Closed Thread
Old 10-03-2012, 11:03 AM   #21 (permalink)
"Outstanding!"
-Jay
Major Equipment Sponsor - AdventureRC
Discount_Bob is offline        Quick reply to this message
Old 10-03-2012, 04:23 PM   #22 (permalink)
LOL, Jay!
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 10-07-2012, 01:36 AM   #23 (permalink)
Default Bell Cranks
In this video we discuss bell cranks and address an extremely rare length problem with a spacer. Please note: Only a couple of folks have encountered this problem. It's fix is easy and we show you how to do it.
[ame]http://www.youtube.com/watch?v=hJlv-i1XSy0[/ame]
Scott
KBDD Team Pilot ):>
Old 10-07-2012, 10:02 AM   #24 (permalink)
Thanks Scott for another Tech Tip Vid. Will definitely be helpful to those who encounter that problem. Like the look of those servo wheels
bnchinook is offline        Quick reply to this message
Old 10-07-2012, 12:45 PM   #25 (permalink)
Keep'em coming Scott, great work.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Quick reply to this message
Old 10-07-2012, 01:03 PM   #26 (permalink)
Scott, you are so good at these videos, I think you need to do one on piro flips
:thum bup:
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Quick reply to this message
Old 10-07-2012, 02:01 PM   #27 (permalink)
:thum bup:
Thanks... I think. LMAO! PIro flips... Umm... Yeah.
Scott
KBDD Team Pilot ):>
Old 11-02-2012, 12:03 AM   #28 (permalink)
Originally Posted by dunkonu23 View Post
In this video we discuss how to achieve a proper main gear/pinion gear mesh.
http://youtu.be/qFtYJzmp9FQ
This video is blocked in Germany due to legal reasons. As such, I apologize to our German friends. The giveaway is open to all non-sponsored pilots in any country except Germany (no offense, you can't see the video for the reason mentioned above).
This started off as a tech tip for the bell cranks. During recording, my tripod broke. After that, I could not get the angle I wanted for the video. I haven't forgotten the request. I will be getting a new tripod and get the bell crank tech tip video done as soon as possible.
Scott
Has anybody tried the old Paper in the gear trick? How do you feel about it?
I just tried it tonight, took a 1/2" wide strip of plain white copy paper, fed it into the mesh, pushed the motor up tight and tightened all the screws while holding pressure on the motor.
It doesn't make the mesh feel over tight when the paper is in the mesh, but when it is removed, the mesh feels smooth and quiet. When I hold the motor solid, I can feel a VERY TINY tick in the mesh backlash, almost too small of a movement to see. It is that way, even and smooth all the way around the gear.
Now!, is this too loose? Is it not a good practice to follow? Give me some input here guys.
Edit, My mesh and backlash is EXACTLY like what you showed in this video Scott.
Bryan AMA# 982814
"No-Neck R/C"
Old 11-02-2012, 06:22 AM   #29 (permalink)
That's great, Bryan. I've used the paper mesh method on straight gears with success, but I always seem to go back to the method I used in the video. I think either way is fine. My only concern with the paper method is this: With slant gears, you need a paper thickness that will be pliable enough to bend enough to mold itself to the slant. Plain copy paper from one manufacturer may vary in thickness when compared to plain copy paper from another manufacturer. That means gear mesh may vary. In the end it's whatever you're most comfortable doing.
Scott
KBDD Team Pilot ):>
Old 11-02-2012, 09:44 AM   #30 (permalink)
I think it will be ok, I have the same lash that you showed, almost nothing, and a little click.
Bryan AMA# 982814
"No-Neck R/C"
Old 11-02-2012, 09:55 AM   #31 (permalink)
I Find that the regular printer paper to be too bulky and ridged and does not allow it to flow into the mesh well. I go by feel now but, I think the plastic bags the parts come in to be a better tool for mesh. I feel It is very flexible in corners being that its self lubricating which allows it to flow between the teeth better.
Charley Stephens
Charley Stephens is offline        Quick reply to this message
Old 11-02-2012, 12:28 PM   #32 (permalink)
Quite honestly, I've never tried the paper method with the Rush. I just used the tried and true click method.
I wouldn't have thought to use the plastic packing bag, though. I guess that's why you're you, Charley!
Scott
KBDD Team Pilot ):>
Old 11-04-2012, 04:09 PM   #33 (permalink)
Default Give away winner
Clay333 is the winner of the Tech Tip video giveaway. Clay won a set of Edge 713mm blades! Clay guessed the song used for the intro was "Lessons" by Rush.
Congratulations, Clay! PM me your address and your blades will go out ASAP!
Scott
KBDD Team Pilot ):>
Old 11-04-2012, 06:45 PM   #34 (permalink)
Scott
Thanks alot Scott! I can promise you I will put them to use right away and will think about your incredibly nice gesture everytime I fly! Thank you
Clay333 is offline        Quick reply to this message
Old 11-04-2012, 06:53 PM   #35 (permalink)
Outstanding, Clay! It's my pleasure. I hope you enjoy your new blades!
Scott
KBDD Team Pilot ):>
Old 11-14-2012, 09:42 PM   #36 (permalink)
Default Links
Scott your tips on how to put those big links on gave me an idea. I took an old pair of ball link pliers and ground off the tit. It works great for snapping on those big boys.
foolforspeed is offline        Quick reply to this message
Old 11-15-2012, 04:33 AM   #37 (permalink)
Yep, that works, too. Also, you can grind a deeper slot on one side of the pliers. I just didn't have a spare set of pliers to modify.
Scott
KBDD Team Pilot ):>
Old 02-24-2013, 04:52 AM   #38 (permalink)
Anyone from the team got some nice en clean wiring options for me? i see a lot of holes for tiestraps, but i'm i little bit lost in the wiring (to keep it clean) :-)
Sponsored by :
Flying : SAB Goblin630 : scorpion 5020-450 /YGE 120HV(Beastx)
Mikado Logo600 : scorpion 5020-450 /YGE 120HVK(miniVbar)
AleeS Rush750 : scorpion 5020-450 /YGE 120HVK(Skookum SK540)
arroxfive is offline        Quick reply to this message
Old 02-24-2013, 08:12 AM   #39 (permalink)
most of the team guys run the wiring inside the frames. "I" personally run the elevator, and tail servo wires down and inside the the left frame right under the 2nd mainshaft bearing and up to the gyro plate. i think scott may have pics of his somewhere or in his videos. i know Backburner1955 and I wired our models the same. look threw some of his post and he has some pics i think of how he wired his model. i'm kinda anal about wiring and spend more time hiding my wires then i do building the kit. im not a fan of wires on the outside of the frame if i can help it. BUT it does become a pain when rebuilding from a crash sometimes.
dodgeboy is offline        Quick reply to this message
Old 02-24-2013, 08:14 AM   #40 (permalink)
anothing, you will need 2 servo extensions for the rear servos
Closed Thread
