Old 08-25-2007, 09:20 PM   #1 (permalink)
Default Make your own Stepdown regulator
Last week I was looking for a stepdown regulator. I've got the 2 in 1 from Align, great thing by the way. But nowhere a stepdown to be found.
the 2 in 1 provides 5.8V which is a little bit to high for most rudder servos. Need to knock off 0.7V.
You can do this by taking a short servo extension wire.
Cut the red wire.
Solder a Diode 1N4001 in between the 2 ends (kathode to the servo side)
and your done.... Use this between your gyro and rudder servo.
Cheap solution. This will cost your around 1.5 dollars.... and works fine.
Ron
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-)
kraaijer is offline        Reply With Quote Quick reply to this message
Old 08-25-2007, 09:27 PM   #2 (permalink)
What kind of load can you run under that diode? Have you done any tests?
electricdurango is offline        Reply With Quote Quick reply to this message
Old 08-25-2007, 09:32 PM   #3 (permalink)
The 1N4001 is rated for 1A, enough for 1 servo.
Don't use this for more then that.
Old 08-25-2007, 09:36 PM   #4 (permalink)
For the less knowledgable
The white ring around the diode needs to point towards the servo.
Alfred
Radios: JR DSX9, Mikado VControl
Helies: 2xTRex450, TT30, TT50SE, RJX50, X-Cell60, Fury Expert, Stratus, Kasama ECO (under construction), Goblin 770
Alfred is offline        Reply With Quote Quick reply to this message
Old 08-25-2007, 09:39 PM   #5 (permalink)
Thanks for clarifying that Alfred, forget to mention that.... :-)
Old 08-25-2007, 09:47 PM   #6 (permalink)
Team Taco VP
Thats whats in the Align step down anyway
Bob
Old 08-25-2007, 09:50 PM   #7 (permalink)
That's what I figured... makes it even better, cause it's easy to get, easy to make and cheap.
Old 08-26-2007, 02:45 AM   #8 (permalink)
So can you wire 2-3 diodes in parallel to increase current capacity without changing the .7V dropdown ?
John
Old 08-26-2007, 02:59 AM   #9 (permalink)
Not usually a good idea since diodes often don't share current well due to very small variations in forward voltage drop. This can be overcome with snubber resistors but just makes things more complicated. Do a search on www.digikey.com for a big selection of diodes of whatever current rating needed (I used 3A).
Have laser, will travel.
cbdane is offline        Reply With Quote Quick reply to this message
Old 08-26-2007, 03:46 AM   #10 (permalink)
If you want a higher Current rating use a diode from the 1n5xxx series.
You could put 3 1N4001 in parallel, but you would have to find "matching" diodes, and as suggested here above doing this is taking a risk.
If you need anything bigger I suggest you simply use a BEC of 6A at 4.8V and you're done. However, a lot of servos actually work great with 6V so why take that away :-)
Old 08-30-2007, 04:31 PM   #11 (permalink)
Hi,
Here I coud not find the 1N4001 but the 1N4004, can I use this last one ?
Boris.
BorisGarcia is offline        Reply With Quote Quick reply to this message
Old 08-30-2007, 05:17 PM   #12 (permalink)
Yes you can, is even "saver" because of the higher Voltage rating.
Good luck.
Old 08-30-2007, 08:13 PM   #13 (permalink)
Talking Open season
It is open season on radio shack diodes. Any of the rectifier diodes would work fine for this step down. If you want a higher current rating check the specs. A voltage rating over 10 volts and a current rating large enough to suite your wishes and go for it.
For Example:
3-Amp Diode
Model: 1N5402 | Catalog #: 276-1143
Decisive 200A surge. Type 1N5402. Peak Inverse Voltage (PIV) is 200.
or
PTC205 Silicon Diodes (3-Pack)
Model: PTC205 | Catalog #: 276-1114
Contains 2.5A, 1000-PIV silicon diodes
RTDillon is offline        Reply With Quote Quick reply to this message
Old 08-30-2007, 09:10 PM   #14 (permalink)
For Example:
3-Amp Diode
or
Exactly. But you still probably want to check the forward voltage drop also. Some of the high power rectifiers have smaller drops meaning they may not get your voltage down to 5V.
Old 08-31-2007, 03:51 AM   #15 (permalink)
Is this the time where I should start buying stock in Radioshack?
I don't recommend to use this to step down before the receiver though. I you have a need for that you're better off using a BEC.
I posted this because the Align stepdown's are sometimes hard to get by and ar nothing else but a 1N4001, so why not make it ourselves.
Old 10-05-2007, 03:58 PM   #16 (permalink)
Thanks for this, it works a treat with a IN4004.
Nobody had the Align stepdowns so I would have been well stuck without this. We could churn out loads of these and supply them to the stores, I bought 10 of these for 1 (about $2) !!!!!
Outrage G5 Skookum Flybarless
T-Rex 500esp V-Bar flybarless
Outrage 550 - T-Rex 600 Nitro Pro
DMHC
frogbmth is offline        Reply With Quote Quick reply to this message
Old 10-06-2007, 08:57 AM   #17 (permalink)
Hello there,
Had the same problem myself (no step-down available and a beautiful sunny saturday coming). Did my own circuit with a 3A diode and it works perfectly (I get 5.1V for the rudder servo)
Sam.
sambogosse is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 04:44 AM   #18 (permalink)
Hi.
I'm using a 1N4007 (the only one my local electronics-shop had in stock), but when I meassure the voltage, it only drops from 5.75 to 5.35 (0.4 volt).
Is this becausse my messurement is made without any load ?
dkpodder is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 09:28 AM   #19 (permalink)
Yes, foward current is necessary to see a voltage drop..
TDRx2
Mikado 600SE
Sandy is offline        Reply With Quote Quick reply to this message
Old 12-29-2007, 12:26 PM   #20 (permalink)
Smile 1n4007
I have found this thread when looking for a solution for my S9257 with the GY401 and the Align controller for the T-REX 450 SE V2.
I had a hard time to find a step-down and was not willing to be running my brand new servo on 6 volts.
The suggestion given in this thread was just perfect for me, though I could only find the 1N4007 available but it works the same for this step-down.
Anyway, thank you guys for all the comments. You have saved my weekend !
Eduardo
Eduardo is offline        Reply With Quote Quick reply to this message
