Old 10-11-2007, 11:58 AM   #1 (permalink)
Team Taco VP
Default Logo 5/6003D Build & V-Stabi setup videos by Mercuriell
This topic is for Mercuriell to post his Logo 600 build videos!
Thanks John!
Feel free to edit this up as you like. I love what you have done with the first post in your 600 build vids
Bob
Old 10-11-2007, 06:02 PM   #2 (permalink)
Thanks Bob - Worth noting folks that many parts of the Logo 600 are the same as the Logo 14 - tail slider - tail hub and I think much of the rotor head so much valuable info can be gained from checking out Bob's Logo 14 thread
LOGO 600 3D Build videos:
What's in the Box - 15MB wmv eal
Frame Build- 25MB wmv
Tail assembly - 46MB wmv
Gear assembly - 16MB wmv
Main grip & mixer arms - 16MB wmv
Rotor assembly - 23MB wmv
Washout and swash assembly 16MB wmv
Servo installation - 16MB wmv
Rotor head setup - 20MB wmv
Final thoughts - 23MB wmv
NEW Mikado V-Stabi
Installing flybarless head on L5003D and what's in the V-Stabi box ! - wmv 28MB
Connecting up V-Stabi Electrics - wmv 14MB
Assigning Bank switching to radio (JR 9303) - wmv 25MB
Electromechanical setup of V-Stabi on Logo 5003D - wmv 49MB
John
Old 10-11-2007, 08:17 PM   #3 (permalink)
Great, I was waiting for vids on this heli.
John, compared to the Trex 600CF, how does the quality compare ???
ADK
TREX 450 SE, HS65MG, 9650, GY401, Align 3K CF main Blade.
DRAGONUS II PRO, FUT S3153 DIGITAL SERVOS, GY401, Align 450XL .
TREX 600CF, 9255'S, GY401 9254, Fut 138 DP RX.
TREX 500CF, 4x9257 on 6 volt, GY401, 6S 2500's EVOLITE'S, 13T, 2700HS.
Antony Konnarides is offline        Reply With Quote Quick reply to this message
Old 10-12-2007, 09:22 AM   #4 (permalink)
Great work John! Now you make me want one even more!
Jeroen -
Just fly it!
BarnOwl is offline        Reply With Quote Quick reply to this message
Old 10-13-2007, 05:45 AM   #5 (permalink)
That's a very interesting question - the mouldings are very good quality and well thought out - the blade grips for instance are huge and really well reinforced, the feathering shaft is chunkier and the flybar 4mm as opposed to 3mm. I think the quality of parts is better say 9/10 compared to the T600 7/10 - the gear wheel mouldings are very substantial and well produced. The engineering is rather more elegant - double herringbone main gear, double radial/thrust bearing tail rotor, ball links at the end of the boom braces and the frame is really well thought out so I'd have to give it a big - but I love the T600s too !
John
Old 10-13-2007, 05:08 PM   #6 (permalink)
Thanks for your opinion !!!
ADK
Old 10-14-2007, 02:44 PM   #7 (permalink)
What do you think about the flybar being 4mm instead of 3mm when the other parts of the head are plastic? It seems that the flybar could destroy more of the head in a crash since it will transfer more destructive energy into other parts.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote Quick reply to this message
Old 10-14-2007, 05:04 PM   #8 (permalink)
I guess that's true but the job of the flybar is act as a rigid bidirectional strut between paddle and mixer arm so I assume thicker is better from a functional point of view - designers of model helis, like cars have to trade off durability against function and fashion - the Logo ethos seems to be to put the latter two first!
John
Old 10-14-2007, 06:04 PM   #9 (permalink)
just a question, but i was wondering if someone would ever do a build video on the vbar system on any of the logos. i know its very expensive to get but i think many people will want to see it done, including myself just a suggestion
Jason Chow is offline        Reply With Quote Quick reply to this message
Old 10-14-2007, 06:05 PM   #10 (permalink)
Does the 3mm flybar seem less rigid on the Trex600?
TRex 450SE
Spektrum DX7
Old 10-14-2007, 07:27 PM   #11 (permalink)
Man the tailboom looks like a bazooka. Nice looking machine.
skid is offline        Reply With Quote Quick reply to this message
Old 10-15-2007, 02:02 AM   #12 (permalink)
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 10-15-2007, 03:40 AM   #13 (permalink)
I don't know if Bob's getting a V-Bar with his L500 - I'll probably get one eventually but wanted to see what the stock machine was like as this is my first Logo.
John
Old 10-15-2007, 03:40 AM   #14 (permalink)
Yes the T600 3mm flybar seems very flimsy by comparison with the Logos 4mm version
OK tonight we put up a modded Frame video with comment to highlight that the bearing mount M2.5 x 10 bolts are TOO SHORT to safely engage the Nylock nuts - you need to get some 12mm ones or else Loctite them.
Also put up the servo installation - quite straightforward and no real probs - just mount the elevator servo first so you can get at the output arm through the left aileron servo hole.
John
Old 10-28-2007, 08:47 AM   #15 (permalink)
Put up the rotor head setup - pretty starightforward and the ball link lengths come out as per manual except for the servo to swash links which might be expected to vary - also posted 1st FF and hover in the Build Thread
John
Old 11-27-2007, 12:45 AM   #16 (permalink)
Thanks for all the info. The videos are great!
I was just wondering if anyone could tell me the best way of stretching the L600 to accomodate 690mm blades? ie. what would I need?
Cheers,
Griffo
Griffo is offline        Reply With Quote Quick reply to this message
Old 11-27-2007, 10:31 AM   #17 (permalink)
Smile
Cheers,
Griffo
Send a PM to N74DV he will have the boom and belt info you need.
rerazor is offline        Reply With Quote Quick reply to this message
Old 11-30-2007, 03:56 AM   #18 (permalink)
Mercuriell, thanks for the videos. How does Logo 600 compare to Trex 600 and which one do you prefer?
DeanK is offline        Reply With Quote Quick reply to this message
Old 12-01-2007, 04:25 AM   #19 (permalink)
I love them both - I like the gutsy, tough, simple design of the T600 and I love the floaty, soaring, effortless grace of the LOGO 600 - they're both great helis and I think it a shame that many Mikado acolytes look down on and badmouth the old T600 !!!
John
Old 12-01-2007, 07:41 PM   #20 (permalink)
I hereby hang my head in shame...
There's a reason I'm still hanging on to the T-Rex 600 even though I have a Logo. They're both still a blast to fly!
John
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote Quick reply to this message
