Old 09-01-2012, 03:03 PM   #1 (permalink)
Blade Forum Support
Default OK I killed two servos ds420 and the Jr ds188
OK I killed two servo the ds420 and the ds188. What I'm thinking is happening is that its to low voltage causing them to go out making the motor over work. I am only able to get 8 to 10 flights out of them both before they go to the servo heaven in the sky. It works great when its working. So all I have to say say is the the 130 3n1 don't like these servos for some odd reason. If anyone have a better thought about it chime in .
Be blessed
Isaac
Sent from my A100 using Tapatalk 2
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 03:19 PM   #2 (permalink)
Maybe a voltage regulator is in order. I hate to add extra weight but a small 3s pack connected to a xp-12a and a small regulator feeding 6V to 3-in-1 and tail servo sounds like a good set-up. Can you measure servo voltage output on the 3-in-1?
itsmillertime0 is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 03:37 PM   #3 (permalink)
I recall that you're running a 8000 HP08 with an 11 pinion at 100%.
I tried that and had two stock servo failures within three packs.
Thinking at that RPM there was a resonance at that RPM I turned down the throttle curve a bit and all was OK.
The 8000 with a 10 pinion is good at 100%, but my favorite is the 7600 with an 11 tooth.
RickM39 is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 04:33 PM   #4 (permalink)
I think DoubleCH has been running the eflight ds35 for a while. May want to try that one.
A lot of RC stuff:
Heli's, Quads, FPV gear, Tools, Chargers, Transmitters
jmisuraca is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 04:37 PM   #5 (permalink)
Blade Forum Support
One of the guys had a ds35 and his burned out also.
Don't know
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 09-01-2012, 04:54 PM   #6 (permalink)
my ds35 has been working fine so far. IDK 5 to 8 flights? i did see one guy had the link not in the closest hole on the arm . maybe it doesnt have enough torque with a long horn?
auto2 is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 05:24 PM   #7 (permalink)
Then again... it could be Isaac's flying style!... kidding!
I would think the low voltage makes sense since it's finicky down to 4.8v no?
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 05:38 PM   #8 (permalink)
The 3in1 puts out around 3.75 volts to the servos. But that was a board that what acting funny that I replaced.
Goatkeeper is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 06:04 PM   #9 (permalink)
Low voltage does burn up windings. Might be the case.
Old 09-01-2012, 06:32 PM   #10 (permalink)
Blade Forum Support
That's what I was thinking. Lol my flying style
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 09-01-2012, 07:08 PM   #11 (permalink)
Hey TNT I just did the mod! 6 flights all good, bird is stock.
Andrew166 is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 07:32 PM   #12 (permalink)
Blade Forum Support
Keep me up on the progress. I may give another try this time a Futaba one.
Be blessed
Isaac
Sent from my DROIDX using Tapatalk 2
FPV Everything Now
GOD BLESS
Old 09-01-2012, 07:39 PM   #13 (permalink)
Blade Forum Support
I had it turn down on 85%
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 09-01-2012, 07:39 PM   #14 (permalink)
Maybe it's the hp08 + servo the board can not handle.
A lot of RC stuff:
Old 09-01-2012, 07:52 PM   #15 (permalink)
Blade Forum Support
Maybe haven't thought about that Humm. Seem like it wouldn't burn it.
Now goatkeeper is came up with a thought freq could be an issue 333kz I don't know what the frequency is of The stock servo vs The ds188 or ds420
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 09-01-2012, 08:19 PM   #16 (permalink)
Be blessed
Isaac
Lol, ok 8 flights so far so good, but my bird is stock, do another 12-16 flights tmr.
Old 09-01-2012, 08:31 PM   #17 (permalink)
TNT. Are you running the hp08 off the stock board? If so I wonder is a dedicated esc would resolve this issue.
A lot of RC stuff:
Old 09-01-2012, 09:03 PM   #18 (permalink)
Blade Forum Support
Yeap I'm running my hpo8 off of the stock esc. It may resolve it but I don't have a esc to try it on .
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 09-01-2012, 09:27 PM   #19 (permalink)
Whats the servos rated at, might be voltage.
Did u kill stock motor? Or just wanted more lower. Maybe another esc?
Sent from my ZTE-Z990G using Tapatalk 2
Fusion 480,OMP M1/M2,600N,lots of Planes Powered by NX10 AMA 33 yrs.
Old 09-01-2012, 10:45 PM   #20 (permalink)
If the servo can take it you could power directly off the 2s. Just disconnect the postive from the 3-in-1 and verify the ground to the servos is common to the pack (should be). You can also drop down 0.7v by adding a diode, or 1.4v by adding two diodes in series. If that voltage is still to high you can use something like this http://www.dimensionengineering.com/products/parkbec or this http://www.ebay.com/itm/New-RC-3A-U-...item4846d8d595
Gregor99 is offline        Reply With Quote Quick reply to this message
