Closed Thread
Old 01-23-2014, 07:37 AM   #281 (permalink)
I think 710's would be better for you. Especially with lower head speeds like 1900. For me on 713's I needed to be at least at 2000 with 12.5 degrees of pitch for my Big Air/3D style. My bird is heavier than most so you may be ok. Give it a try and then increase as needed.
When I was running 1900-2000 I was able to fly for almost 6.5 minutes on 5000mah 14s. If you are running 5000mah 12s you should be able to get 5.5-6 minutes at that lower head speed.
Scorpion Power Systems
Michaelinpr is offline        Quick reply to this message
Old 01-30-2014, 01:09 PM   #282 (permalink)
Now that I either have everything in hand, or purchased and currently en route, it's time to post the final setup.
AleeS Rush 750 w/ 750 stretch kit
ESC: YGE 160HV Heatsink
Motor: Quantum 4530-450kv
Pinion: 12T (target 1900HS)
RX: Futaba R6202SBW
TX: Futaba 12Z
FBL: VBar Fullsize Black
Cyclic Servo: Futaba BLS252
Tail Servo: Futaba BLS251
BEC: WR Hercules Super Mini G2 (set to 6v)
Main Blades: Edge 753mm
Tail Blades: Edge 116mm
Main Battery: Pulse 6S 5500mAh 45C
RX Battery: Pulse 3S 1350mAh 35C
I maybe be cracking the box this weekend, pics to follow...
Anthony.L is offline        Quick reply to this message
Old 01-30-2014, 01:29 PM   #283 (permalink)
Enjoy your build. Remember, if you have any questions, please be sure to ask. Also, please check out our Tech Tip videos in the sticky!
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 01-30-2014, 02:07 PM   #284 (permalink)
Scott
I've already watched all your tech tip videos, thanks for taking the time to record and post those. I've done those in the past, and know how much work it is.
If it wasn't for Super Bowl this weekend it would probably be done. GO HAWKS!
Old 02-14-2014, 08:28 PM   #285 (permalink)
I've got a chance this year to fly a set of 713's. Will I be ok on my 2000 HS with those blades. I know they are bigger, and it takes more power to rotate them. This is all relatively new to me. I'm thinking I'll be ok at the 2000 HS.
It was so much easier flying 50 sized Sceadu's with OS 50 Hyper's and 600mm blades! LOL!!
Don't scold me! LOL!
Where do the Du-Bro 1/4 scale hinges go on a helicopter???
Team Shannon, Scorpion Power Systems and TailDraggerRC. Thank you all!
chris-fry is offline        Quick reply to this message
Old 02-14-2014, 08:30 PM   #286 (permalink)
You will be fine Chris!
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Quick reply to this message
Old 02-14-2014, 08:52 PM   #287 (permalink)
I think you will be better off with 713's. Based on your head speed and your sprt style you will find the heli much more stable and a bit lower disc loading.
Old 02-14-2014, 09:07 PM   #288 (permalink)
I run 1900 HS with 713's and it flies awesome! I do big sky stuff with some 3D. I've never had an inkling of a bog or drop in HS.
Logo 690sx / Logo 480 Xtreme / Goblin 570 /
QAV 250
[/SIZE][/SIZE][/COLOR]
[/COLOR][/SIZE]
foolforspeed is offline        Quick reply to this message
Old 02-15-2014, 10:04 AM   #289 (permalink)
chris, just so you know those very blades have been on my Rush at 2250 for a year. they worked just fine.
dodgeboy is offline        Quick reply to this message
Old 02-17-2014, 04:32 PM   #290 (permalink)
My Rush setup's finalized now, just need to start building. Maybe this week.
Motor: Scorp 4525-520 Ultimate, 12t pinion
ESC: Castle Edge 160HV
BEC: 2S LiPo 2600mah
Servos: BK 7001HV cyclic, Futaba 256HV tail
FBL: Vbar Silverline
Blades: Cyclone 695 / Edge 115
Packs: 4400mah 45C
Head speed: 2200 Vbar governed
Low speed, high drag
Otto Rotation is offline        Quick reply to this message
Old 02-17-2014, 06:14 PM   #291 (permalink)
Nice, that thing should haul! Post lots of build pics!
Old 03-22-2014, 03:04 AM   #292 (permalink)
Default scorpion 4035-560kv esc yge
hello friends Woodhelven me ask you .... I have a motor scorpion 4035-560kv and YGE 120hv drive, I would like to know which is the correct timing, since the engine low me about 60 degree heat, and the inverter as an little hot too, thanks greetings
javidjtech is offline        Quick reply to this message
Old 03-22-2014, 07:44 AM   #293 (permalink)
Creo que entiendo tu pregunta pero el traductor de google no funciona bien a veces. Dime tu pregunta en Espaņol.
Creo que 18 grados. YGE es un poquito diferente que otra marcas.
Viste el Sticky en el foro de YGE?
https://www.helifreak.com/showthread.php?t=345959
Lea todo que el dice. El hablo del timing.
Old 03-22-2014, 03:42 PM   #294 (permalink)
gracias Michelimpr, queria preguntar acerca de la configuracion que tengo en el rush 750, me gustaria saber que timing poner en el yge para que el motor y el variador baje lo mas frio posible, tengo un yge de 120 hv y un motor scorpion de 4035-560kv. gracias por tu ayuda michelimpr, ahora mirare el hilo que me has dejado de 120 hv, saludos
Old 03-22-2014, 09:11 PM   #295 (permalink)
Built, tweaked, tested and flown....
Rush 750 with 750 stretch kit
Carbon Skids (Nice upgrade) gives good tail blade clearance from ground
KDE 700XF-495
CC Ice 160HV
Grey Reactor HVX
HV servos
753mm Edge main blades
116mm Rail tail blades
Blue-line full size V-bar (pro software)
5800mah 6s 45c Glacier packs
1800mah 3s glacier flight pack
Flys like a dream
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Quick reply to this message
Old 03-22-2014, 09:27 PM   #296 (permalink)
Sweet! But one problem, where are the PICS?!?!
Old 03-23-2014, 09:49 AM   #297 (permalink)
KDE 700XF-495
CC Ice 160HV
Grey Reactor HVX
HV servos
Flys like a dream
and the pics
Name:	2014-03-23 09.45.05.jpg
ID:	496822   Click image for larger version
Name:	2014-03-23 09.45.54.jpg
ID:	496823   Click image for larger version
Name:	2014-03-23 09.45.29.jpg
Old 03-23-2014, 01:08 PM   #298 (permalink)
Looks great Satgod! Only one quick suggestion: Use more than one strap to hold your batteries in. Velcro is good, but even with my flying, I use two straps in addition to velcro per battery.
Scott
KBDD Team Pilot ):>
Old 03-24-2014, 06:27 AM   #299 (permalink)
Ok.......como dije, creo que 18 grados ayuda par bajar mas frio. Si tu motor dice en los specificaciones a 5, entonces 18grados es correcto.
Trata a usar google translate para traducir el primer post del hilo en el foro de yge que te mencione.
Old 03-25-2014, 06:24 PM   #300 (permalink)
thanks Michaelinpr, this weekend I try and tell you the outcome, thanks for your help ...
Closed Thread
