Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 01-08-2013, 05:03 PM   #1 (permalink)
Question To bearing mod or not to mod
I just bought myself the 450x as my first "Real" heli. I am unsure after reading all your guy's posts if I should do the bearing loctite mod or not as I have not even flown my new bird yet. I have seen posts of owners that have over 100+ flights without issue, and others with problems in less than 50 or so. I even saw one person comment when they took thier's apart to do the mod, there was no c-clip retainer installed from the factory. I was not sure if there has been any updates to the models being sold as of now vs early generations? Any thoughts would be greatly appreciated as I am very much a noob, but I like to buy and maintain toys that will last me longer than poorly made or cheap toys.
P.S. I also noticed some speak of modifying the ESC and or use of hot glue to support a loose part? Thanks guys!
cantflygood is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 08:58 PM   #2 (permalink)
I haven't done anything with mine.
More than a few on this forum think the lube might aggravate the problem. I follow suit.
If it fails after 60 or 70 flights, by that time I'll be ready to upgrade to the eflite 450 motor (because my skills will be SO much better).
Realflight 6, Phoenix, DX8
mCPX v2, Blade 450x, KDS Innova 450sd, KDS Innova 550 v2
Syko is offline        Reply With Quote Quick reply to this message
Old 01-09-2013, 03:25 AM   #3 (permalink)
The ESC mod would consist of installing a step down diode for the tail servo (which cannot run at 6V) and switching the ESC to 6V to minimize the risk of VUS which would cause a brownout.
The hot glue can be applied at the base of the capacitor which comes out of the ESC/SBEC, where it is soldered to the PCB, inside the heat shrink, to avoid that vibrations make it loose.
I strongly suggest both very easy mods.
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 01-09-2013, 09:22 PM   #4 (permalink)
I was hoping someone would say leave well enough alone on that mod for now.
On another tangent- how did your Fusuno custom painted canopy turn out? I was interested to see some teeth. I used to paint cars, now just run the office and paint a few customs on the side. I was thinking for the price of buying the EX canopy unpainted.
Thanks for the reply!
Old 01-09-2013, 09:30 PM   #5 (permalink)
What would your opinion be on replacing the cheap plastic geared tail servo instead of the diode installation? Then just flip the switch so to say and run back through the beast set up? If this would be a better option what servo would you recommend?
Also any chance there is a video clip or thread detailing the hot glue capacitor trick?
Lastly I just have to say thanks for the people running this forum, and the great wealth of knowledge the visitors are willing to share with such a noob to the hobby as myself!
Old 01-10-2013, 01:20 AM   #6 (permalink)
The stock tail servo is actually a good one, only small disadvantage is this not running at 6V.
The step dow diode mod is very easy and cheap if you buy the one with the servo plugs already installed (search the forum for details), so I would suggest this mod first, then maybe upgrade the tail servo when and if it strips/burns out later.
In that case... again, search the forum, alternative servos are discussed again and again... almost every week: Hitec 5084MG, MKS DS95i and Savox SH026MG seem to be the most popular ones, IIRC. I used to run a Hitec, now I run the MKS.
Old 01-10-2013, 02:41 PM   #7 (permalink)
Look at the 330 uF, 35V electrolytic capacitor on the battery lead side of the ESC....
You can't miss it.....it hangs off the end of the ESC PCB...which is the issue.
Look at where the leads are soldered to the PCB.
There is no support from the PCB so vibrations cause metal fatigue at the junction of the capacitor leads and the solder pad on the PCB.
All you need to do is to lay on a "blob" of hot glue so that the "can" of the capacitor is glued to the PCB. Don't worry if you "bridge" the capacitor leads with the glue "blob". That won't hurt anything...
FWIW
EEngineer is offline        Reply With Quote Quick reply to this message
Old 01-11-2013, 12:31 AM   #8 (permalink)
EEngineer,
Thanks for the info, I now have something easy to due this weekend!
Old 01-14-2013, 04:16 PM   #9 (permalink)
FWIW i took my motor apart after 3 flights to add locktite. After only 3 flight you could see wear on the shaft from it spinning inside the bearing.
B
Lowenslow is offline        Reply With Quote Quick reply to this message
Old 01-14-2013, 05:14 PM   #10 (permalink)
Default Re: To bearing mod or not to mod
I've just completed the loctite motor mod on mine and I would strongly recommend doing it. It solved the vibe problems I was having and it only takes about 30 minutes to pull the motor and apply the loctite (although you should wait 24 hours for the loctite to fully cure). I would also suggest putting loctite on the flybarless follower arm screws, as they will eventually loosen without it and cause vibrations that will mess with the AR7200BX.
In my opinion, 30 minutes of your time isn't worth a pair of CF blades and a main shaft. I had a set of Radix blades get chewed up when the 450X tipped over on spool up because of the right tilting of the swash caused by the vibrations interfering with the AR7200BX. The tip over also bent the main shaft.
Also, I don't know if you've actually read any of the write-ups on performing the loctite motor mod, but a few tips:
-Apply red loctite to the inner race on both the upper and lower bearings.
-Use the eye of a sewing needle to apply the loctite.
-Make sure you don't use too much loctite because it could run over the edges of the inner race which could bind the bearing. (A sewing needle eye full of loctite is enough to get the job done.)
-When reinstalling the motor, set the pinion backlash with two screws in the motor mount. Apply blue loctite to and install the other two motor mount screws, then loctite the first two screws.
My 450X is only a month and a half old, so it appears as though they haven't yet fixed these issues from the factory. I only had about 15 packs through it before I started having the vibration issues.
Mikado Logo 700 Xxtreme, Synergy N5c, Blade 450X, Blade Nano CP X
Spektrum DX8
kennyd1gital is offline        Reply With Quote Quick reply to this message
Old 01-17-2013, 10:55 PM   #11 (permalink)
B
Nice! Sounded too good to be true to leave it alone. Thanks!
Old 01-17-2013, 11:02 PM   #12 (permalink)
Kenny,
I apreciate the info, I went to the hobby shop the day after your post & bought red and blue loc-tite. I saw a video on you tube for the bearing mod, but looks like he only did the lower bearing. Sounds like red loc-tite for bearing to shaft, and blue for any metal to metal retention? Also on the video I watched it seamed that when you put the shaft back through the bearing, most of the loc-tite would scrape off the shaft wouldn't it?
Thanks for the reply and helpful tips, including the motor mount screw trick!
Old 01-17-2013, 11:58 PM   #13 (permalink)
I would recommend doing both. The lower bearing is the one causing the vibes, I think, but I went ahead and did both anyway for redundancy.
That is correct.
Some of the loctite will probably rub off on the shaft, but enough will remain on the race to bind it to the shaft. The thing you want to be careful of is not to use too much because then when you slide the shaft through, some of it might run over the edge of the inner race and get into the bearing. You should be fine using the eye of a sewing needle to apply the loctite. Filling the eye of the needle should be just enough to coat the inside of the inner race. Fill the eye and apply to the upper bearing inner race, then fill the eye again and apply to the lower bearing inner race.
Also, when you go to put the shaft back through the bearings once the loctite is applied, it may take a little force to get the shaft seated on the bearings, because the red loctite has now filled in the small gap that was between the inner race and the shaft. Just be sure to push the motor/bearings all the way back into the housing/onto the shaft in one motion. Try not to slide the bearings back and forth on the shaft once the loctite has been applied.
Lastly, take your time with it and think your way through each step before you do it. Good luck! Let us know how it goes!
Spektrum DX8
Old 01-18-2013, 08:51 PM   #14 (permalink)
Was there anything wrong or you didn't like about the Hitec servo? Why the switch?
helifanatic99 is offline        Reply With Quote Quick reply to this message
Old 01-19-2013, 12:43 AM   #15 (permalink)
The Hitec was just dying... could not get rid of tail shake during FFF and fast right turns (no, neither reducing gain nor pot 3 helped, it was the servo).
Old 01-19-2013, 01:49 AM   #16 (permalink)
I'm guessing this could be part of the problem I'm having with getting my tail dialed in. How do you like the MKS servo? I'm thinking about getting some to replace the stock servos in my 450X.
Spektrum DX8
Old 01-19-2013, 01:55 AM   #17 (permalink)
I actually had bought it for my coming Warp... then just used it when needed.
I have now some 50 flights on it and very happy (but the Hitec was as good from what I can tell, I'm ot good enough to judge the differences).
Old 01-19-2013, 02:31 AM   #18 (permalink)
Lubrication of the bearings - not with thin and watery.
Trex :- 450SE V2 retired, 250SC retired, 450 PRO fbled Airwolfed, 500 ESP fbled Airwolfed, 250DFC, 450DFC, 500DFC, 800DFC. M690l, MR25P - Futaba/Align. Blade :- 4003D retired,CX2, MQX, 350QX v3 - spektrum. 4503D, 450X - spektrum/Savox.
jimmanyk is offline        Reply With Quote Quick reply to this message
Old 01-19-2013, 09:01 AM   #19 (permalink)
Did you crash the Hitec servo? From what I've read, those are supposed to be some pretty tough metal geared servos.
Old 01-20-2013, 10:48 PM   #20 (permalink)
Thanks Kenny,
Bearing mod is now completed, and I only had one bone-head move- that was installing the motor mount before the pinion gear during reinstallation. Easy enough though overall, next I still need to hot glue the capacitor on the ESC and find the right diode for the tail servo.
I still haven't even had a chance for good weather to fly this thing yet!
DX9, Phoenix 5 sim, Blade 120sr, nano cpx, Blade 130x, Blade 450x
