mSR X Blade Micro SRX Helicopters Information and Help |
#1 (permalink) |
![]() http://ganninger.de/DX6i-mSRX.pdf
I can't take ANY credit for them other than typing the right thing into google. Not sure who came up with this but my hats off!! It's flying better and more well behaved than EVER before. It literally piro's like an mCP X now! My heli already had a near perfect MM mod done but the mixes on this setup make it AWESOME! Keep in mind I'm BL with a 13,500KV HP03S. Can't comment for sure on how it'll work with a stock motr but it's well worth a try trust me!
DSMX DX6i, MH mCX2, mSR, BL RKH mSR X, 3 X mCP X v.1 (one stocker, one destined for DBL, one destined for DBL mini130X), Lachmund mQX PM me for your soldering and mSR X BL build needs. |
#2 (permalink) |
![]() Join Date: Jan 2012
![]() I see a few people are looking. If you try em post back if you're as impressed as I am!
#3 (permalink) |
![]() Yes I have tried these as well can't remember were I found them.
But flies great. ![]() |
#4 (permalink) |
![]() Everything stock except extra washers on feathering shaft
and extended carbon fiber boom. |
#5 (permalink) |
![]() Yep, these settings are KILLER! I think that they were posted on this forum somewhere before, but good to bring these up to the top.
Can/should we make this posting a sticky? I know that many will benefit from having these settings handy. ![]() |
#6 (permalink) |
![]() Just for reference, here is the posting where I originally found the settings. I *believe* they are the same settings.
https://www.helifreak.com/showthread...highlight=dx6i |
#7 (permalink) |
![]() YES! Thats the thread I first fopund it in .I didn't have a DX6i at the tie so I printed it out and saved it in my box. Stumbled across it the other night and gave it a try. IMMEDIATELY knew I had to bring it back to the top since I saw that thrad about DX6i settings.
I posted in there I thought it was in the front of the manual because Ididn't know where I printed it from but it looked JUST like the DX6i setup table in front of the mCPX manual so I assumed.
#8 (permalink) |
![]() One would assume that these settings would need to be used AFTER the MMM has been applied, right?
If you search over at RCG in the main MSRX thread just after the helicopter was released, there are a LOT of people who posted their settings. This was before the MMM caught on and as you can see, the settings are ALL OVER THE PLACE. One can only assume it was because everyone's heli had different link lengths. Here are the links that I farmed from that thread... http://www.rcgroups.com/forums/showp...postcount=1350 http://www.rcgroups.com/forums/showp...postcount=1363 http://www.rcgroups.com/forums/showp...postcount=1426 http://www.rcgroups.com/forums/showp...postcount=1454 http://www.rcgroups.com/forums/showp...postcount=1660 http://www.rcgroups.com/forums/showp...postcount=1673 http://www.rcgroups.com/forums/showp...postcount=3178 Most of these are pictures of people's mix screens while others are just textual. So, just be careful. YMMV depending on how you have your link lengths set. |
#9 (permalink) | |
![]() Quote:
YES, after the MM mod works best IMO.
#10 (permalink) |
![]() Tried out these setting today and they are pretty good. I had to be quick on the thumbs. Not for flying around the house, for me anyways.
#11 (permalink) |
![]() Hate to pick a bone here, but the mm "mod" is not a mod, it is an adjustment. The servo rods are made to be adjustable (you can lenghten or shorten them). This "mod" is also known as "leveling your swashplate". Changing or replacing a part is a modification. Tightening your blades or leveling a swashplate are adjustments. You might notice RKH sells an "MSRX Swash Leveler", not a "MM Mod Tool". Although it is necessary to do in order to have an MSRX fly predictably , it is not a new concept at all. In the begining many people thought the AS3X did this for you, it does not. It needs to be done on all CP helis and (I believe) all flybarless birds, since there is no flybar for "automatic" leveling. Try flying an MCPX with an unlevel swash. BTW, those are good settings , although the mixes are not necessary. Use your thumbs, they are much more relilable in the long run and adapt much better to different reactions (of the heli) at different speeds.
A few little birds... |
#12 (permalink) |
![]() Wanted to offer some personal preferences to the above settings.
Aile D/R at 75% (normal mode) A bit of expo. on the ELEV and AILE D/R will give a bit more control for technical manoeuvres. (This is really a personal preference for each pilot to use as needed / prefered) Elevator at 115% to 120% (or more for loops) - faster forward / reverse flight and needed for "loops" (not so pretty MSRX "D" loops) Aileron at 105% - just a bit more. Note: I do not do "rolls", not sure if it's even possible, but you had better bump it up as with my elevator setting if you want to try. Rudder at 125% -max out here for (quicker) pirouttes (no risk to servo as none is used for rudder input). The mSRX is on the slow side with piros, this helps a bit. Also dosen't hurt left turns.
#13 (permalink) |
![]() does anyone have the those mix settings for dx9 or similar radio where the mixes are set up using 7 point curve? I am not sure how to set up the dx6i mix settings on my dx9
Mcpx: HP08 13k, xp12a flashed, HP03t tail and hyperion 550. Msrx, MQX hybird, Nano CPX |
#14 (permalink) |
![]() Since you're actually moving the swash AWAY from level I'd still say it's a modification to the intended design of the helicopter. They intended it to be flown with a level swash. Most of us prefer it to be angled forward and to the left.
#15 (permalink) | |
![]() Everyone: I apologise for being off topic, however...
Sorry B-O-B, respectfully, I must disagree. If you agree that the the swash servo rods are made to be adjustable by screwing them in and out (they obviously are, that's why they are threaded), then you would have to agree that screwing them in and out would be an adjustment. For example; changing the position of your car seat is not a modification, it is an adjustment. The seat is made / designed to be adjustable (as are the servo rods). Using something in the capacity it was meant to be used is not a modification. Attaching the seat on the roof would be a modification. Replacing the seat with another type of seat would be a modification. Cutting holes in the seat would be a modification. Quote:
The fact that many people prefer their swash one way or another has nothing to do with what I'm getting at. Many people prefer their swash to be adjusted forward and to the left, I agree. In addition, if you read the mm mod, the word used to discribe what you have to do is "adjust", not "modify". Should servo travel adjustment be called servo travel modification? I will give you that, (technically, as defined by a dictionary) any change could be considered a modification. But, if you button up all of the buttons on a shirt or half the buttons on a shirt (according to your preference), are you modifing the shirt? Technically, yes, but in reality (in a practical sense), absolutly not. A combination of fixed adjustments (tweeks) to achive a given result, might be called a set up. A combination of variable adjustments (tweeks) to achive a given result, might be called a system. It should have been called the M(artyn) M(cKinney) (Swashplate) Set Up System. Because that's really what it is (No offence toys2cars2toys) There, I'm done.
#16 (permalink) |
![]() SO then TECHNICALLY it is a mod
![]() And yes aileron rolls are ENTIRELY possible. I'd love to get a DX6i setup that EXACTLY replicates the high rate settings of the MLP4DSM. I wonder if Horizon could get me pointed in the right direction.
#17 (permalink) |
![]() Yes, just not in the real world!
![]() ![]() What % do you set your servo travel "modification" at for rolls and flips? PS, didn't you like my new name for the "mmm"?
#18 (permalink) | |
![]() Quote:
I've done them on the Mix 2 settings with this TX.(flips so far) I'm still trying to get the settings to duplicate the high rate settings of the stock MLP4DSM. Thats what I use to do all my acrobatics.
#19 (permalink) |
![]() I used the MLP4DSM when I first got my MSRX and I hated it. Then I set up my Dx6i (that I used for an MCPX) for the MSRX and started loving the bird. I had to have my DX6i serviced a few months back and was forced back to the MLP4DSM for a couple of weeks, and I absolutely loved it! I still use it (the MLP4DSM) when I want to "travel light". Obviously the DX6i is superior, but the the stock remote (in high rate) is a solid preformer. But only once you are used to the bird.
Don't think HH will be much help with settings.
#20 (permalink) | |
![]() Quote:
I was on the phone for 45 minutes before anyone ever even picked up. Then they assured me that if I bind as an airplane (not gonna happen, love me some TH) and flip to the high rates it should be exactly the same. Yeah well, it's not. LOL. The MLP4DSM gives me MUCH tighter flips and rolls than the DX6i even on 125% servo travel programmed in.
