Closed Thread
Old 01-07-2014, 07:51 PM   #261 (permalink)
Sorry Saeed, just having a little fun at your expense. No offense intended. One of my favorite NCIS characters Ziva, an Israeli in DC, is always mixing her metaphors. Adds to her charm!
Steve Graham is offline        Quick reply to this message
Old 01-07-2014, 08:42 PM   #262 (permalink)
Default Re: Alees Rush 750 setup thread
No worries
Saeed
saeed09 is offline        Quick reply to this message
Old 01-13-2014, 07:05 PM   #263 (permalink)
Default Re: Whats your set up
The rush getting decked out with spektrum controls now she just needs motor and esc then gaged out and she will maiden hopefull around march so far its got
edge se 693 and 115 blades
Spektrum H6200 on cyclic
Spektrum H6210 on tail
Ar7200bx Dx8
Pulse 2550 rx batt
Pulse 6s 5000 45c batt
Esc and motor are undecided will probably go with castle and kde
Rc Zombie is offline        Quick reply to this message
Old 01-13-2014, 07:21 PM   #264 (permalink)
Here is my setup
Scorpion HKIII-4035-500Kv
Kontronik Heli Jive 120+HV
Skookum SK540 with 2 DSMX Satellites
MKS 665 Hv Cyclic Servos
MKS 669 Hv Tail Servo
GensAce 6S 30C 5300mah x2 Flight Packs
SkyLiPo 2S 25C 2650mah Rx Pack
Scorpion Back Up Guard
Edge 713mm FBL Main Blades
Edge 115mm CF Tail Blades
Heli Option quick release canopy mounts (t-Rex 700 and 550 I believe)
Align 700 Carbon Tail Rod w/ quick uk rocket links and Align guides.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Quick reply to this message
Old 01-13-2014, 09:01 PM   #265 (permalink)
Mine is set up like this
Jr 8717 hv cyclic
futaba bls256hv tail servo
vbar full size hooked up to futaba sbus receiver
castle bec pro
Kde 700-495 motor
Castle edge 160 hv
pulse 5000 45c and 65c batteries
rail 716 main blades
rail 115 tail blades
Rc booya canopy mounts
All flown with a futaba 14sg radio
Ryan Sams
Team Evolution, Team JR, Team Velos Rotors, Team KDE Direct, Team MSH Brain, Team KBDD International, Team Morgan Fuels
Rsams is offline        Quick reply to this message
Old 01-13-2014, 09:09 PM   #266 (permalink)
My Setup is as follows:
Protek 250T's on cyclic
Futaba BLS 256 on the tail
Mikado silverline full size vbar w Pro
Gryphon Quasar HV Bec
KDE 700-495 KV Motor
MegaPower 120 HV ESC
Pulse Ultra 6s 5000s 65c
Edge 713se mains
rail 116 tails
RC Booya mounts on the back.
quick uk thumb screws on the fronts.
JR XG14 DMSS
Scorpion Motors
XPERT Servos
Lynx
bigballajeff is offline        Quick reply to this message
Old 01-13-2014, 09:46 PM   #267 (permalink)
Final setup TBD but this is the current plan
Motor: Scorp 4525-520
Pinion: 12t
ESC: Castle Edge 160
Cyclic: Protek or Futaba HV
Tail: Futaba 256 HV
FBL: ikon or vbar silver
Gov: vbar/ikon target hs 2200
Batts: 4400 45c
Blades: Cyclone main Edge 115 tail
RX: Futaba 6208SB
Possible change in plans would be a KDE 700xf-495 or Scorp 4530-540 motor
Looking for 3:30 - 4:00 flight times medium 3D
Low speed, high drag
Otto Rotation is offline        Quick reply to this message
Old 01-13-2014, 10:54 PM   #268 (permalink)
no need to make 2 threads with all the same info in it. there is a set up thread up top.
dodgeboy is offline        Quick reply to this message
Old 01-14-2014, 02:52 AM   #269 (permalink)
Agreed, have a mod dump this thread.
Anthony.L is offline        Quick reply to this message
Old 01-14-2014, 10:33 AM   #270 (permalink)
Default Whats your set up
Or if the OP would be kind enough to lock it then it will fade away.
DiceK is offline        Quick reply to this message
Old 01-14-2014, 11:55 AM   #271 (permalink)
It can be merged with the sticky thread, if a Mod is contacted about it...
Bryan AMA# 982814
"No-Neck R/C"
Old 01-14-2014, 12:20 PM   #272 (permalink)
I've contacted a mod.
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 01-14-2014, 07:25 PM   #273 (permalink)
I tried I do not have permission
Old 01-14-2014, 09:54 PM   #274 (permalink)
at the bottom of your next post there is a small box to check that says "close this thread"
Old 01-15-2014, 01:58 AM   #275 (permalink)
closed thread
Old 01-15-2014, 08:12 AM   #276 (permalink)
Member
Merged.
Bob O is offline        Quick reply to this message
Old 01-15-2014, 08:20 AM   #277 (permalink)
Thank you, Bob!
Scott
KBDD Team Pilot ):>
Old 01-15-2014, 09:58 PM   #278 (permalink)
Default Alees Rush 750 setup thread
Here is my setup.
Motor: Scorpion 4525-520
Pinion: 12t
ESC: kosmik 200
Cyclic: Mks bls950
Tail: Mks bls980
FBL: vbar blue pro
Gov: kontronik
Batts: 4400 45c or 5000 60c
Blades: Cyclone main, Rails 116 tail
RX: Spektrum
Kosmik is right now an overkill but got it at a good deal and I have future plans of 14s setup.
Victor M.
MikadoUsa/Scorpion Power Systems/Xpert Servos
vmalpi is offline        Quick reply to this message
Old 01-16-2014, 05:55 AM   #279 (permalink)
Damn!!!! That's a lot of ESC, there bro---in every way!!! Looks great, though!!!
Scott
KBDD Team Pilot ):>
Old 01-23-2014, 03:49 AM   #280 (permalink)
What blade size would u guys recommend for a sport flyer.
Will most likely be radix 110mm on the tail and 690 or 710 mainblades.
This is my setup
Scorpion 4525-520kv Limited Edition
Fusion Hawk 120A
12T pinion
5000mAh 40C
I would like to run 1900rpm but not sure the esc will hold up.
According to MrMels calc 2154rpm is my sweetspot with the gov in vbar or sk540.
Got both vbar and sk540 havent decide wich one to put in the rush.
I have seen some of u use the align 11T and i might try that.
So 710 or 690 for sport flying at 1900rpm ?
Pirre is offline        Quick reply to this message
Closed Thread
