. People worry about brittle solder, but that is only the case when a wire is fixed to a rigid point with no strain relief. I have no qualms about cutting servo wires to length and crimping connectors and cutting Spektrum satellite RX cables to length, solder and insulate in the middle. No helicopters falling out of the sky to date due to solder, thumbs yes, solder no!
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote Quick reply to this message
Old 09-21-2012, 10:53 AM   #12 (permalink)
I want to trim the sensor's cable in length for the TDR(which will be stacked)
Can I open the sensor's case afterwards and solder place a new cable?
Has anyone ever opened the blue sensor?
Bill
Old 09-21-2012, 10:59 AM   #13 (permalink)
Cannot answer that but I would be happier attacking from the other direction if it was mine. Cut and crimp on new servo connectors if you have the tool of course.
Synergy E7 -
N7 - N5C
Alun
Old 09-21-2012, 11:03 AM   #14 (permalink)
Of course I will cut the plug and install a new one with HansenHobbies tool .
But if I decide to sell it how am I going to restore the cable?
Bill
Old 11-20-2014, 11:47 PM   #15 (permalink)
TT
I needed to replace the cable due after shortening it then moving it to a different heli. If you are good with soldering to PCBs then it shouldn't be a problem...if you aren't then you probably shouldn't attempt it.
TT is offline        Reply With Quote Quick reply to this message
Old 11-21-2014, 05:50 AM   #16 (permalink)
The Capi
I've done it before, it isn't easy at all
Tags
vbar
