Closed Thread
Old 08-21-2012, 08:05 PM   #1 (permalink)
Default Alees Rush 750 setup thread
there wasnt one so i thought i'd start one, maybe it can be a "sticky".
since i dont have one yet, i have just paided for my last part and should have everything this week or next waiting for a airframe to go in.
i went with a HV set up on this heli and its my first go at a Hv set up.
here is what i went with.....
KDE 700xf-495
AR7100BX
MKS 665HV cyclic
MKS 669HV rudder
Castle ice2 120HV esc
WR hercules super BEC
radix 713mm main blades blades
radix 110mm tail blades
2 spider 5300 30c 6s packs
how does that sound ?
dodgeboy is offline        Quick reply to this message
Old 08-21-2012, 08:17 PM   #2 (permalink)
Looks good to me!
With your bec of choice (same one I have), you could ditch the flight battery and save some weight.. Plus, I think minimum recommended is 3s battery to the WR bec
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Quick reply to this message
Old 08-21-2012, 08:26 PM   #3 (permalink)
Here is my setup
Scorpion HKIII-4035-500Kv
Kontronik Heli Jive 120+HV
MicroBeastX V3.0
Outrage Torq BL9180 Cyclic Servos
Outrage Torq BL9188 Tail Servo
Spektrum AR7110 Receiver w/ Regulator & 2 Satellites
GensAce 6S 30C 5300mah x2 Flight Packs
SkyLiPo 2S 25C 2650mah Rx Pack
Edge 713mm FBL Main Blades
Edge 115mm CF Tail Blades
Eventually I will upgrade to Edge 753mm Mains when the longer boom comes out.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Quick reply to this message
Old 08-21-2012, 08:27 PM   #4 (permalink)
My planned setup is as follows:
Scorpion HK3 4035 - 500
Kontronik 120 HV
3x Torq 9180
1x Torq 9188
2s Lipo reciever Pack
Beastx V3
Edge 693 SE
Edge Tails
2x Spyder 5300's
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Quick reply to this message
Old 08-21-2012, 08:40 PM   #5 (permalink)
Originally Posted by eagleridge View Post
Looks good to me!
i cant find anywhere where is says that. im in no way doubting you. just cant find a answer either way. if i were to drop the rx pack, do you wire up the BEC like you would do a CC pro bec to 6s ?
Old 08-21-2012, 08:54 PM   #6 (permalink)
A little snippet from WR website
SPECIFICATIONS:
FEATURES:
Height ----- 15mm
l Compact high efficiency 5V or 6V
Width ----- 27mm switching voltage regulator.
Length ----- 54mm l Wide input voltage range from 9V
Weight ----- 33 grams to 60V.
(8-30 NiCd/NiMH or 3-14 LiPoCells)
http://www.western-robotics.com/hercules-BEC-HV_hp.html
I wired mine to 12s, just like Charley..
Kevin Williams
Team OFH
Old 08-21-2012, 08:59 PM   #7 (permalink)
thanks kevin. oh well, thankfully that pack wasnt much. im sure i'll use it on something else.
so kevin, you or charley are not using a flight pack, just a bec ?
Old 08-21-2012, 09:06 PM   #8 (permalink)
Yeah.. You will still find uses for it.. I actually was gonna go the flight battery direction..CHarley was like "nah man, just run it off the mains.. It works great and saves weight" I wired in
a deans harness so that I could plug in a flight pack for setup without having to power the motor and ESC... You could use that battery for that purpose.. Reason being to wire 12s, is obviously the bec will draw power more evenly from both 6s packs instead of more draw from just one pack..
Kevin Williams
Team OFH
Old 08-21-2012, 09:16 PM   #9 (permalink)
i understand that but the reason why i asked is because, with a CC PRO BEC they say to wire it up to 6s cause it can fail if hooked up to 12s. but thats great i can ditch the flight pack and hook up the WR bec up properly to 12s. thanks alot kevin !
Old 08-21-2012, 09:43 PM   #10 (permalink)
I have read about the Bec Pro smoking on 12s... But, I have a buddy that has one on 12s on his Fusion and no problems.. Guess its luck of the draw.. I think the WR is a much better piece!
Kevin Williams
Team OFH
Old 08-21-2012, 10:17 PM   #11 (permalink)
Originally Posted by backburner1955 View Post
Here is my setup
MicroBeastX V3.0
how much flight time do you get with that? and what headspeed are you running? is there a big difference between the 693 and 713 mains as far as flight time goes?
Richard Zappe
Old 08-21-2012, 10:38 PM   #12 (permalink)
I haven't even built it yet... I have been so busy with work and the kids, no time yet. I will get it built real soon. Actually, I dont think there will be much difference with the 713's, that is only like 2 1/2" larger disc than 693's.
Bryan AMA# 982814
"No-Neck R/C"
Old 08-22-2012, 12:11 AM   #13 (permalink)
I have the following parts at the moment...
Align:
700MX 510kv
DS610 cyclics
DS650 tail
CC Ice 2 120HV
Edge 713mm FBL mains
2x 6S 5000maH 45C Lipos
Gyro TBD
Will most likely go with a WR BEC
As funds allow I will change out the Align stuff, and possibly the CC. I have Torqs, a HKIII 4035 and YGE in my Fusion, so will move in that direction as well.
I am a little confused about motor choices... I have a HKIII 4035 530 in the Fusion, what motor would give a similar feeling of power in the Rush swinging 713mm, and a heavier heli???
Diabolo, Fusion 50, Goblin 500, Mini Protos stretch 6S
Controlled sometimes by a DX18
The claw NZ is offline        Quick reply to this message
Old 08-22-2012, 02:04 PM   #14 (permalink)
Xera 4530-500KV
YGE 120HV (maybe 160?)
Spektrum AR7200BX
Western Robotics Super BEC
Edge 693mm FBL Main Blades
Edge 105mm CF Tail Blades
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX
Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451
wolfdown is offline        Quick reply to this message
Old 08-22-2012, 02:10 PM   #15 (permalink)
you would have to go up to a KDE motor or a 4525 scorpion to get that kind of feel which would suck your batteries dry cause you have so much more of a disk a 4035 is plenty of motor for this bird a 4035 is actually a good bit more powerful than a 700mx.
Richard Zappe
Old 08-22-2012, 04:14 PM   #16 (permalink)
hmmmm, maybe I'll swap the 4035 from the Fusion then and sell the 700MX to help fund the 4025 or Quantum 4125 that I had originally planned for the Fusion until I got a good deal on a new 4035...
Old 08-22-2012, 04:21 PM   #17 (permalink)
Why not the 4530? That should get you in the same flight characteristics. I'm thinking that or the KDE. Suck them batts!!
Sent from my Tapatalk using iPhone.
Goblin 500 Sport HW 100v3 Brain2 KST Rail 516
Pr˘tos stretch AR7200BX Sav÷x 1250/1290MG Switch 473
180CFX DX18
RCHN #0650 AMA# 448427
th0rg0d is offline        Quick reply to this message
Old 08-22-2012, 06:00 PM   #18 (permalink)
My setup:
Scorpion HKIII 4035-500
Castle ICE2 120HV with EC5 connectors
2500mah Lipo receiver pack
AR7200BX Flybarless controller and receiver with a Spektrum DSMX satellite
JR8917 Cyclics
Torq 9188 tail servo
Edge 693SE main blades
Edge 115SE tail blades
+-12 degrees collective pitch
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 08-22-2012, 07:48 PM   #19 (permalink)
my finel set up
scorpan 4035-560 liked this ran a bit hot.... Have a savox 530kv motor in it now runs great
saxox sb2274sg cyclic
savox sb2272mg tail
CC ice 120HV2 might switch to a 160
Blades were spin blades but trying out the new blades from herizon
And magnum energy 75c packs
codfish124 is offline        Quick reply to this message
Old 08-22-2012, 08:22 PM   #20 (permalink)
My setup
Ar7200BX
Hobbywing 120HV Platinum Esc
Scorpion 4035-500kv
WR Hercules Super bec
Ds610's on cyclic
Mks HBL669 HV tail servo
Edge 693SE mains
Edge 105 tails
Kevin Williams
Team OFH
Closed Thread
