Electrics for nx4 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 09-25-2012, 01:45 PM   #1 (permalink)
Default Electrics for nx4
Hi,
I would like to get all the electrics and engine for the nx4 but unsure what's the best to go for as i generally fly all electric but fancy having a go at a small nitro.
I'm thinking 4 x align 510 1 x 520 for tail, os37, mini vbar, but unsure about electrics for the engine. Do I need a governor, can I use an align 2 in 1 for the glow plug ?
If you guys can give me an idea then I can get started buying (gulp) for Nov 5
Cheers
Rik
blueskiesdz is offline        Reply With Quote Quick reply to this message
Old 09-25-2012, 03:20 PM   #2 (permalink)
For gov I am going to use a "Multi Gov" and a Rev Glow for starting...... JC is using a "Throttle Jockey" for gov. and a Ni-Starter for starting....
Pinion
Gaui X7, X5, NX4, X42, X3
Gaui USA, Empire Hobby, JR Americas, Cyclone Blades, MKS Servos USA, OptiPower Batteries,YS Engines,
PowerMaster Fuels
Pinion is offline        Reply With Quote Quick reply to this message
Old 09-25-2012, 03:29 PM   #3 (permalink)
I'm going to use the VBar governor and Align sensor, and Push Glo to heat up the plug.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 09-25-2012, 04:06 PM   #4 (permalink)
I ordered the MSH brain with Governor, Align sensor, and push glow. I am thinking the JR HV servos ( DS3717HV ).
I am not sure what size battery will fit on there.
-GN
Citizen 106
Protos MAX V2 | Forza 700 | Goblin 570/500/380 | Gaui NX4 Nitro and Gasser | T-REX 600E PRO DFC | T-REX 550E V2 | Dominator 450L | Blade 130/180 x/cfx | JR XG14/XG11MV | Icon
GasNerd is offline        Reply With Quote Quick reply to this message
Old 09-26-2012, 12:25 PM   #5 (permalink)
We are using a LiFe 1450mah, However if your using HV servos you can use a 1300-1600mah Lipo and be fine ;-)
JC Zankl
Empire Hobby/GAUI,PowerMaster Fuels/YS Engines/Graupner Radios/Scorpion Power Systems/Castle Creations/VTX Blades/Bavarian Demon/Velos Rotors/Xpert Servos
jczankl is online now        Reply With Quote Quick reply to this message
Old 09-26-2012, 12:52 PM   #6 (permalink)
NICE! I have some 1300 mAh packs I can share from my X7.
Old 09-26-2012, 04:44 PM   #7 (permalink)
Sounds excellent and thanks for the info.
I just need a Lipo and I have everything - minus the kit
I ended up going with Hitec HS-7235MH High Volt Speed Digital MG Mini Servo. I was going to do the JR's, but these are 100 dollars cheaper for 4! I will splurge on the tail servo.
I have had good luck with both my JR and Hitecs ( way more luck than my Align or Savox servos).
Went with MKS DS-8910A+ for the tail servo
-GN
Citizen 106
Old 10-03-2012, 03:31 PM   #8 (permalink)
Would this battery be too large?
ThunderPower G6 Pro Lite RX
TP1900-2SPLRX
1900mAh 2-Cell/2S 7.4V
14 x 46 x 73 ( mm )
http://thunderpowerrc.com/G6ProLiteR...oBatteries.htm
thanks,
-GN
Citizen 106
Old 10-03-2012, 03:50 PM   #9 (permalink)
You don't want to be to much bigger than this pack here. As the canopy will have trouble going on.
Hyperion LiFe 1450 2s 6.6v
L x W x H (mm)
84.6 x 29.5 x 17.2
Should fit just fine ;-)
JC Zankl
Old 10-07-2012, 10:21 PM   #10 (permalink)
Picked up my motor and pipe from Bobby Jacks today. With the weekend sales going on snagged a brain at a killer deal from readyheli so will use that for fbl and gov. Just need to snag a push glow now.
For servo's, probably going to run MKS DS9660A+ on the cyclic and MKS DS8910A+ on the tail.
So for the RPM sensor looks like the align sensor is what people are going with. Will the spektrum one not work?
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote Quick reply to this message
Old 08-29-2016, 10:13 AM   #11 (permalink)
Just picked up a built (never flown) gaui nx4 with 5 x (never used) mks ds9670a+ on it. Anybody know if they will suffice on this model? The stall torque on 6v is somewhere around 38.1 oz. Seems a bit on the light side for cyclic. I did read on vstabi that they roughly recommended minimum 40 oz for 425 mm, so I guess it's in the ball park. Will be running 430mm blades and os 37 motor. I fly intermediate 3d..
GAUI X5, NX4, X3, T-REX 450 Pro V2, Hisky HCP100S, Blade nano CP S - Spektrum DX8
Joslan is offline        Reply With Quote Quick reply to this message
Old 04-11-2017, 12:59 AM   #12 (permalink)
Read the vstabi forum again and they recommend minimum 25 oz for 425 mm (not 40 oz as previously stated). So should be ok.
Human Verification
