Like Tree16Likes
Old 05-05-2019, 05:46 PM   #2581 (permalink)
Thanks for that. I just grabbed a set. Not to rehash the tail servo topic in this thread but what makes the DS36 better than the DS35?
Chris1683 is offline        Reply With Quote Quick reply to this message
Old 05-19-2019, 11:50 AM   #2582 (permalink)
Is there a part number for an adapter to connect the DS76T plug to the 130X board to test things out before committing to swapping the plug?
* Gaui X3L, 450X, Tarot 450 Pro V2, OXY3, 300CFX, 180CFX, 130X, V120D02s, mCPX BL, mCPX v2, Super CP, nCPX BL
* DX9, DX7 G2, Devo 10 & 7e w/Deviation, Turnigy 9x w/ er9x, DX6i
RoboHeli is offline        Reply With Quote Quick reply to this message
Old 05-19-2019, 11:56 AM   #2583 (permalink)
Ooh, I think I just answered my own question:
https://www.microheli.com/helicopter...converter.html
Old 05-19-2019, 01:02 PM   #2584 (permalink)
If you have any bad 130X servo...
You can use any regular servo wire to make a test adapter without cutting up the DS76T wires
RoboHeli and Mrowka like this.
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X(2)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 05-19-2019, 01:08 PM   #2585 (permalink)
Assuming you meant the DS76T...
The DS76T is a 450-size servo...
1) Much stronger
2) Without the issues of DS35 V2
I have now swapped the DS76T into 14 130X's without a hitch
A much better option without the stock servo twitching
Mrowka likes this.
Old 01-03-2020, 08:12 PM   #2586 (permalink)
My laptop blocks the microheli web site due to it "phishing", so I don't go there.
Logo 600 (Spirit Pro), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), 180CFX, 130X, Horus X12S
PassinThru is offline        Reply With Quote Quick reply to this message
Old 04-01-2020, 07:21 PM   #2587 (permalink)
Took my 130X’s off the shelf for some Spring flying. All 3 flew perfectly after their winter break. Looking forward to maybe nailing down piro flips this year!
inganeer and Mrowka like this.
Old 04-14-2020, 09:50 AM   #2588 (permalink)
just put one of these on the tail was a direct drop in for my busted DS883. Its a bit quick but so far early flights are holding up.
https://hobbyking.com/en_us/blue-arr...___store=en_us
Specs:
Torque: 0.50kg ~ 0.65kg
Weight: 3g
Speed: 0.07 ~ 0.06sec / 60deg
Voltage: 4.8v~6.0v
Gear Train: Metal output gear
Gear Type: Digital
Motor type: Coreless
Plug: JST connector-1.5mm pitch (Will fit Spektrum Rx AR-6300)
Spline Count: 20
HedgeHeli is online now        Reply With Quote Quick reply to this message
Old 04-15-2020, 05:52 AM   #2589 (permalink)
I use these on most of my 130x's. Works good on the cyclics too.
Sent from my LGL63BL using Tapatalk
inganeer is offline        Reply With Quote Quick reply to this message
Old 04-16-2020, 12:26 PM   #2590 (permalink)
FWIW, MH 130X cyclical servos are rebadged Blue Arrows with a different plug.
I mocked up parts (again) on the 3S 130X I am building and realized that I am going to have to do something about the A/B gear mesh. Also, I realized why the main gear and pinion gear don't mesh so good - the main shaft is tilted ever so slightly so that it isn't quite perpendicular to the frame or the motor pinion.
Not sure how to fix that.
Also, my eleven year old has graduated from her little Blade 70S to a Nano CPS in SAFE mode. Her little brother is trying to learn to fly an Inductrix.
130X parts wanted! The Precious! You has the Precious!
Mrowka is offline        Reply With Quote Quick reply to this message
Old 04-19-2020, 04:19 AM   #2591 (permalink)
Its not working great for me, its flyable but not happy. Shame because at the price its certainly attractive.
The vid shows the wag and the mechanical nature of the tail as it turns. I have upped and lowered gyro gain, increased and lowered mechanical gain but to no avail, this is the best it gets.
Initially the vid was a parody on a post in the main thread about vbar being smooth but hey I ran out of skill
Bit of flipping at the end, as I say flyable but not happy.
Eflite Blade 130x Tail Servo Demo (4 min 1 sec)
Specs:
Weight: 3g
Voltage: 4.8v~6.0v
Gear Type: Digital
Spline Count: 20
Old 04-19-2020, 09:05 AM   #2592 (permalink)
A lot of people like the D03013 Blue Arrow as a tail servo.
I've never installed one as a tail servo, but for a few dollars more, you can get a DS76T, which is, like, the Greek god of 130X tail servos.
Old 04-19-2020, 11:39 AM   #2593 (permalink)
We should have hats made...instead of MAGA...
MT130XGA...(which we both have already done)
Mrowka likes this.
Old 04-20-2020, 09:27 AM   #2594 (permalink)
From your mouth, to Mr. Blade's ears.
Although, thinking it over, the 130X already is great. We just need to convince its creator to recognize this.
