Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
#41 (permalink) |
![]() Another good example of the flexibility. Good to hear it worked. Would have been my approach too.
#42 (permalink) | |
![]() Quote:
Great thinking ![]()
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Goblin700, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro EF MXS 3W110, Ultimate Aeroworks 20-300, DA 170, PowerBox Mercury, Q80-8M in a 91" EF Extra and MXS 104+ few jets |
#43 (permalink) | |
![]() Jotto,
Do you have a DC or DS. If you have a DS, take a screen shot of the set up and post it. If you have a DC, you will have to wait until version 2.0 of firmware is available to do it. Lou Quote:
Vector 550 Quad/Octo Multirotors DJI WooKong Multirotor Controllers Twin Bergen 44 Magnum Turbines - KERO Start FBL ![]() www.circlecityhelis.com |
#44 (permalink) |
![]() Actually the DC v1.07 already has that option too in system menu you just have to assign a switch to it, same as in DS I guess (I don't have a DS)
#45 (permalink) |
![]() There is still no good explanation of how to start and stop a timer by "throttle channel value" not throttle stick position. I want the timer to run whenever throttle channel is anything but 0%. The timer can only be activated by physical switches, and even logical switches can only be a combination of switches or sticks. I also tried using mixes but since those only work between true channels and timers depend on switches or logical switches I see no way of making the timer work by throttle value.
There is also a lack of sequential reverse activation for using the spring loaded switch. Futaba allows you to start the timer by flipping the spring loaded switch and then auto reverses the next flip to stop it. Start and stop reverse every time you flip the switch to the front and back. It's quite useful. Any ideas will be appreciated.
Marcos Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol. |
#46 (permalink) | |
![]() Quote:
#47 (permalink) | |
![]() Quote:
#48 (permalink) |
![]() Just starting to play with the Jeti.
I added a new .wav file but when I try to play it I get an error 'Invalid RIFF ID' Any idea what causes this? |
#50 (permalink) |
![]() The recorder you are using might be formatting them wrong. I also got errors if I tried playing them before disconnecting the USB from the computer.
#51 (permalink) |
![]() Interesting about the Laps function to achieve the reversed on/off.
I still don't see how the on/off position of the gimbal in the sticks advanced menu has anything to do with the throttle value. If I am on Idle 1 with a flat 50% throttle curve the timer still stops at minimum pitch. Maybe I am missing something at the Logic Switch configuration step?
#52 (permalink) | |
![]() Quote:
Edit: Unless I am misunderstanding you I guess my question is why does the throttle signal matter? You should be able to logically tell it when the motor is running. Last edited by BustedRaptor77; 05-23-2013 at 01:50 PM.. Reason: added |
#53 (permalink) |
![]() That works for a timer on when not on hold, though I could just program the Hold switch to activate the timer then.
My trouble is before the flight: Kontroniks block the motor when initialized at anything above cero throttle. I have relied on starting like this, no Hold, mid stick, my Normal curve is flat so as to have an added flying condition. When I am ready to take off I hit Hold, the ESC arms and I then release Hold to spool up into Normal. In this sequence a timer configured through the Hold switch starts as soon as I turn the radio on since there is no Hold until just before starting the flight. I do trust the K blocking the motor more than the Hold switch being on since once the ESC arms a hit to the switch and you have a big problem. I use K on 90% of my helis and I want to keep starting with the ESC not arming, to me it is more important than having a comfortable timer. On the Futaba I start the timer manually with the spring loaded switch but I do forget to start it every now and then and it is not useful when doing lots of autos for example.
#54 (permalink) |
![]() I've been dreaming of moving to mAh consumed alarm for a long time but the transition will be gradual as I get new Rx and re program the helis into the DS-16, even the purchase of Jlogs for all my K equiped helis will be gradual. In the meantime, I need either a timer start on the spring switch that reverses the on/off or a timer that starts when throttle value is above cero. Or a timer on another 2 position switch for the time being but that sounds so precarious...
#55 (permalink) | |
![]() Quote:
#56 (permalink) | |
![]() Quote:
Have laser, will travel. |
#57 (permalink) |
![]() Telemetry and antenna signal:
Is it possible to log the antenna signal strength for review after a flight? Seems it should be something that can be checked but all I see in the Rx telemetry is the Rx voltage. Am I missing something? DC-16 and R6L rx ... Rob |
#58 (permalink) | |
![]() Quote:
#59 (permalink) |
![]() Have had my DS-16 for about two weeks. All I can say is wow! I am setting up my TREX 550. I do not understand the throttle hold vs auto setup. I have a Mezon 90 ESC and a 7ch Jeti RX. Can I put TH and Auto on one switch or do I have to use two different switches or one three position switch?
#60 (permalink) | |
![]() Quote:
Take the blades off and turn on the motor then lower your flat curve to a point where the engine stops and then add a few more clicks. I think that should take care of your problem.
