Old 01-11-2015, 11:07 AM   #81 (permalink)
Originally Posted by omerco View Post
I think scorpion recommended somewhere to soak it in alcohol for 2 days to break the locktite. not sure if i remember correct (?)
Yes that was the answer I got from Scorpion, and it works well, soaking it in alcohol bought at a pharmacy overnight and it just needs a soft tap and then slides off. If using this with the powder coated stators of other motors be careful as it destroys the powder coating as well
VControl
Old hand at Planks
Peter
Old 01-11-2015, 01:45 PM   #82 (permalink)
It is not powder coated, thank you , i will try 100% alcohol
But will be careful
Logo 700XX (kosmik160,KDS4725-548kV)
Logo 550SX (hobbywing 120HV, HK4025-1400kV)
Miniprotos
krtek2k is offline        Reply With Quote Quick reply to this message
Old 04-25-2015, 06:06 PM   #83 (permalink)
Sticky/FAQ in the Electric Motor Design and Construction - RCGroups subforum:
(Re)winding and building motors: tips&tricks, manuals, resources, videos, checks&tests.
Vriendelijke groeten Ron
ron_van_sommeren is offline        Reply With Quote Quick reply to this message
Old 05-05-2015, 04:13 PM   #84 (permalink)
Hi,
I keep reading about "test winding" in order to find the the exact Kv of a motor.
Can someone explain me the process?
Thanks!
Papabill is offline        Reply With Quote Quick reply to this message
Old 05-05-2015, 04:24 PM   #85 (permalink)
See opening post, item #10 of this sticky
(Re)winding and building motors: tips&tricks, tutorials, resources, videos, checks&tests.
Old 05-06-2015, 01:50 AM   #86 (permalink)
Originally Posted by Papabill View Post
Hi,
Thanks!
mainly it means wire thickness plays little roll in KV changes so we first do the planned wind with a relatively thin wire to determine the constant Ron has written, and then we calculate #of turns to get the desired KV.
All that before we put the effort of putting the final thick wire.
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 05-06-2015, 01:01 PM   #87 (permalink)
Thanks!
Old 05-06-2015, 01:07 PM   #88 (permalink)
As I am trying to understand YY termination can you please tell me if the following is YY termination?
Thanks!
Old 05-06-2015, 01:12 PM   #89 (permalink)
Yes it is: 2 seperate Y motors with their phases connected respectively
Old 05-06-2015, 01:15 PM   #90 (permalink)
Thanks, and this winding scheme?
Old 05-06-2015, 02:26 PM   #91 (permalink)
Also YY - the difference between the schemes is that the first is for 10 magnets bell and the second is for 8 magnets one.
use this calculator:
http://www.bavaria-direct.co.za/scheme/calculator/
put 12 slots and then play between 10/8 magnets you will see the difference.
Old 05-10-2015, 10:37 AM   #92 (permalink)
Hey guys! Those are my drawings from RCG! I'm ApexAero there, I got interested in motor rewinding when seeking more to do in the hobby. I spent about 140 hours reading and studying BL motor winding in both forums and have just touched the surface but have enough info to wind and share these days. It has renewed my interest in model aviation after getting burned out on Nitro. Many thanks to Ralph and Ron for the inspiration. Am now after the 250 mph barrier at the age of 60 with my arthritic hands and all!
peace out,
Tom J
PS: I still have my 05' Rex 450 V2 w/3400 rpm head speed!
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote Quick reply to this message
Old 09-25-2015, 10:42 AM   #93 (permalink)
Turn Calculator 7
Includes the calculation of the surface of a slot in the stator, and the maximum number of turns that can be achieved as well as the resistance of the wire.
www.rcgroups.com/forums/showthread.php?t=2228201
Prettig weekend Ron
Old 10-25-2016, 11:58 AM   #94 (permalink)
Talking 4525 ultimate winding
One question guys I just rewind this motor 6+4 yy using 0.4547mm copper wire 8 strands, indeed this motor its working fine but its doesn't has the power like the original. I don't understand the table calculator. how many strands and turns I had to have to achieve with this wire to get 520kv on this motor?. I had to rewind with original wire 1.4mm that for me its very difficult. Any suggestion are welcome
darkglen is offline        Reply With Quote Quick reply to this message
Old 10-25-2016, 03:12 PM   #95 (permalink)
You need 11 Turns on that motor to get to the 525-550 kv range, not 10.
For the copper - it's basic mathematics: calculate the cross section area of the original one strand and compere it to the new one X 8
http://www.engineeringtoolbox.com/aw...uge-d_731.html
http://www.basic-mathematics.com/are...alculator.html
Old 10-25-2016, 03:52 PM   #96 (permalink)
Thanks a lot
