NX4 Photos and Videos - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Like Tree5Likes
Old 08-28-2012, 09:40 AM   #1 (permalink)
Registered User
Default NX4 Photos and Videos
Photo by Me crappy Cell Phone.
Photo by Experience RC
[ame]http://www.youtube.com/watch?v=EGHvWEzPguQ[/ame]
[ame]http://www.youtube.com/watch?v=AkksHvtYp90[/ame]
Pinion ITP with Bobby Watts
William James
Old 08-28-2012, 10:24 AM   #2 (permalink)
Default NX4 Photo's
Here are some photos under the hood of my NX4
JC Zankl
Empire Hobby/GAUI,PowerMaster Fuels/YS Engines/Graupner Radios/Scorpion Power Systems/Castle Creations/VTX Blades/Bavarian Demon/Velos Rotors/Xpert Servos
jczankl is offline        Reply With Quote Quick reply to this message
Old 08-28-2012, 12:03 PM   #3 (permalink)
Registered User
SWEET!!!!!! Thanks for sharing JC!!
William James
Old 08-28-2012, 12:10 PM   #4 (permalink)
Thanks for sharing JC! Couple of quick questions... given that the BLS257 is typically a rudder servo, why was it used for cyclic here? It has enough torque without risking stripping a gear on a hard maneuver?
Also, I noticed in other NX4 pictures the use of a header tank. Do you know if one will be provided in the kit or is this something extra?
Finally, do you know if blades will be included in the kit?
Thanks again!
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 08-28-2012, 12:15 PM   #5 (permalink)
Both Bobby and I flew IRCHA with Futaba BLS257's they are working great. But I really like my Savox servos.
Header Tank has not been discussed as far as I know. I think it will be a separte purchase.
My Set up is
OS 37
OS Pipe
PowerMaster 30%
Throttle Jockey Gov
Hyperion LiFe 1450 2s
Savox 1250's on Cyclic and Throttle
Savox 1257 on Tail
AR7200BX
KBDD Lime Green Dampers
KBDD 70.4mm New Edition Tail Blades
SpinBlades 435mm 3d Blades
2750HS Idle 2
Pinion ITP with me at Dusk
[ame]http://www.youtube.com/watch?v=aBqFu5cUJ0U[/ame]
JC Zankl
Old 08-28-2012, 12:21 PM   #6 (permalink)
Thanks, I just ordered up some Edge 423mm FBL blades and Edge 72mm tails. On the pipe... do you have a part number for the OS pipe? Only pipe part number I've found is for the Hatori pipe.
Can you tell we're all chomping at the bit???
AMA #934662
Old 08-28-2012, 12:39 PM   #7 (permalink)
Default Pipe
Unfortunately I don't have a part number for the OS Pipe yet.
Chomp Chomp ;-)
JC Zankl
Old 08-28-2012, 03:52 PM   #8 (permalink)
Registered User
The fact you guys released the NX4 not a 700N at IRCHA when EVERYONE was expecting a 700...... PRICELESS!! Way to go!
William James
Old 08-28-2012, 11:58 PM   #9 (permalink)
More pics
ID:	344499   Click image for larger version
ID:	344500   Click image for larger version
ID:	344501   Click image for larger version
alvinchai is offline        Reply With Quote Quick reply to this message
Old 08-29-2012, 07:36 AM   #10 (permalink)
Registered User
Originally Posted by alvinchai View Post
More pics
SWEET!!! So is the header tank to offset the weight of the pipe or just personal preference. I stopped running header tanks long ago because they were just something else to maintain but on this heli maybe I should get one for it. Not sure.
William James
Old 08-29-2012, 07:40 AM   #11 (permalink)
looks like the saddle holds about a minute and a half worth of fuel! longer is better!
Gaui X7, X5, NX4, X42, X3
Gaui USA, Empire Hobby, JR Americas, Cyclone Blades, MKS Servos USA, OptiPower Batteries,YS Engines,
PowerMaster Fuels
Pinion is offline        Reply With Quote Quick reply to this message
Old 08-29-2012, 10:40 AM   #12 (permalink)
It's there to keep the motor from leaning out. It does serve a purpose ;-)
If you watch Bobby's video's he never flys into the header.
JC Zankl
Old 08-29-2012, 10:48 AM   #13 (permalink)
Originally Posted by jczankl View Post
It's there to keep the motor from leaning out. It does serve a purpose as the small motor really can't suck through the fuel magnet.
What about an O.S. Bubbleless clunk? That's what I use on my 700N...works great. Also, I'm trying to make a decision on how I will power this heli. I know I want to stick with 2s lipo and go through a regulator. I have been going back and forth on several models, but I may have just found something small and perfect for the job:
http://www.western-robotics.com/hercules-linear_hp.html
This picture shows all the available options. If you look, one of them is a rocker switch. Any way we can get the dimensions for the opening by the nose to make sure this switch will fit in there?
Comes with this neat LED to alert you to a low battery and optional buzzer if you wanted that.
My thoughts are to use a SwitchGlo Pro for the glow driver and just use this small regulator to feed everything 6v and their switch to power it on/off. Keeps the weight down.
AMA #934662
Old 08-29-2012, 12:01 PM   #14 (permalink)
OS Bubbless clunk is really to help keep the fuel from foaming. It's really not going to help in lean part of the tank. And won't really help in foward flight toward the end of the tank. I am not running a header and had a flame out with a clunk.
I will be running a header tank. Headers are cheap. $13ish
JC Zankl
Old 08-29-2012, 02:33 PM   #15 (permalink)
Default GAUI NX4 Pictures
[IMG]http://cnrcgroups.com/data/attachment/portal/201208/28/210923***tnidutd2nfxms.jpg[/IMG]
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 08-30-2012, 04:04 PM   #16 (permalink)
any idea if they will release a combo package?
Trex 700e
hamstar78 is offline        Reply With Quote Quick reply to this message
Old 08-30-2012, 05:06 PM   #17 (permalink)
Default Hamstar
Yes there will eventually be a combo package.
JC Zankl
Old 08-31-2012, 08:31 AM   #18 (permalink)
Registered User
Thanks for the info JC.
William James
Old 08-31-2012, 08:31 AM   #19 (permalink)
Registered User
Thanks for posting those photos Matt!!
William James
Old 08-31-2012, 08:35 AM   #20 (permalink)
Thanks Matt!
It looks like the frame has a cutout towards the nose for a switch. Too bad they didn't put this someplace else where you don't have to take the canopy off to flick the switch. On my 700N, I put the switch near the tail boom, so I just flick it and never have to deal with the canopy.
AMA #934662
Human Verification
