Go Back   HeliFreak > R/C Electronics Support > Robird G31
Robird G31 RobirdUSA Factory Support Forum
Like Tree3Likes
Old 12-12-2012, 08:21 PM   #201 (permalink)
This I the Robird setup,
Monitor screen
Rapid Helis Australia
Lighty is offline        Reply With Quote Quick reply to this message
Old 12-12-2012, 08:30 PM   #202 (permalink)
Somethings not jiving there. Do you have neg trim in your throttle channel by chance?
If you set I1 for 90, then your monitor screen should coincide. That's all in the Tx.
Maybe you have your throttle endpoint turned down?
sent from my phone using circus midgets
Compass 7HV Gaui X5 Formula HD Cell 500
LawnDartHeli is offline        Reply With Quote Quick reply to this message
Old 12-12-2012, 08:44 PM   #203 (permalink)
Okay, I did some checking on my DX6i. First pic is IU 90% flat w/ no subtrim.
Second pic is the same thro settings w/ -30 subtrim on throttle.
Notice how it effects the thro in the monitor screen.
ID:	373733   Click image for larger version
Old 12-12-2012, 08:46 PM   #204 (permalink)
If you don't have subtrims active, you may need to send in your Tx for calibration. Especially if it shows discrepancy on another model.
Old 12-12-2012, 09:00 PM   #205 (permalink)
Thanks for that. My sub-trims are at zero.
Funny thou my 7HV has a flat 95 and it reads 91. Not far out at all.
Old 12-12-2012, 09:07 PM   #206 (permalink)
That is strange fo sho..
Can you go in and up your max endpoint and see if that squares it up in the moniter screen?
Old 12-12-2012, 09:08 PM   #207 (permalink)
Nevermind..you said it shows 100 when you set it at 100.:banghead:
Old 12-12-2012, 09:12 PM   #208 (permalink)
I would just go by my throttle curve screen and just forget what the monitor says. Set it up that way and tach it, if its where you want it rpm wise I'd call it good. Even setting up the gov it just wants to know max throttle, it doesn't know what your monitor says.
Old 12-12-2012, 09:35 PM   #209 (permalink)
Hi Lawn
Really appreciate your help.
With the ROBIRD and Warp I get a max HS of 3000. Going by Mr Mel cal I should get 3700. I am going of the ROBIRD log so I'm no sure how accurate it is.
cheers
Old 12-12-2012, 09:45 PM   #210 (permalink)
The only thing I trust when it comes to headspeed is an optical tach. Even with the gov sensor on the motor theres no real way for it to read head rpm. In the vib log it shows a way different rpm that what its actually turning. I run the gov in my esc, at 85% throttle Im sitting a 2650 on the business end. My Robird shows way higher.
Old 12-12-2012, 10:02 PM   #211 (permalink)
Will TACH it on Friday.
Back to the monitor screen it's weird how the Robird correlates with that screen. Anyway the TACH will tell the truth!
Old 12-12-2012, 10:16 PM   #212 (permalink)
LOL!
The headspeed calculator method works good, usually is pretty damn close. If its spinning too hard you can always back it down.
But the Tx showing two different values at the same setting is still strange. I won't lie, I've never messed with a DX8, so I don't know what all settings effect what.
May post in the Spectrum forum and see if anyone else has that issue?
Old 12-14-2012, 09:24 AM   #213 (permalink)
Okay, I might have missed it in the thread someplace, but on a 500 size heli:
Robird + Satellite (one or two?)
or
Robird + Receiver + Satellite?
(I'm a JR/Spektrum guy)
Jon
Chaos 600E
Jonathan Ott is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 10:28 AM   #214 (permalink)
Two sats or rx+sat.
I have rx+sat on mine.
Old 12-14-2012, 11:08 AM   #215 (permalink)
Originally Posted by LawnDartHeli View Post
Two sats or rx+sat.
I concur: Robird + standard Rx + satellite
SDedic214 is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 01:38 PM   #216 (permalink)
Thanks guys, Robird+receiver+satellite it shall be.
Also, if I'm understandng what I've been reading, if I go Robird+receiver+sat I don't have to do any voodo magic to power the rudder servo, right?
Jon
Chaos 600E
Old 12-14-2012, 01:44 PM   #217 (permalink)
You are correct!
Old 12-14-2012, 04:19 PM   #218 (permalink)
or
Jon
I have no luck to find another SRx adaptor to have Robird + 2 Satellites. Anyone can find an additional SRx adaptor for Robird?
Blade: Fusion 270, 180 Trio, 180 CFX, 130X, MCPX-BL, Nano-CPS
Prôtos 500 - SK720. HK500TT - Robird G31. Tarot450pro - Beast X
Trex600CF - Scorpion 4025-740, SK720. Trex600Nitro sport - YS50, CGY750
Racing Quad: Mojo 230. BabyHawk R
dennis052 is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 04:25 PM   #219 (permalink)
What is your experience with this gain ? On my 9303 i have channel 7 and 8 as gain for ELE/AIL and can set by channel travel a low value and a high value (and the 50% value for the switch in the middle). I am using the 3 pos AU2 switch.
Do you have any idea what is the equivalent with the analog dials. 0 dials could be middle of the channel (50%).
Originally Posted by gothicbunny View Post
I've been watching these for a while. The thing that finally sold me was setting Ele/Ail gains by Tx. Now does anyone know where you can get the SRX cables for running a second satellite?
stiganas is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 04:44 PM   #220 (permalink)
The newer ones come with 2. I could send you one of mine? I'm using a full rx with the sat plugged into it, not the unit.
