Old 09-18-2012, 01:44 PM   #1 (permalink)
Default Motor Mods Compiled
Let's get the motor swap threads stickied...!
HP08 stock ESC:
https://www.helifreak.com/showthread.php?t=440200
HP08 3S:
https://www.helifreak.com/showthread...ghlight=dylwad
HP06:
https://www.helifreak.com/showthread...ghlight=signal
Spin 8800 external ESC:
https://www.helifreak.com/showthread...light=alex7703
CH05:
Main Board Signal Spot (External ESC's):
Prefered signal spot: https://www.helifreak.com/showthread...ghlight=signal
Alternative signal spot: https://www.helifreak.com/showthread...oredump&page=4
Pinion Information:
Aries17q 9T,10T, and 11T Calculations: https://www.helifreak.com/showthread.php?t=456752
HP08 8000kV / 7600kV, 10T or 11T?: https://www.helifreak.com/showthread.php?t=456641
MOTORS, PINIONS, AND OTHER PARTS:
http://astroid-designs.myshopify.com...ons/blade-130x
http://astroid-designs.myshopify.com/
http://www.topcopter.com/default.asp
http://www.overskyrc.com/index.php?m...dex&cPath=5_24
Last edited by alex7703; 09-25-2012 at 10:29 AM.. Reason: Added pinion information
alex7703 is offline        Reply With Quote Quick reply to this message
Old 09-18-2012, 06:28 PM   #2 (permalink)
Bookmarked
Also Oversky has 10T and 11T pinions
liftbag is offline        Reply With Quote Quick reply to this message
Old 09-18-2012, 08:08 PM   #3 (permalink)
Originally Posted by liftbag View Post
Bookmarked
+1 on the bookmark.
+1 on the stickies definitely, for the very simple fact is you know the freak is "probably" backed up better than most of the comps out there and wouldn't it be tough to have to look this stuff up AAAGAIN.
bell
bellus alatus is offline        Reply With Quote Quick reply to this message
Old 09-19-2012, 01:02 PM   #4 (permalink)
Originally Posted by bellus alatus View Post
+1 on the bookmark.
bell
All this info is spread out pretty bad and was a pain to find in search already.
Old 09-19-2012, 04:51 PM   #5 (permalink)
Thread stuck. Good info, thanks guys.
Alex, after a certain amount of time, you'll lose the ability to edit your post. If you ever need to add something, please just PM me so I can add it.
ChrisH is offline        Reply With Quote Quick reply to this message
Old 09-19-2012, 05:24 PM   #6 (permalink)
Will do and thanks Chris.
Old 12-30-2012, 06:33 AM   #7 (permalink)
anybody have advice on tx settings for the spin 8800kv motor for the 130x?
Antzx10rr is offline        Reply With Quote Quick reply to this message
Old 12-30-2012, 11:07 AM   #8 (permalink)
the only different settings would be the Throttle Curve if you dont want 100% flat. You might try 85% and see if you like, if not, go up or down!
gdawgs56 is offline        Reply With Quote Quick reply to this message
Old 12-30-2012, 04:04 PM   #9 (permalink)
Better add the hp10 to the list. Ive got one ordered from topcopter but who knows when I will get time to install and test. Better kick butt for the price. Lol
xpcm is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 01:24 PM   #10 (permalink)
Oops! Didn't realize the pinion/HS info is already on the 1st post.
Old 02-24-2013, 06:16 PM   #11 (permalink)
My first HP08 died after 20 flights and the second one does not seem to have as much power, has anyone seen this. Tried it with 2 main boards. I am on my 5TH board in 500 flights, 2 have lost throttle and 3 cyclic output.
Thanks.
boat55 is offline        Reply With Quote Quick reply to this message
Old 02-25-2013, 05:49 PM   #12 (permalink)
Default Re: Motor Mods Compiled
I had two go bad both in 13 fights I'm using a xp12 and a spin 8000 now lot better motor but I only have 7 fights on it
Sent from my Desire HD using Tapatalk 2
Sentinel1537 is offline        Reply With Quote Quick reply to this message
Old 02-28-2013, 08:41 AM   #13 (permalink)
I second this. The spin motor is much better! My hpo8 crapped out on me after 80 flights.
Chris g. is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 12:57 PM   #14 (permalink)
Was planning on going with the HP08S but after seeing the above have reliability issues I think I'm going with the HP10S. Flight time isn't an issue since I have a paraboard and use the Glacier 450s with basic flying and mild mild 3D.
Someone described it as giving the 130X a 450 power/weight ratio which sounds perfect because that's what I'm moving up to next!
Just waiting for AD to get some more and the mount frame brace in.
nicholask1993 is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 06:27 PM   #15 (permalink)
Which is better - HP08S or Spin 8000Kv?
BladeScraper is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 06:45 PM   #16 (permalink)
Spin! IMHO
Old 03-30-2013, 09:24 PM   #17 (permalink)
Which is better - Hp10 or Spin 8000?
mixfisto is offline        Reply With Quote Quick reply to this message
Old 03-30-2013, 10:57 PM   #18 (permalink)
What oil should I use? Helidirect says to oil the bearings every 5 flight. Will this work?
http://helidirect.com/extreme-bearin...es-p-27403.hdx
Or this?
http://helidirect.com/scorpion-motor...kit-p-9899.hdx
Old 01-16-2014, 10:27 AM   #19 (permalink)
Hey can some one rate all the current after market motors? (Spin, Quantum, HP08s, HP10s, Lynx 2s & 3s)
Tarot 450 Pro DFC
Blade 300x Blade 180CFX
jlk69 is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 11:28 AM   #20 (permalink)
dct
http://www.lynxheli.com/product_info...ducts_id=22931
What about this motor?
Can be seen here..
Blade 130x hard 3D (2 min 39 sec)
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote Quick reply to this message
