Go Back   HeliFreak > Multi Rotor Support > Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Open Source Flight Controllers (CC3D, Ardupilot, etc.) Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Old 01-17-2013, 09:16 AM   #1 (permalink)
Default HK KK2.2 board Throttle error. No signal?
Hey All,
I have an issue with my new HK KK2.2 board. When I plug it in I get a "throttle error. No signal". I checked the cables and made sure black is on the outside. Then switch out the receiver and throttle cable off my other helicopter with the same error, pulled out my volt meter to test voltage and all seems good. I'm not sure where to go from here.
My question, am I missing a something or did I get a bad board, should I try something else?
Any help would be greatly appreciated.
Scott
Align T-REX 450 Sport
(Castle Creations Phoenix 45), (Spektrum DX8 AR8000 TM1000), (Revolectrix Co-Pilot II Lite)
http://www.helifleet.com/Halcyon32
Contributor, Team LavaQuad
halcyon32 is offline        Reply With Quote Quick reply to this message
Old 01-17-2013, 10:00 AM   #2 (permalink)
HF MR Support
...Is your TX on?
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 01-17-2013, 10:06 AM   #3 (permalink)
Go into the MISC Settings and make sure CPPM is disabled.
Also go into the receiver test screen and see if any of the other channels are working.
Subaru4WD is offline        Reply With Quote Quick reply to this message
Old 01-17-2013, 10:15 AM   #4 (permalink)
Thanks for the help
Originally Posted by PTcaflyer View Post
...Is your TX on?
TX is on.
CCPM is set to no. In the receiver test it only shows throttle as no signal. All others are showing a number.
Any other ideas.
Old 01-17-2013, 10:18 AM   #5 (permalink)
Originally Posted by halcyon32 View Post
Thanks for the help
TX is on.
Any other ideas.
Take the cable comming from the RX leading to the KK2 off your throttle channel and swap it with the cable on your ELE or AIL channel. I have had issues with those connectors before being bad.
Old 01-17-2013, 10:25 AM   #6 (permalink)
[QUOTE=Subaru4wd;4635611]Take the cable comming from the RX leading to the KK2 off your throttle channel and swap it with the cable on your ELE or AIL channel. I have had issues with those connectors before being bad.[/QUOTE
Same thing. shows throttle as no signal
Also checked for cold solders, they look fine.
Old 01-17-2013, 10:26 AM   #7 (permalink)
What transmitter are you using?
What channel is your throttle programmed to?
If you put the throttle channel of the RX, on the AIL input of the KK2, does AIL respond to your throttle stick??
Old 01-17-2013, 10:39 AM   #8 (permalink)
Transmitter is DX8 RX is AR6115e,
OK we have a result. When I moved the AIL to the Thro and the Thro to the Ail. Now the AIL is showing no signal...
Are you telling me I have two bad RX's. I just flew this one yesterday... Lol
Guess I will have to get two new RX's...
Thanks for the help guys...
Old 01-17-2013, 10:49 AM   #9 (permalink)
No. I think your transmitter is not programmed correctly and is not outputting any signal on your THR channel.
This sounds more like a DX8 issue and not a RX or KK2 issue. Could be a bad cable, but you said you already swapped cables so that's probably not it.
Old 01-17-2013, 11:16 AM   #10 (permalink)
That sounds better than two bad RX's. I'll have to reprogram the THR channel and see.
Old 01-17-2013, 11:53 AM   #11 (permalink)
Ok so now I am confused.
TX is programmed to the THR throttle channel as far as i can tell. Or at lest the throttle is showing its programmed in the monitor. When I move the throttle up and down the monitor is showing the THR channal moving correctly.
Old 01-17-2013, 12:02 PM   #12 (permalink)
Plug a ESC directly into the THR channel of your RX and see if it responds to throttle input.
make sure you have no props attached to the motor!
Old 01-17-2013, 12:33 PM   #13 (permalink)
Nothing
Old 01-17-2013, 12:43 PM   #14 (permalink)
Thats your answer.
No THR output from the RX.
Old 01-17-2013, 12:47 PM   #15 (permalink)
Thats your answer.
So bad Rx then...
And Now My TX Batt died... Talk about timing.
Thanks for all your help,
Old 01-17-2013, 01:04 PM   #16 (permalink)
Maybe you can reprogram the DX8 to output its throttle to a separate channel? I dunno, but that sucks. Also, if the battery was very low, maybe the DX8 did not have enough power to output to all channels.
Have you used this TX/RX combo successfully on other planes?
Old 01-17-2013, 01:10 PM   #17 (permalink)
I have use it on others in the past but its been awhile. Ill wait and see if it is the TX batt before I go buy a new RX
Old 01-17-2013, 03:09 PM   #18 (permalink)
Mine is setup in Acro mode not heli . Maybe try that
jombo is offline        Reply With Quote Quick reply to this message
Old 01-17-2013, 04:48 PM   #19 (permalink)
Would be best if you had a plane mode as the KK2 just takes basic input and does what it needs to with it.
Old 01-18-2013, 06:13 AM   #20 (permalink)
I have it set up in plane mode. I tested with the TX Batt charged with the same results. I am gona go to my LHS and get a new RX and see if that works. Wish me luck
