Old 07-18-2013, 11:15 AM   #221 (permalink)
No. Go to the Gyro menu on your Dx6i. Set up on of the numbers to 40 (that will be rate mode), the other to 60 (that will be HH). If you need more rate mode gain, go from 40 to 35. If you need more HH gain, go from 60 to 65.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 07-18-2013, 05:41 PM   #222 (permalink)
Awesome thanks!
tonyastro is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 01:07 PM   #223 (permalink)
I am having a problem with my ZYX. I can't get my gyro to initialize. When I plug it in all 3 lights come on then they flash and then I get a RED flashing light. I can't seem to get around this red light. I followed this manual http://fbl.net.nz/files/fblmanual.pdf to program it but I still get a red flashing light. I am starting to think I have a dud.
Blade MSRX blinged, MCPX blinged, 130X blinged, 450 3D - DX8
MfishWLRC is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 01:13 PM   #224 (permalink)
Red flashing light is an error code for "Initialization error". It probably means you are not keeping the gyro still during the initialization. After you plug in the battery quickly let the gyro/heli rest on the ground. Do not touch or move the gyro until it finishes the initialization procedure signaled by a twitch of the tail servo.
Goblin Speed | iKon
Old 07-22-2013, 01:26 PM   #225 (permalink)
I have been keeping it still. I don't have my servos plugged in, I just have it plugged into the RX. It is still flashing red
Old 07-22-2013, 04:03 PM   #226 (permalink)
Try doing a factory reset.
Goblin Speed | iKon
Old 07-22-2013, 04:06 PM   #227 (permalink)
I was able to upgrade the firmware and now it flashes blue and the software still wont recognize it and it won't take any stick inputs.
Old 07-22-2013, 07:27 PM   #228 (permalink)
Default Re: Tarot ZYX, ZYX-S & CopterX 3X-1000 Advanced Tuning and Troubleshooting Guide
Stupid question, but your tx is connected to the rx, and rx is plugged into the zyx, right? Just because the zyx needs to see the tx to connect, iirc. I know I had some trouble with mine like that at first, but can't remember.
Sent from my Nexus 4 using Tapatalk 2
mCPX V1 & V2 // 130 X // 450 Pro V2 -- ZYX-S // Fusion 50 -- BX
willr001 is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 12:38 AM   #229 (permalink)
I seem to remember the tail servo MUST be connected for the zyx to initialise
Kev
CPX450, HobbyWing 35A ESC, Scorpion 2221-8, HS65MG's, HK401B, InoLabs D401HB
Trex450 Sport Combo - All Stock
Trex600ESP Combo, converted to belt drive.
HK600 Stock Build Project
bionicbone is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 02:08 AM   #230 (permalink)
Kev
Nope no servos need to be connected, it only needs a valid TX signal to initialize.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 07-25-2013, 04:05 PM   #231 (permalink)
After 2 years of trying I've come to the conclusion that the CX-3X1000 gyro will not work on the 250.
Old 07-25-2013, 08:10 PM   #232 (permalink)
Lol. That's dedication right there.
Goblin Speed | iKon
Old 07-26-2013, 12:05 PM   #233 (permalink)
What sucks is the cyclic is great. I would think that the tail would be the least of my problems since there are $10 gyros that can do the job well. I wanna install a separate G401B gyro just for the tail
Old 07-26-2013, 01:10 PM   #234 (permalink)
Tails on 250's are notoriously difficult to tune. The problem is they have too much authority (i.e. mechanical gain). Possible solutions include eliminating all slop, getting a super high end tail servo, limiting tail pitch throw to less than what's max possible mechanically (from the gyro settings), and/or using shorter tail blades.
Goblin Speed | iKon
Old 07-26-2013, 01:44 PM   #235 (permalink)
Thanks. I'll try all of that.
- I have very little slop on the tail
- I'll definitely get a better tail servo
- So you're saying lessen my pitch limits?
I have another question. I hovered in rate mode to get the perfect pitch link length but when I went back to HH the heli was spinning right. I had way too much + pitch. Should I set the gain low when I'm hovering in RM? What's a good setting?
Old 07-26-2013, 04:03 PM   #236 (permalink)
#1 yes, lessen the tail pitch limits bit by bit to cut back on the max tail authority.
#2 tuning in RM - make sure you've got pitch precompensation off when you do this, otherwise it's gonna be too far off. OTT, don't fuss with this too much, it's only worth getting it close, doesn't have to be spot on perfect.
Goblin Speed | iKon
Old 07-27-2013, 01:21 AM   #237 (permalink)
Hi Guys,
I haven't seen an answer to a possibly silly question, does the ZYX and heli need to be on level ground for takeoff once setup properly on the bench? I'm completely new to the FBL scene, but have finally decided to give it a try after flying flybarred helis for a few years. With those the gyro needs to be still while it initializes, and it made me wonder if the FBL needs to initialize on level ground before taking off. Most of my flying locations are a little rough around edges which doesn't matter with the flybar, just add power and cyclic as needed
At any rate all the parts have arrived and I plan the build this weekend after reading forums like mad the last few nights.
Thanks all for any input.
supersirlal is offline        Reply With Quote Quick reply to this message
Old 07-27-2013, 02:02 AM   #238 (permalink)
Nope, the ground level makes no difference. In fact, I keep my 450 on its side when I plug in the pack and wait for the gyro to initialize. Also for take-off, ground level is inconsequential.
Goblin Speed | iKon
Old 07-28-2013, 08:39 PM   #239 (permalink)
Good to know,
Thanks Dr. M
Old 07-30-2013, 06:55 PM   #240 (permalink)
Default Any suggestions
Hello Dr. M and Mike,
Any suggestions on the 3X1000 on the 500, or just keep same settings as the 450's?
It is almost ready
kr,
Dave
dcb103 is offline        Reply With Quote Quick reply to this message
Tags
3gys, 3x-1000, tarot zyx, zyx-s
