Old 09-04-2012, 08:17 PM   #41 (permalink)
Originally Posted by BigEast View Post
lol
Another tweak for the tail:
I found my old 450 main blade aluminum spacer and thought of using this as counter weight on the tail to get a propper balanced heli.
Yes, it's not bad at all, I've changed the screw and add about 2 pcs of washer to fit on the round portion on the tail fin and filled that gap.
So did the quick balancing 'just holding the button head... end up it looks balanced. I did test the pirouette flight and it's quite stable.
ID:	346231   Click image for larger version
ID:	346232   Click image for larger version
Aries17q
CopterX 500SE V2 Flybarless, Trex 250 Pro DFC, Streched MCPx Brushless V1, Blade 130X with Spin 8000kv-9T, Lynx upgrades
Aries17q is offline        Reply With Quote Quick reply to this message
Old 09-05-2012, 10:53 PM   #42 (permalink)
Thanks for posting everything in one easy spot. I had already done most everything out of the box, as it was my second one. The first having been kept by HH as they couldn't fix it. The first things. Idi and didn't see them mentioned, but it may be in here somewhere, was replace the stock tail blades with KBDD, and remive and tighten the screws in the tail servo. They are almost always always loose from HH. Placed the 0 and 3 silicon Orings on all ball links. Second tail uide was a must as was balancing blades to remove vibration. After everything I still had wobble till I put in the steel tail shaft and MH tail blade grips with Boca Bearings. I have done nothing with the cone gears and have yet to have a problem. I know I should not have said that.
Metal A gear, was a must also. The biggest difference, after everything was still the tail shaft. That is what made the tail rock solid with. O gyro input. I just ordered the MH square Aluminum tail case, which flies in the face of my "If it ain't broke don't fix it but it looks so cool. Also the Rakon Heli aluminum Tail stabilizer fin eliminated all vibration from there. Thanks all for all the good advice that makes this hobby fun.
Birdmanpa is offline        Reply With Quote Quick reply to this message
Old 09-05-2012, 10:58 PM   #43 (permalink)
Sweet! I'll try that out
BigEast is offline        Reply With Quote Quick reply to this message
Old 09-05-2012, 11:01 PM   #44 (permalink)
Hey Birdmanpa! Thanks for commenting, that's some great insight!!
Old 09-06-2012, 12:47 AM   #45 (permalink)
Hi Birdmanpa,
Our objective is to keep this bird as flawless as it can be. Special thanks to all the guys aswell for giving their best to update us specially when it comes to extreme MODs. (You know...HP08S/Spin motors, MH and RH parts reviews etc.)
Hi BigEast,
What's new to your precious little Bird. oopsss, don't get me wrong
Aries17q
Old 09-06-2012, 01:00 PM   #46 (permalink)
[ame]http://www.youtube.com/watch?v=LxJhbZmjLoA[/ame] here is a video on how to enter the gain menu to adjust values to your preference
bigtxheli is offline        Reply With Quote Quick reply to this message
Old 09-07-2012, 07:52 PM   #47 (permalink)
I have replaced the metal TT with a carbon one, that I made from a carbon 1.5 mm rod. That along with adjusting the mesh between the gears has made a resonance free heli!
Skycommander is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 11:26 AM   #48 (permalink)
Default 13x repairs
nice post here, you gave me a couple of ideas i hadnt tried yet, both mine fly great now, i had already done a few of the fixes for these helis and now there flying great.might have to consider the others..
thanks for the info
john
radiodoctor is offline        Reply With Quote Quick reply to this message
Old 09-26-2012, 04:39 PM   #49 (permalink)
Default 130x Landing gear fix when no spare available
Broken landing gear? My hobby dealer is 2+ hour return drive and does not always have stock. So I tried zap, shoegoo, epoxy, gorilla glue and contact cement - no luck.
Heat shrink! - works great on a break. Two layers if you want it more rigid. A little slow zap on the gear first hold the heat shrink in place, heat it, and back in the air. Those short pieces that come with the Deans connectors are a perfect fit.
ID:	352811   Click image for larger version
ID:	352812   Click image for larger version
Tower is offline        Reply With Quote Quick reply to this message
Old 09-26-2012, 05:30 PM   #50 (permalink)
Yep +1, did that myself too!
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote Quick reply to this message
Old 09-27-2012, 07:58 PM   #51 (permalink)
Thumbs up You Got It Dude!!!
After looking through this forum I haven't seen a thread with a list of all the fixes/mods for the 130X, so I've compiled most of the ways to get rid of the resonance/vibration as well as the tail wag (If you have it)
If you have anything to add please do!
All fixes/mods can be found on YouTube or here on HeliFreak. Thank you to all of the people who discovered them!!
Fixes/mods:
-Balance the tail blades, this is just simple guesswork to begin with. Start by adding a piece of tape to the middle of either tail blade. Spool up, if vibrations get worse, remove the tape and add it to the other tail blade. Then adjust for maximum performance by moving the tape up and down the blade. Remember to wrap the tape around the leading edge of the blade so it doesn't fall off.
-Purchase the $3 tail pushrod guide (part# BLH3721) and install it on the tail boom between the already installed pushrod guide and the tail case. You might have to, "Open up" the interior of the guide so that the pushrod can move freely. I did this with an X-acto knife.
-CA a piece of carbon fiber to the trailing edge of the tail fin. This can reduce vibrations and strengthen the fin.
-Cut an mCPX grommet in half, then install one of the halves on the bottom of the tail on the ball where the tail pushrod attaches, and the other half on the top of the tail where the ball link is attached to the tail pitch slider.
-Remove the rubber o-rings on the swashplate as well as from the main grip arms and replace them with the included canopy grommets/mounts. This will greatly reduce play.
-Put a drop of CA in the area where the torque tube emerges from the tail boom and from the large tail gear. (Gear C)
-Push the tail boom in as far as possible until A and B gears start to bind. Then pull out ever so slightly. This reduced resonance for quite a few people.
-Straighten the tail shaft. Doing this completely terminated vibrations for many. Instructions can be found in the following link: https://www.helifreak.com/showthread.php?t=443167
-Purchase a set of Boca Bearings which will go into the tail. These bearings may significantly reduce vibration. Here are two links for where to buy them: http://www.bocabearings.com/search.a...0X+BNF&Feature
http://www.bocabearings.com/bearing-...x-bnf-electric
-If Boca Bearings don't suit you, purchase a set of BLH3727 1.5x4x1.12 Bearings. (2) Place these into the right and left side housings in the tail while keeping the stock bearings installed as well. Here's a link to the mod: https://www.helifreak.com/showthread.php?t=448222
-Adjust the gyro gains for best performance, here's a link on how to do that: https://www.helifreak.com/showthread.php?t=429592
-Purchase a steel tail shaft and/or an aluminum/titanium pitch slider from Micro Heli.
-Extend the boom supports for increased rigidity in the tail boom. This greatly cuts down on vibration. Also, add a 4mm CF tube in the frame to decrease flex. Lastly, if you do not wish to extend the boom supports, purchase the 300X supports and cut them down to fit the 130. All 3 mods can be found in this thread: https://www.helifreak.com/showthread.php?t=443278
-If all else fails, simply remove the tail fin. For some folks, this diminished most resonances.
-Lastly, here are two links to a gear mesh related fix which can reduce tail wag: https://www.helifreak.com/showthread.php?t=434332
https://www.helifreak.com/showthread.php?t=434482
Note that some of these methods may not completely work for you, but they have worked for others, including me!
Hope this helps!
BigEast
Thank you M'Man, you have done a great service....and saved 130 X fliers a whole "stuff-load" of time!!!
Regards,
J.
jimmiedac is offline        Reply With Quote Quick reply to this message
Old 10-13-2012, 10:37 AM   #52 (permalink)
misplaced reply...deleted
If it's too nice to throw around, SELL IT!
Blade-T-Rex-Tarot- 450 and under-DX6-AMA#977655
intro is offline        Reply With Quote Quick reply to this message
Old 10-13-2012, 12:37 PM   #53 (permalink)
Blade Forum Support
Great list Bigeast.
Be blessed
Isaac
Sent from my Galaxy Nexus using Tapatalk 2
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 10-13-2012, 01:34 PM   #54 (permalink)
Perhaps I have misunderstood one of the suggested set up mods or perhaps this is so standard it does not need mentioning - but I cannot see it on the list.
On first flight, for me the screw holding the tail rotor blade grip to the Tail shaft vibrated loose and one of the tail rotor flew off. It hit me on the chest and dropped to my feet. The identical same thing occured to another 130x the same day.
I have therefore removed and used a tiny amount of blue threadlock in each of the tail shaft blade grip threads to prevent this recurring.
Mim
Mimbulus is offline        Reply With Quote Quick reply to this message
Old 10-14-2012, 12:17 PM   #55 (permalink)
Arrow
Originally Posted by intro View Post
Boeing, huh? BFE site in Mukilteo is a great place to fly.
Greetings :-)
We're neighbors (well, relatively)... BFE site? Must one be a Boeing employee?
If not, would you mind posting a Google Map link?
Thank you.
HF-Lurker is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 05:44 AM   #56 (permalink)
Default A lot of tweaks for a new BNF out of the box. Blade and HH need to step up
As a prospective 130X buyer, I appreciate the fix it lists you have provided all in one reading.
I have to say that it is almost amusing just how many tweaks/fixes that apply to this new Blade heli. This is bordering on ridiculous. Instead of fixing this pathetic attempt at a full collective micro, I think 130X owners should be demanding your money back from HH.
I think what we need right now is one product specifically to fix this 130X--a complete, already built, blades balanced, replacement tail section. All done and ready to bolt on the bird. Hey, maybe HH could do that for us!
How about that Horizon? Send us a completely fixed tail to bolt onto our 130X's. One with decent bearings, and a straight tail gear! I think it's the freakin' least you can do!
And to "James" from Blades development team, telling us this resonance is normal is flat out being deceptive to your customers. Many of us are experienced RC heli pilots, so we don't buy the "it's normal" statements you are making. Telling us to quickly throttle past your manufacturing FLAWS is just plain irresponsible, and not good for Blade's or HH's reputation.
northernsky is offline        Reply With Quote Quick reply to this message
Old 10-18-2012, 02:59 AM   #57 (permalink)
I don't know if this has been done but
Check this out, I figured out the slop in the tail of the 130x
Items you will need
1 Bearing from blade grip on the mcpx
2 brass spacer from the head
Remove the bearing from blade grip, take the tail shaft from the 130x off and remove the bearing on the closest side to the tail blades.
install new bearing from the mcpx
install brass sleeve, make sure that the small inner race faces the bearing
install gear, install silver sleeve
attach and screw the set screws to the locking hub and BAM no slop.
Attention! I did use the brass sleeve that came with the Microheli upgraded grips
it was the larger of the two. you might be able to use 2 stock spacer from the stock kit. I hope this helps
check the pictures out! its very simple and fly's great!
ID:	358428   Click image for larger version
ID:	358429   Click image for larger version
Team ALIGN USA/ENTERPRISE HOBBY
Team SPEKTRUM
marioa111 is offline        Reply With Quote Quick reply to this message
Old 10-20-2012, 09:27 AM   #58 (permalink)
Great thread big east when i get somefree time to work on it i will start doing some of these things even though mine actually is flying pretty well dooes have resonance on spoolup and down
motorhead540 is offline        Reply With Quote Quick reply to this message
Old 10-27-2012, 06:24 AM   #59 (permalink)
I won't be holding my breath!!
Blade 130X / Blade 450X, Goblin 380 iKon / Goblin 500 iKon Scorpion HKIII-4020-1100KV Spectrum DX9
308Duo / X6 Deep Cycle
Supertuna is offline        Reply With Quote Quick reply to this message
Old 11-02-2012, 08:55 AM   #60 (permalink)
SR tail rotor heat sink for 130X main motor:
https://www.helifreak.com/showthread.php?t=432429
marinr is offline        Reply With Quote Quick reply to this message
Tags
130x, blade, fixes, mods, tail
