Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
#61 (permalink) | |
![]() Quote:
#62 (permalink) | |
![]() Quote:
When you are in throttle hold it figures you are starting the heli so it will spool up slowly. So with the way you want it on a single switch it thinks you want to spool up slow because you are starting the heli. So I don't think it is possible.
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Goblin700, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro EF MXS 3W110, Ultimate Aeroworks 20-300, DA 170, PowerBox Mercury, Q80-8M in a 91" EF Extra and MXS 104+ few jets |
#63 (permalink) | |
![]() Quote:
#64 (permalink) |
![]() Could anyone post the steps for getting a perfect rescue switch and slider for the horizontal function on the HC3SX please ?
Banshee 700 LE ![]() Goblin570 Vayu 350 ...and a s-load of planes |
#65 (permalink) | |
![]() Quote:
[ame]http://youtu.be/wHy6jnW5WI8[/ame]
Team - "Self Interests" - Flying what I want to, simply because I enjoy it! |
#66 (permalink) |
![]() OK - so I've had my DS for a couple of days and am reading though the manual ... slowly.
I will be suing it for a MR and will need to assign the SE switch for Manual / ATT / GPS ATT. My current configuration is that GPS ATT is enabled when the switch is set to the Top or UP position. When I look at the screen display: Main Menu --> Advanced Properties --> Sticks/Switches setup. Then I use the RIGHT arrow to go to the SE switch screen....and this is where is seems backwards to me. With the switch SE in the UP position, the status bar to the LEFT (what I think of being "down position") is darkened. Center is fine. Switch DOWN fills in the RIGHT side of the status bar. So - how do I "reverse" the throw direction of the SE switch? Thanks for the help. Dale. (OBTW - if anyone has a setup file for the NAZA that you've used with your DS-16, could you send it to me? I'd like to see what others are doing and "copy" so I don't necessarily need to start from scratch) |
#67 (permalink) |
![]() does the jeti ds16 wrk well with futaba cgy750 flybarless system? I have a newly built vario ec135 petrol heli setup with blade rotor head, 4 servo 90degree swash. setup with 45degree electronic setup through cgy750.just sold my futaba chg 10 channel radio and thinking of getting the jeti ds16 soon.
#68 (permalink) | |
![]() Quote:
#69 (permalink) | |
![]() Quote:
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
#70 (permalink) |
![]() The Mixer a switch for rescue and a slider for horizon on the Bavarian Demon 3SX hat been covered already ?
#71 (permalink) |
![]() Hey guys,
I must be missing something obvious, but how do I program the Mezon ESC via device explorer? It must all be connected as I can set up the sensors and I recieve information on voltage, current, rpm etc. however in device explorer I only get "R9 EX" (which I set up, seems fine) and "RC Switch" (which I have no idea where that's from). No Mezon ESC showing up. How do I program it? Edit - ah despite the wording of certain statements, it appears Mezon's are not accessible via device explorer, only via the jetibox app. Got it sorted now but that's a shame - device explorer is much quicker and easier to use!
#72 (permalink) |
![]() No device explorer for Mezon (yet). JetiBox emulator is quite simple though.
[ame]http://youtu.be/KgDYxiuUfFk[/ame]
#73 (permalink) |
![]() Helpful vid, thanks
#74 (permalink) |
#75 (permalink) |
![]() got it...
the trick was to use TWO identical mixers for the switch that has to override the slider setting the positive horizon values . |
#76 (permalink) |
![]() Well done!
#77 (permalink) |
![]() I have successfully set the timer:
Menu --> Timers/Sensors --> Timers. a. Created new timer labeled "FlightTime" Initial Value -9:00 (to count DOWN) Target Value 0:00 Timer Type: Standard Report Type: Voice Switch: P4 (activated at -90% through Advanced Properties --> Sticks/Switches Setup --> P4) Reset Type: Short reset ...and when the timer reaches -5:00 minutes I hear the voice - and every 10 seconds after it reaches 1:00 minute. Why not at 9:00, 8:00, 7:00 & 6:00 .......? How do I get the timer to "report" at each minute? I've tried several combinations in the Main Menu --> Timers /Sensors --> Voice output screen --> Repeat every "60 seconds" ... with no success. Thanks. Dale. |
#78 (permalink) | |
![]() I do not believe there is a way to change that. It starts at 5:00, then once each minute until 1:00 where it then announces every ten seconds until 10 seconds and then counts down.
Vector 550 Quad/Octo Multirotors DJI WooKong Multirotor Controllers Twin Bergen 44 Magnum Turbines - KERO Start FBL ![]() www.circlecityhelis.com |
#79 (permalink) |
![]() It can be done but you need to do some editing of a file in the Tx. The info on how to modify the timers voice calls is here.
http://www.jetimodel.com/en/DC-16-am...-notification/ //Dennis.
soXos Strike7 : soXos 600 : soXos 550 : soXos F3C 800 Protos 380 : soXos DB7 nightflyer : Jeti DS-16 & DS-12 : Mini Protos FBL Stretch : Logo 600 I am www.soxosaustralia.com.au | VTX blades | 1st-RC Products | EGODRIFT motors |
#80 (permalink) | |
![]() Quote:
While I know that most of you (us?) use the telemetry data to judge flight time, I have used my Tx timer for a long time by confirming my "flight timer" is still correctly set based on how many mAh I put back into the battery when charging (reactive). This new method will help provide "proactive" flight time judgement. Thanks again. Dale. |
