Closed Thread
Old 02-07-2013, 06:52 PM   #121 (permalink)
Default Re: Alees Rush 750 setup thread
Originally Posted by jmdanna View Post
it's an original. well from what I've heard, the higher res isn't really noticeable. maybe when my transmitter dies I'll upgrade, but for now I'll stick with my DX7
Well, from my experience its 100% noticable and helps alot if you need the feel of high cylics at low mechanical settup. The frame rate is double of that of the normal dx7. 11ms and 22ms!?? This means your stick inputs will be 2X faster! Its not only about speed but the resolution changes the feel and make you more connected.
Trust me its worthy
Saeed.
saeed09 is offline        Quick reply to this message
Old 02-07-2013, 09:08 PM   #122 (permalink)
I understand... it's just not worth the extra money to me right now to buy a new expensive radio and new sats for both my helicopters... they are both older type dsm2 sats. it would be a costly upgrade
Jacob
Rush 700, Synergy N5c tt, MA Fury 55, Trex 450 pro, Blade 130X
jmdanna is offline        Quick reply to this message
Old 02-08-2013, 12:50 AM   #123 (permalink)
Buy a used JR X9503 or X 9303, both are DSM2 and no sat upgrades are needed. You then can sell the DX7, which is still highly sought after.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Quick reply to this message
Old 02-08-2013, 09:21 AM   #124 (permalink)
my satellites aren't the higher resolution though...
Jacob
Old 02-08-2013, 09:53 AM   #125 (permalink)
I am using a Dx7 with dsmx satellites as they are backwards compatible. I chose to run dsmx sats because a Dx8 is in my near future.
Sent from my XT907 using Tapatalk 2
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Quick reply to this message
Old 02-08-2013, 10:01 AM   #126 (permalink)
Just so everyone knows, to my knowledge, the DX7 can be upgraded to DSMX.
http://www.horizonhobby.com/products...only-SPMDX7UPG
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 02-08-2013, 01:26 PM   #127 (permalink)
DSMX doesn't mean high-res does it? I thought it just depended on the transmitter. Isn't the DX7se a DSM2 transmitter?
Jacob
Old 02-08-2013, 04:04 PM   #128 (permalink)
You'll have to research that one, Jake. To my knowledge DSMX is 2048bits with either 11 or 22ms latency. Whether or not you can use 11ms latency on your DX7, I don't know.
Edit: Perhaps the easiest thing to do is just give Horizon a call. I'm sure they'll know.
Scott
KBDD Team Pilot ):>
Old 02-08-2013, 06:13 PM   #129 (permalink)
A Main Hobbies/ProTekRC Field Rep
Spartan RC Field Rep
Todd Moriarty is offline        Quick reply to this message
Old 02-08-2013, 10:47 PM   #130 (permalink)
Jake don't sweat it bro. Im using my trusty old jr9303 and have no issues. Keep what you got.
dodgeboy is offline        Quick reply to this message
Old 02-09-2013, 12:52 AM   #131 (permalink)
I tried it at 2200 and I didn't care for the extra weight as I have to run at least 5000's to get 4 minute flight. I like the way the 4400's fly cause it shaves like half a pound off the machine at the cost of having to run a lower headpeed to have a respectable flight time. To me this is a good trade-off.
gbiggs1986 is offline        Quick reply to this message
Old 02-09-2013, 12:56 AM   #132 (permalink)
Today I was going over my heli and noticed that the maingear has up and down play. There is no up and down play on the mainshaft. Is this normal?
Old 02-09-2013, 07:45 AM   #133 (permalink)
Readjust your lower bearing block to remove all slop
Old 02-09-2013, 10:21 AM   #134 (permalink)
+1 Mike.
How much up and down play?
One more question: Are the screws for the hub and the hub to main gear screws tight?
The reason I asked how much is this: Sometimes, through normal use or by design, one way bearings may need just a tiny bit of up/down play in order to work properly.
Scott
KBDD Team Pilot ):>
Old 02-09-2013, 04:03 PM   #135 (permalink)
Maybe 2mm up and down. Al screws are tight. I talked to bobby smith about it and he says his is the same way so I guess it's something I never noticed.
Old 02-09-2013, 08:19 PM   #136 (permalink)
I checked mine, it's normal. Don't worry.
Scott
KBDD Team Pilot ):>
Old 02-09-2013, 11:36 PM   #137 (permalink)
2mm up and down ? mine doesnt move at all. i would think 2mm would throw off your pitch at some point. i learned from another heli i had that had the same type of adjustable bearing block to really wrench down on those mounts screws.
Old 02-10-2013, 12:05 AM   #138 (permalink)
Just checked mine.. It does it also..
Dodge... They are talking about just the main gear moving up and down.. Not the mainshaft, so there should be no pitch problems
Kevin Williams
Team OFH
Old 02-10-2013, 12:42 AM   #139 (permalink)
Mike,
It's just the way OWB's work, bro. No big deal.
Scott
KBDD Team Pilot ):>
Old 02-10-2013, 05:20 AM   #140 (permalink)
He said there is no play on the shaft and only play on the main gear! This means the auto gear has no axial play. I agree with Scott that should be fine. It could be the auto bearing barell/sleeve is designed to be alittle taller by few mm to give a play on the main gear. I will confirm when i get close to mines though.
Saeed.
Closed Thread
