Old 01-07-2013, 05:06 PM   #1 (permalink)
Default Standalone Jeti Telemetry
I am considering using Jeti telemetry without their TX (too expensive for the moment) because I really want mAh data (stupid spektrum still do not supply it).
I assume you can use http://www.espritmodel.com/jeti-tele...rogrammer.aspx to receive the data without using a TX?
Will a Rsat2 work as telemetry TX (not in US so dont need FCC approval)?
Is there any way to use the RPM signal from a VBar enabled YGE ESC as input to the jeti system, or will I need to use their sensor?
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 01-07-2013, 05:55 PM   #2 (permalink)
You can use a Jeti Box with all the telemetry modules. I do not know if you can use the VBar enabled YGE ESC as input. Rsat2 should also work.
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
www.circlecityhelis.com
lperagallo is offline        Reply With Quote Quick reply to this message
Old 01-07-2013, 11:22 PM   #3 (permalink)
You will need the Jeti RPM sensor unless you are feeding the JB Profi with JLog or JLog2.
Another option is to get a Mezon ESC and a JetiBox Profi and the Mezon will send everything you'd ever want to the Profi (including rpm).
Team - "Self Interests" -
Flying what I want to, simply because I enjoy it!
Seasick78 is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 11:55 AM   #4 (permalink)
You can do it with a Profibox, the appropriate MUI voltage/current sensor, and a small receiver like an R5L to transmit the telemetry data to the Profibox.
If you want to see RPM on the telemetry you'll need the Jeti brushless RPM sensor or as mentioned if you switch to a Mezon ESC you won't need either the voltage/current or the RPM sensors as the Mezon already has that capability internally and will send voltage, current, mah consumed, and RPM directly the R5 receiver.
According to Esprit the next shipment of Mezon ESCs will have a built in phase sensor output for external governor use. The current Mezon ESCs will work with an external governor but you need a phase sensor.
I'm currently using a YGE160HV with a MUI200 sensor for voltage/amperage/mah telemetry but I might simplify the wiring and switch to a Mezon 135 Opto when the next batch arrives.
Minicopter Diabolo - BD Axon, Kosmik 200, Xnova XTS 4530-480, 14S 4500, BLS255HV/BLS256HV
Bergen Magnum 44 -
BD Axon, Wren MW44 turbine, BLS156HV/BLS256HV
Jeti DC-16
Kiba is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 12:30 PM   #5 (permalink)
Kiba.
The OP is from Australia so he can use the RSAT2. Doesn't need the R5.
Lou
Old 01-08-2013, 01:41 PM   #6 (permalink)
Originally Posted by lperagallo View Post
Kiba.
Lou
Didn't notice that. Even more convenient for him that he gets the RSAT2, and way to rub it in for us customers in the US that don't get the RSAT2.
Bergen Magnum 44 -
Jeti DC-16
Old 01-09-2013, 03:19 AM   #7 (permalink)
Are these ESCs available for sale yet anywhere?
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 01-09-2013, 08:27 AM   #8 (permalink)
Expected late this month in US. You might check Hacker site in Europe. They call it the Master Mezon there.
Old 01-10-2013, 08:11 PM   #9 (permalink)
Do those support external governors? Do they have a RPM output for use with external governors?
I really like that about my YGEs, would be a pity to give that up to get telemetry.
-DX8
Old 01-10-2013, 08:49 PM   #10 (permalink)
From what I understand yes the ones coming to the states will support an external gov.
BustedRaptor77 is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 08:51 PM   #11 (permalink)
Cool, do you know if they will have a separate lead for RPM output (like a YGE) in a format FBL systems read or will one need an external sensor?
-DX8
Old 01-10-2013, 08:53 PM   #12 (permalink)
The new Mezon is supposed to have a built in phase sensor.
Old 01-10-2013, 09:05 PM   #13 (permalink)
About three minutes into this video it is called "fast response" https://www.youtube.com/watch?v=fERT...layer_embedded
Old 01-10-2013, 10:27 PM   #14 (permalink)
As far as i can tell from that video though, there is no extra lead for RPM output to the FBL on that model. So you would need a sensor...
-DX8
Old 01-10-2013, 10:29 PM   #15 (permalink)
Ask F1Rocket I think he made the video.
Old 01-10-2013, 11:54 PM   #16 (permalink)
All new Mezon 130 and 135 ESC will come with the RPM output lead. The one we use for the video did not have it.
Danny
F1 Rocket is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 11:57 PM   #17 (permalink)
Danny
What about the smaller ones?
I dont have a 700, likely will not in the near future, and get rather irritated when the cool features are only available on the top end ESC (I am looking at you kontronik )
Even the smallest Mezon is quite large.
-DX8
