Closed Thread
Old 09-16-2012, 11:50 PM   #61 (permalink)
Originally Posted by dunkonu23 View Post
Yes. A shaft length of 39-41mm is necessary.
Scott
Cant find a drawing on this, will the align 700mx 510 shaft be long enough to run on the Rush?
chrisansilver is offline        Quick reply to this message
Old 09-17-2012, 12:41 AM   #62 (permalink)
The Align MX motor's shaft is A-OK.
-Jay
Major Equipment Sponsor - AdventureRC
Discount_Bob is offline        Quick reply to this message
Old 09-17-2012, 12:47 AM   #63 (permalink)
The 700MX has a 36mm shaft, it may work...
The Scorpion has a 38mm shaft.
http://www.scorpionsystem.com/files/..._dimension.pdf
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Quick reply to this message
Old 09-17-2012, 12:54 AM   #64 (permalink)
Scott
So this should be 36mm-41mm for the required shaft length.
Bryan AMA# 982814
"No-Neck R/C"
Old 09-17-2012, 01:38 AM   #65 (permalink)
I was gonna go to bed 30 minutes ago, but I pulled mine apart just to verify. The 36mm 700MX shaft does indeed go into the support bearing. Not by a lot, but it certainly does extend into the lower bearing and provide enough for the pinion to rest on the bearing and fit appropriately.
-Jay
Old 09-17-2012, 02:34 AM   #66 (permalink)
Originally Posted by PePito_ View Post
So jamin_00 you buy the Kontronik Pyro 700-52 with the long shaft.
I trying to decide the motor and my option are
Kontronik Pyro 700-52 (Long shaft)
KDE700XF-495 KDE
Any help please
I had a spare Pyro on my bench but I had cut the shaft down so its not reaching the support. I'll be replacing the shaft with a new one this week hopefully.
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Quick reply to this message
Old 09-17-2012, 03:00 AM   #67 (permalink)
I'm waiting for a package with my Rush 750,
but the setup is ready:
- motor QUANTUM 4530- 500KV
- ESC Kontronik Heli Jive 120
- 2 x 6S TP 5000 65C G6
- Futaba BLS 255 HV + BLS 256 HV
- rx Futaba R7008SB
- MICROBEAST
- blades SAB 710 + SAB 115
Kulichik is offline        Quick reply to this message
Old 09-17-2012, 05:18 AM   #68 (permalink)
Most likely. I only considered the two motor shafts I know work.
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 09-17-2012, 07:00 AM   #69 (permalink)
Good, thanks.
Old 09-17-2012, 07:45 AM   #70 (permalink)
My motor shaft sticks out the bottom of the bearing. That's the KDE 700XF-495.
dodgeboy is offline        Quick reply to this message
Old 09-17-2012, 08:10 AM   #71 (permalink)
Mike,
That is not an issue unless it rubs on something. Do you know about how much it sticks out? It would be a good gauge to see how long of a shaft is needed.
Scott
KBDD Team Pilot ):>
Old 09-17-2012, 08:25 AM   #72 (permalink)
i'll measure it when i get home today
Old 09-17-2012, 08:27 AM   #73 (permalink)
Thank you, sir!
Scott
KBDD Team Pilot ):>
Old 09-17-2012, 11:08 AM   #74 (permalink)
- rx Futaba R7008SB
- MICROBEAST
Alright My friend!!! glad to see you in here
Charley Stephens
Charley Stephens is offline        Quick reply to this message
Old 09-17-2012, 01:11 PM   #75 (permalink)
Will the scorpion hk3 530kv motor work with a 12s set up 5000mah, and the standard pinion using a scorpion esc?
gashead is offline        Quick reply to this message
Old 09-17-2012, 01:39 PM   #76 (permalink)
I see no reason why it wouldn't, though I don't use a Scorpion ESC.
Scott
KBDD Team Pilot ):>
Old 09-17-2012, 02:38 PM   #77 (permalink)
It all depends on the govenor. If its more like a helijive then no you need the 500 kv if its more like castle on its headroom then yes a 530 is perfect. 2200 is about the most headspeed you want out of a 700 size and if you can keep the motor at the top end of the governing scale then it will be much more efficient and have more torque.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Quick reply to this message
Old 09-17-2012, 10:00 PM   #78 (permalink)
the shaft on my KDE motor sticks out of the bottom of the pinion support bearing by 4mm.
its not in anyway close to touching anything but it gives you a idea of how long my shaft is i couldnt help my self
Old 09-17-2012, 10:14 PM   #79 (permalink)
Bryan AMA# 982814
"No-Neck R/C"
Old 09-17-2012, 10:33 PM   #80 (permalink)
I'm using the Align 700MX 530kv and the Scorpion V 130A ESC; however, I'm using the VBar governor for it's awesomeness and have never tried the Scorp gov. The governor on the Scorpion allows for much higher headspeed- 2600 rpm with a 530kv motor, down to about 2100 with the 12T pinion.
While I certainly wouldn't run it at 2600, if you're looking to go for around 2200 you'd be fine (in my opinion).
-Jay
Closed Thread
