Old 06-03-2013, 02:49 AM   #21 (permalink)
For anyone trying to get logview to work i have put a step by step guide together that should work on any computer no matter what OS you are using.
http://www.archeli.com.au/forums/sho...73#post1552173
I hope this helps a few people out that are still struggling with this system.
waxman is offline        Reply With Quote Quick reply to this message
Old 06-08-2013, 12:44 PM   #22 (permalink)
Thanks for these videos John. It's your fault I got the Diabolo (your build videos) and now it's your fault I'll be able to read my log files
BTW, My appData folder, in my user folder, was hidden (win7). I had to change my settings in control panel to show hidden files/folders. I was until I figured this out.
THANKS AGAIN!
Diabolo…HC3SX…Gmauro HKIII-4530-450…KOSMIK 200…MKS HLB950/HLB980...Rev 14s 4400 60C
Protos 500 Stretched
…HC3SX…Hyperion 3026-880kv…KOBY 90…MKS DS9670A+/DS-760...TP 6s 3300 65C
mCP X bl...Nano QX...Futaba 8FG
NickBee is offline        Reply With Quote Quick reply to this message
Old 10-07-2013, 10:26 AM   #23 (permalink)
Default Some Kosmik and Logview Setup videos
So..... I followed the videos but still cannot 'import device file.'
Team - "Self Interests" -
Old 10-07-2013, 10:47 AM   #24 (permalink)
Disregard my last post. Figured it out by loading a .lov file.
Old 10-08-2013, 01:09 AM   #25 (permalink)
Doing my best to get this working , and not a chance after watching video several times.
Any shortcuts ? I've been at it for 4 hours now.
Windows 7 64bit
I have the kosmic ini file on the desktop ready to go into the proper folder.
Open up the gereta folder and the other folders aren't there. ( csv and openformat )
Tried going into control panel and changing setting to show hidden folders and still not there.
I ended up sticking it in the main gerata folder and I can see it on the menu screen.
When I select it the data options on left aren't there.
Not able to upload off sd card either.
seasick ... Could you tell me more about the lov file ? where to find one and where to put it ?
Martin
Logo XXtreme 800 8917 / 256HV VBC
rcmarty is offline        Reply With Quote Quick reply to this message
Old 10-08-2013, 01:24 AM   #26 (permalink)
I got it to work a bit more.
With the program running , I went to open , got an error , clicked ok , then I got to see folder.
Moved the files into the folder ( ini and lov )
import device file is now selectable. Click on it and select a file from sd card
Little green bar on bottom loads file , gets to end and disappears , then nothing.
Is it hanging up at this point ?
Martin
Old 12-17-2013, 11:50 PM   #27 (permalink)
I am having a similar issue. I'm using the SCG Module with my cool kosmik, v4.2. It seems that logview is hanging up trying to open the data generated from the SCG. Any potential workarounds for this? What happens is I goto open devicefile, the green bar at the bottom loads across, and then there is no data displayed on the graph when it finishes loading. There is no load error either. I was taking a look at the log files in excel and noticed a checksum to check the data coming in from the SCG module. Maybe this is the cause for logview not loading? Not sure how exactly to modify the .ini file, but I'm sure there's a way
edit: Here is a shot of the data from my .log file. It looks like the standard .ini being used does not cover the extra data generated from the SCG, which can be seen in the columns after 'tv' Any ideas on how to modify the ini to either look at, or disregard that info?
Regards,
Keith
Keith
Goblin 700C Gasser -- Goblin 700C -- Goblin 570 -- Gaui NX4
#29
gcac399 is offline        Reply With Quote Quick reply to this message
Old 12-18-2013, 02:05 AM   #28 (permalink)
Regards,
Keith
I had similar issues. Finally figured it out.
I had about 15 logs on the card , some that were there before I updated the software in the kosmic.
In desperation I started going older and older on the logs , then just before the first one it worked.
After a ton more tinkering I finally figured out that the software update on the kosmic was no longer compatible with the lov and ini files I had in computer program.
Removed them then back to kontronics website and I got different versions that were for a updates kosmic.
Hope this helps some
Have you updated the kosmic ?
Has it ever worked ? ( pre updated kosmic ? )
MArtin
Old 12-18-2013, 11:53 AM   #29 (permalink)
Thanks for the reply. This is my first kosmik which I just got on a Black Friday sale I haven't messed around with different software versions yet. I made an excel program that will do the job of log view in the mean time, to make sure there's no crazy outliers current, voltage or temp wise which would indicate a problem withm y new setup (I.e. Cold solder joint etc)
The info from the log files says it's firmware v4.2, but I've never had it work since this is all brand new to me. I do haves. Progdisk if i want to downgrade the software, but I would then be concerned about the cell guard module working with the older firmware...
Keith
Keith
#29
Old 12-18-2013, 12:13 PM   #30 (permalink)
Keith
The SCG module you are refering to will not work with any previous versions of the firmware.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 02:57 PM   #31 (permalink)
Thanks Mercuriell
Your instructions still work with lastest logview 2.7.6.511
Khalil N.
Seaview Rotary Wings, Brooklyn NY.
nuroo is offline        Reply With Quote Quick reply to this message
Old 05-30-2014, 07:23 AM   #32 (permalink)
My log view was working great until I updated new software for kosmik now it doesn't work.. what are the proper steps to get it back running?
kevinbj is offline        Reply With Quote Quick reply to this message
Old 05-30-2014, 07:27 AM   #33 (permalink)
There are two versions of .ini device files for Kosmik, v3.02 and after and before. Go to the Heliporn ini generator and try and make a new .ini device file
John
Old 05-30-2014, 08:32 AM   #34 (permalink)
Do I have to reinstall lov. Files also?
Old 06-15-2014, 11:35 AM   #35 (permalink)
I have install the new kosmik firmware and updated the logwiew on my pc but now my log view takes 30 min or more to show the log.. any reason why?
Old 06-15-2014, 04:35 PM   #36 (permalink)
how old is your pc?
Richard Zappe
Old 06-16-2014, 07:01 AM   #37 (permalink)
Originally Posted by Wh1teAfr1can View Post
how old is your pc?
Well its a laptop but only a yr old.. before I installed the new firmware . The kosmik it use to take seconds to download the graph.
Old 06-16-2014, 07:46 AM   #38 (permalink)
are you using SCG module? also have you updated your ini file recently for log view?
Richard Zappe
Old 06-16-2014, 08:19 AM   #39 (permalink)
HF MR Support
Yep, the latest version takes forever on my MacBook Air too.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 10:12 AM   #40 (permalink)
I'm not using Scg module.. I don't know what that is.. I jus take the card out the kosmik & insert to laptop but since update it takes forever to view log.. Please explain SCG module
