Closed Thread
Old 05-16-2013, 06:39 PM   #61 (permalink)
Scott, i went to try to oil the lower motor bearing today and again found no where to access the bearing. The one in the motor, not the pinion support. Can you help me out here?
Jacob
Rush 700, Synergy N5c tt, MA Fury 55, Trex 450 pro, Blade 130X
jmdanna is offline        Quick reply to this message
Old 05-16-2013, 06:45 PM   #62 (permalink)
Jake I get to mine with the heli upside down, going thru the battery trays. I ave a 6" or longer plastic needle oiler that just gets right in there.
On the other hand I have had my x5 with the stock scorpion motor for over a year now and have only oiled the bearing 3 times.
dodgeboy is offline        Quick reply to this message
Old 05-16-2013, 06:56 PM   #63 (permalink)
I gotcha beat.. I have NEVER oiled my bearings LOL
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Quick reply to this message
Old 05-16-2013, 07:00 PM   #64 (permalink)
You crack me up dude.
Old 05-16-2013, 08:24 PM   #65 (permalink)
I think you're mistaking the pinion support bearing with the inner motor bearing nearest the output shaft. I am able to oil the upper bearing because of the cooling fan openings, but I am unable to reach the lower bearing, so I haven't oiled it.
Jacob
Old 05-16-2013, 09:39 PM   #66 (permalink)
I figured it out. I have the scorpion motor oil with the needle that snaps on the bottle. I put a 2 inch piece of fuel line on the needle and connected the other end to the bottle. Now it will reach through the gyro chamber to the bottom of the motor. Of course you still have to invert the machine so gravity will help the oil run into the bearing
foolforspeed is offline        Quick reply to this message
Old 05-17-2013, 12:45 AM   #67 (permalink)
I'm going to oil mine again tomorrow, so I'll let you know how I did it. I have oiled it before, though.
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 05-17-2013, 06:47 AM   #68 (permalink)
Im not mistaken. Im sure I know the difference between the motor bearing and the support bearing.
Old 05-17-2013, 12:54 PM   #69 (permalink)
I prefer to use grease on my bearings if they last long enough to need more lubrication.
I'm a greaser. I do have a bottle of the scorpion motor oil though. I used it on my door hinges the other day.
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Quick reply to this message
Old 05-17-2013, 02:41 PM   #70 (permalink)
i thought you were mistaken because I don't see a way to get to that bearing through the battery trays, or from any way for that matter
Jacob
Old 09-19-2013, 06:25 PM   #71 (permalink)
Awesome thread
Thanks to all the team members and others that contributed
Really helps out a new rush owner for the build
automagp68 is offline        Quick reply to this message
Old 10-31-2013, 06:17 PM   #72 (permalink)
I was wodering which would be better, the HK-4530-500 Scorpion 4530-500 Brushless Motor (6mm Shaft Diameter) Limited Edition or the HK-4530-450 Scorpion (450 KV) 14S Brushless Motor? i wasnt sure which would be better.
flyingcuban is offline        Quick reply to this message
Old 10-31-2013, 07:05 PM   #73 (permalink)
Motor selection really depends on how you fly and the head speed you want to fly. If you do not know a target head speed, I would stick with something smaller as a 14S setup is not necessary for any variant of the Rush. For lower head speeds (2035-50, max) and stock gearing a HKIII4035-500 with 6mm shaft. A 6mm shaft is a requirement for pinion fit. If you want higher head speed then something like 4235-520 or 4525 520.
Scott
KBDD Team Pilot ):>
Old 11-05-2013, 06:00 PM   #74 (permalink)
Scott
I even watched him oil his bearings once!!!!!
Where do the Du-Bro 1/4 scale hinges go on a helicopter???
Team Shannon, Scorpion Power Systems and TailDraggerRC. Thank you all!
chris-fry is offline        Quick reply to this message
Old 11-05-2013, 07:36 PM   #75 (permalink)
I put a couple drops of oil on all the bearings I can reach, on the swash plate, main and tail shaft about once a month. On my nitro.....exhaust is enough oil.
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline        Quick reply to this message
Old 12-22-2013, 05:21 PM   #76 (permalink)
Default Re: Team ALeeS RC Tech Tips
Brass spacer 5x3mm 3mm opening. I cant find a place for this
Rc Zombie is offline        Quick reply to this message
Old 12-22-2013, 05:36 PM   #77 (permalink)
You're the second person (I think) who got brass spacers. Fear not! They're unused.
Scott
KBDD Team Pilot ):>
Old 12-22-2013, 08:31 PM   #78 (permalink)
Cool I thought I missed a step and I been over it and over it thank you
Old 12-22-2013, 08:59 PM   #79 (permalink)
You're very welcome!
SCott
KBDD Team Pilot ):>
Old 12-22-2013, 09:00 PM   #80 (permalink)
I had those spacers in my kit too. They drove me crazy for a while trying to figure out what I could of missed.
Team JR
vanheli76 is offline        Quick reply to this message
Closed Thread
